Starting a Quality Department from Scratch and Implementing ISO 9001
P
pthareja
#11
If you are the one given the potentially poison chalice of writing up a QMS from scratch without help then how likely is it you are going to convert the top managers to a good quality way of thinking? Especially if they were arguing against the need for certification in the first place.
Sky is the limit for QMS
But, the path is straight for right quest!
May be there are obstacles in the way,
some clouds in the middle, destined to sway!
Why get deterred with the dark clouds ,
because some good ones can still connect well
towards the distant objective, in large 'clouds'
And your initiatives will, some day swell,
very well!
John Broomfield
#12
Good evening and thanks for the replies so far.
ISO was not the choice of the management of our department, it was demanded from the Head Office. By starting a new department, they thought they could make this easier, and yes, their idea is just to get the certificate and that's it. I know that's not the way to start, but I have to take it as it goes.
I wasn't too happy when I got this assignement, but now (2 weeks later), I'm getting more interested. And at the end of the day, I have to make this a succes, with or without the management.
Control666,
Welcome to the Cove and we wish you every success with turning an edict from head office into an effective management system.
Keep us posted on progress and problems.
We are here to share your successes and discuss your problems.
John
Sidney Vianna
Post Responsibly
#13
Sorry, but you are in an untenable situation. Even if you manage to lead this small organization thru certification, the QMS certificate won't help you, if the service performance is subpar. In my experience, customers tend to start requiring QMS certificates from suppliers with quality problems. Customers tend to think that ISO 9001 certification will lead to supplier performance improvement, but, and unfortunately, certification does not necessarily lead to improvement.
If "management" is not interested in developing, involving itself and supporting a quality MANAGEMENT system, you are destined to fail; even if you "succeed". In my opinion, if you can not manage to have them engaged in the process of putting the system in place, you have to realize that you will become the "system". Be prepared to deal with the consequences of that. Such as, if there is a major quality problem, guess who the managers will sacrifice in the altar of Joblessness to appease a disgruntled customer?
Controls666
#14
Good morning,
Yes Sidney, I understand that, but what do you think what will happen if a say "No"to the management and tell them that they can do it themselves. I guess I would see that altar also.
At least now I have the possibility to turn them around. Anyway, as stated in an earlier post, the 2 managers who are against it, are hired. The third one (he's also the Financial Controller) already agreed via mail his support (which gives my a bit more chips in my stack).
John Broomfield
#15
Good morning,
Control666,
No one is saying "say no to management and do it yourselves".
Your new role is to engage them in the development, use and improvement of their management system.
For this it is best to start with the system as it is rather than "writing a QMS" around ISO 9001.
John
Controls666
#16
Well, a new development has occured. As I explained (to the management)that it was impossible to start a ISO procedure without the full co-operation of the management, by using this thread and the help of a certification expert ( I recently obtained VCA* for the company, Safety Certificate, by him), some doors suddenly opened. Myself and 1 hired manager will go on a introduction course ISO 9001, followed by another course of Internal Auditor. Both will be given in December, but untill then, I can hire a consultancy bureau and have the opportunity to consult our (also hired)IT guys.
Don't know what just exactly happened, but at least we're going forward (Well, at least I hope so)
TPMB4
#17
It sounds like it is getting interesting. Please keep us informed, I for one am interested in your progress and developments. If that is not being too nosey of course.
It sounds like you are getting the top management on board and the help/input you need. Or at least some of it but that is a start.
smryan
Perspective.
#18
Control666, you are definitely in the right place for help and guidance. I too am not from a Q background but am now the ISO Queen in our small (approx 50 employee total) company. The wealth of knowledge & experience here is invaluable!
I totally agree with JRB (you HAVE a system, start there) - but would break it down a small bit further.
:2cents:
1) Get a copy of the standard to which you wish to become certified.
2) Skim through it the first time noting all the overlap & redundancy. Realize that you do not have to have a document or separate process for every bullet in there. There are actually only a few "Thou shall have a document" requirements in there. Often a single documented process will apply to several sections.
3) Read through it a second time thinking about which processes you already have that are meeting each of the requirements. You'll probably spot some weaknesses too.
4) my personal process - take it or leave it - take the electronic format of your purchased ISO pdf, copy & paste it into a Word document. Turn it into a table. Add a column to the right. Start filling in on the right what documents or processes you have that meet the requirement on the left. Good way to spot the gaps and make sure those that need to get filled in do.
Best of luck!!
Controls666
#19
Being nosey has nothing to do with it. For what I know, most of these type of situations (intern politics) happen in each organisation, big or small. For what I can tell, someone pulled some strings at the Head Office. In my opinion, that's not the way to do it, but if it means progress for this particular task, I take everything.
Something I didn't mentioned before, I'm on holiday upcoming Saturday for 2 weeks and when i come back, there's a meeting here with all the Area Managers & Board of Directors. And I maybe mentioned during the meeting few hours ago, that we would look not so good if we had nothing to show for, if this subject was brought up...
