Starting from scratch - a plethora of challenges for a new Lumber Mill Machine Shop
jjmusicjr
This will be by first post among many I'm sure. I've been in the manufacturing trades for over 40 years. Automotive R&D for 30 years, Aerospace for 10 years, and now I'm in the lumber industry setting up a Quality System for a ground-floor CNC Machine shop that will provide replacement parts to said lumber mill company and all of its divisions. Needless to say, it's a daunting endeavor and I feel that I may be over my head at times.
The management here has not given me any guidelines, other than, "get it done," which is a bit of a foreign concept to me having come out of two previously heavily-regulated industries. So far, I don't see the need for us to be ISO 9001 certified, since (at least for now) we are only providing parts to internal customers. However, the owner's long-term vision for us will be to eventually be an OEM supplier to other lumber companies.
Right now, I have two questions, one vague, and one specific:
1) I'm trying to set up a QMS from scratch. The lumber company itself has quality standards for the end product, however, I can't find anything to suggest that the machines that I'm supplying parts for are controlled. That leaves me with setting up the QA/QC policies. Up to this point, I've not met anyone that has any experience in the QA/QC side of things until myself. So, I'm reaching out for assistance and suggestions on how to get started.
2) The discussion came up yesterday regarding First Article Inspections, and the requirements and frequency of them. In my experience with AS9100/9102, a FAI was performed on the first part of a new design, program change, fixture change, etc. After that PCD's were used to control the manufacturing process until another even happened that would require another FAI, or Delta FAI. The debate happened when the shop floor supervisor said that he was under the impression that a FAI was required on EVERY production run. When I tried to explain that there is no reason to do a full FAI, and just use the PCD's, he had to agree-to-disagree. Ultimately I believe I can resolve this with an in-process inspection form that goes with every job/part once a "real" FAI has been accomplished. My question to you : Are there different FAI requirements that I'm not aware of? Are FAI requirements only related to AS9100?
Thank-you in advance for your assistance.
Al Rosen
What is "PCD"?
I believe the shop floor supervisor is referring to a first piece inspection to verify the setup of the machine prior to running the job.
Eredhel
Quality Manager
I think you're thought process is on the right track, but remember that the standards, even AS9100, don't necessarily get that specific. A lot is left up to the organization to decide on how they want to fulfill things. I say that because you don't want to build for the standard but rather build for the context of your organization. Yes you can trim fat, but find out what the organization is and needs first.
I know shops that require a full first part inspection at every shift change, no matter what. Well that makes for a lot of machinists standing around waiting on the 1 inspector you might have to get to them. We only use the AS9102 first articles when the customer requires them (AS9100 doesn't require the forms specifically btw). Those forms just add way too much cost, especially time, for normal day to day use. We still check and document every dimension but we use our own inspection forms that include header information, 100% dimensional documentation, outside process checks, and sample verification. We even require it for each work order we run, but only once. So if they're running 1,000 parts over a week they only have to wait on a first article one time, regardless of shift changes. But we also do random in process inspections all day every day and each time one is done it gets documented on the work order's inspection form, not re-writing every dimension just hash marks for a sample being done. So our sample gets met and the majority of issues are caught in process. Although if most of the jobs we ran were low quantities we'd probably have to adjust that.
I'm only saying all that to give you some examples, there are a lot of ways to get things done. But I would start by getting with top management and getting more specific on what the organization is trying to do. There are a lot of standard practices you can implement but who knows maybe as an organization you need to bulk up more than is actually necessary here and there.
jjmusicjr
What is "PCD"?
Hello Al, a "PCD" is a Process Control Dimension. I view these dimensions as things that need to be checked on every part--things that can be affected by tooling changes, setup changes, etc. An example would be wall thicknesses, hole diameters/depths, etc. The PCD's can number from a few, to many depending on the complexity of the program and number of setup operations.
jjmusicjr
Thanks for the input Eredhel, I was able to find a Quality Manager of one of the mills that we service as an internal customer. I'm hoping that he can provide me some of that information that I seek.
As for the AS9102 forms, I know what you mean in that they can create a lot of unnecessary expense, just due to the redundancy of some of the documentation. I think I can achieve that with a simplified version of the form that I applied to the aerospace company that I previously worked at. The production run quantities that we are going to be running are closer to 1-5 pcs, with the occasional 40-50 part run for some close-tolerance parts.
This is all good advice. Thanks
jjmusicjr
Overall thicknesses of ±.0005", then of course there is hard-anodizing after that.
Eredhel
Quality Manager
Gotcha, so close tolerances on low quantity runs. I was just getting my head around it more in case other questions came up that I wanted to give feedback on.
Cari Spears
Hi, jj.