G
Gmzita
#20
Controls666 -
I bought a book on ASQ's website that I have been reading to try and help steer me in a new QA initiative at my job -
"The Change Agent's Handbook - a survival guide for Quality Improvement Champions" by David Hutton.
I am about 1/2 way through and have several pages of notes to help me with initial proposals and how to start.
It may help!
J Implementation of Total Quality Management/Starting a Quality Department Reliability Analysis - Predictions, Testing and Standards 9
M Starting a quality Department - What are the things I need to initiate it? Misc. Quality Assurance and Business Systems Related Topics 5
C I'm starting my Career in Quality Assurance Career and Occupation Discussions 8
D Just starting out looking to get into a quality engineer position Career and Occupation Discussions 2
M Implementing a Quality System - Just starting out..... in over my head. Quality Tools, Improvement and Analysis 12
F Starting a Quality Control Program and writing a Quality Control Manual Quality Manager and Management Related Issues 10
R Starting In-Process Quality Inspection in the Production Shopfloor Inspection, Prints (Drawings), Testing, Sampling and Related Topics 13
E Starting to write a Quality System Manual - Import/export medical devices - Need help ISO 13485:2016 - Medical Device Quality Management Systems 1
B Starting a new Quality System ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 17
D Starting a Business Related to Quality in a 3rd country Consultants and Consulting 3
R Quality System Implementation Starting from the Beginning ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 19
D ISO 9001 - Hierarchy List of Procedures Starting with the Quality Policy ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 3
A Establish a New Quality System based on Lean - Starting A Late Career in Quality Lean in Manufacturing and Service Industries 7
C Career Change Question - Why did you choose Quality Engineer as starting job? Career and Occupation Discussions 3
L Just starting Quality and ISO 9000 - Not even a Quality Manual ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 12
J Starting a Weibull Analysis: Source on how to perform Weibull Reliability Analysis - Predictions, Testing and Standards 2
S Starting an ISO 41001:2018 Facility management system Other ISO and International Standards and European Regulations 3
Marc Goldsmiths University will take beef products off the menu starting in September 2019 Sustainability, Green Initiatives and Ecology 19
J Starting from scratch - a plethora of challenges for a new Lumber Mill Machine Shop Quality Management System (QMS) Manuals 11
supadrai ISO 27000 - Starting from Scratch for a Smallish Law Firm IEC 27001 - Information Security Management Systems (ISMS) 4
Q Presentation for Employees - Starting the ISO 9001:2015 Transition ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 2
J Starting from the factory floor get any respect? Coffee Break and Water Cooler Discussions 13
C FMEA Starting point FMEA and Control Plans 7
L Starting an Internal Audit - Help with the basics Internal Auditing 12
M Contract Manufacturer 510K Starting Point 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 13
L Hand-starting threaded fasteners Benchmarking 3
M Starting out toward compliance Imported Legacy Blogs 0
B Starting a small boutique and looking for business ideas Career and Occupation Discussions 8
M Starting ISO 17025 Accreditation from scratch - Petroleum Laboratory ISO 17025 related Discussions 3
N Overwhelmed starting a new aviation related business AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 19
O Aerospace Registrar Problems - Starting Over? AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 13
Jen Kirley Starting Something New Career and Occupation Discussions 104
bobdoering Finally, evidence that people are starting to care about Apple computers After Work and Weekend Discussion Topics 7
E Starting Nadcap Accreditation and making an Implementation Timeline AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 2
T Document Control Revision - Starting Over Document Control Systems, Procedures, Forms and Templates 1
Q How raise en ECO starting from a NC - ECO after NCR? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 8
B Template for starting up new manufacturing facility in our company AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 9
A Starting Supplier Management System in a Company Supplier Quality Assurance and other Supplier Issues 4
K Starting a new Calibration and Repair Laboratory General Measurement Device and Calibration Topics 15
B Starting a business in Dubai Career and Occupation Discussions 1
B Implementing APQP - Starting a fresh.... APQP and PPAP 6
R ANSI Z1.9 AQL 0.4 - What are the starting equipment expectations? Inspection, Prints (Drawings), Testing, Sampling and Related Topics 3
K Starting an ISO 17025 Accredited Laboratory ISO 17025 related Discussions 15
M Petrol (Gasoline) Prices Around the World - Part Trois Starting January 2011 Coffee Break and Water Cooler Discussions 25
C Starting an MSA study - How to decide which is appropriate or required Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 2
Ajit Basrur Starting Sustainability Initiatives in our Organization Sustainability, Green Initiatives and Ecology 15
C Rebuilding the QMS - What is a good starting point? Quality Manager and Management Related Issues 13
Z Long Term Measurement Logging for Machine Shop - Starting with a clean slate Statistical Analysis Tools, Techniques and SPC 3
S Starting up a new Calibration Laboratory General Measurement Device and Calibration Topics 18
A Starting the journey (ISO 9000 awareness) ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 2