I'm confused about why a supplier of replacement parts to a lumber mill would have to comply with aerospace FAI? I'm thinking the same as Al - is someone saying FAI when they mean FPA (First Piece Approval)?
Eredhel
Quality Manager
Btw that's a great point. Where I currently work everyone says FAI when they're talking about FPI (first part inspections). Can definitely lead to some communication issues.
supadrai ISO 27000 - Starting from Scratch for a Smallish Law Firm IEC 27001 - Information Security Management Systems (ISMS) 4
C Starting a Quality Department from Scratch and Implementing ISO 9001 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 32
M Starting ISO 17025 Accreditation from scratch - Petroleum Laboratory ISO 17025 related Discussions 3
H ISO 9001 Implementation - Starting From Scratch ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 7
GStough Suppliers Starting to Charge A Fee for Customer Audits Supplier Quality Assurance and other Supplier Issues 14
R Starting an automotive containment business Service Industry Specific Topics 3
H Starting my own 3rd party inspection company Service Industry Specific Topics 6
qualprod Setup time only at starting production? Lean in Manufacturing and Service Industries 5
J Starting a Weibull Analysis: Source on how to perform Weibull Reliability Analysis - Predictions, Testing and Standards 2
S Starting an ISO 41001:2018 Facility management system Other ISO and International Standards and European Regulations 3
Marc Goldsmiths University will take beef products off the menu starting in September 2019 Sustainability, Green Initiatives and Ecology 19
J Implementation of Total Quality Management/Starting a Quality Department Reliability Analysis - Predictions, Testing and Standards 9
Q Presentation for Employees - Starting the ISO 9001:2015 Transition ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 2
C I'm starting my Career in Quality Assurance Career and Occupation Discussions 8
J Starting from the factory floor get any respect? Coffee Break and Water Cooler Discussions 13
C FMEA Starting point FMEA and Control Plans 7
L Starting an Internal Audit - Help with the basics Internal Auditing 12
M Contract Manufacturer 510K Starting Point 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 13
L Hand-starting threaded fasteners Benchmarking 3
D Just starting out looking to get into a quality engineer position Career and Occupation Discussions 2
M Starting out toward compliance Imported Legacy Blogs 0
B Starting a small boutique and looking for business ideas Career and Occupation Discussions 8
N Overwhelmed starting a new aviation related business AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 19
O Aerospace Registrar Problems - Starting Over? AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 13
Jen Kirley Starting Something New Career and Occupation Discussions 104
bobdoering Finally, evidence that people are starting to care about Apple computers After Work and Weekend Discussion Topics 7
M Implementing a Quality System - Just starting out..... in over my head. Quality Tools, Improvement and Analysis 12
E Starting Nadcap Accreditation and making an Implementation Timeline AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 2
F Starting a Quality Control Program and writing a Quality Control Manual Quality Manager and Management Related Issues 10
T Document Control Revision - Starting Over Document Control Systems, Procedures, Forms and Templates 1
Q How raise en ECO starting from a NC - ECO after NCR? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 8
B Template for starting up new manufacturing facility in our company AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 9
A Starting Supplier Management System in a Company Supplier Quality Assurance and other Supplier Issues 4
K Starting a new Calibration and Repair Laboratory General Measurement Device and Calibration Topics 15
B Starting a business in Dubai Career and Occupation Discussions 1
B Implementing APQP - Starting a fresh.... APQP and PPAP 6
R ANSI Z1.9 AQL 0.4 - What are the starting equipment expectations? Inspection, Prints (Drawings), Testing, Sampling and Related Topics 3
K Starting an ISO 17025 Accredited Laboratory ISO 17025 related Discussions 15
M Petrol (Gasoline) Prices Around the World - Part Trois Starting January 2011 Coffee Break and Water Cooler Discussions 25
C Starting an MSA study - How to decide which is appropriate or required Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 2
R Starting In-Process Quality Inspection in the Production Shopfloor Inspection, Prints (Drawings), Testing, Sampling and Related Topics 13
Ajit Basrur Starting Sustainability Initiatives in our Organization Sustainability, Green Initiatives and Ecology 15
C Rebuilding the QMS - What is a good starting point? Quality Manager and Management Related Issues 13
Z Long Term Measurement Logging for Machine Shop - Starting with a clean slate Statistical Analysis Tools, Techniques and SPC 3
E Starting to write a Quality System Manual - Import/export medical devices - Need help ISO 13485:2016 - Medical Device Quality Management Systems 1
S Starting up a new Calibration Laboratory General Measurement Device and Calibration Topics 18
B Starting a new Quality System ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 17
A Starting the journey (ISO 9000 awareness) ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 2
T CE Marking regulation of construction products starting on January 2009 CE Marking (Conformité Européene) / CB Scheme 4
B Tips for JUMP STARTING Job/Career Search? Career and Occupation Discussions 8
