Statistical Analysis of Road Traffic Data
Y
yasharif
I have a database:
Interstate ADT(avg daily traffic) IRL 1yrRL 2ndyrRL...5thyrRL
I-95 15000-25000 800 750 650 340
I-95 is a highway where average daily traffic is from 15000-25000. The roadmarking or roadsign that were put initially to guide the car/driver at nighttime had IRL(initial retro reflective number) of 800 and the material was polyurea. It can be thermo or paint also. Then an instrument is used and the reading of the roadmarking taken a year later and found 750 and then the later years 650,340...and son on may be upto 7th year.
I developed an exponential degradation model from the database but does not look satisfactory to my BOSS.
Now my goal is to find the cost effectiveness of these materials.
Is there any otherway you can suggest or advice me..
Thank you once again.
Regards
Sharif
Steve Prevette
Deming Disciple
Seems like a fairly straight forward analysis. Is the IRL a linear, measured quantity, or a subjective scoring?
Y
yasharif
No it does not seem to me linear.
There are 3 materials for roadway marking : polyurea, thermo and paint.
The first marking that is put is measured and that is called initial retroreflective number. And then the other readings are taken at 6 months, 1 yr, 2 yr, 3 yr, 4yr and 5 yr.
The minimum retroreflective number to be valid for the materials are with a standard number.
Polyurea (white): 800
Polyurea (yellow): 500
Thermo (white): 375
Thermo (yellow): 250
Paint (white): 225
Paint (yellow): 200
Now a sample :
US 17 route: Polyurea
(initial) (6month) (1yr) (2yr) (3yr) (4yr)
White: (629) (490) (478) (368) (324) (No data available)
Yellow: (517) (450) (390) (326) (272) (No data available)
there are several routes like this for intertate, primary and secondary.
This is just a sample.
I am trying to find an equation (linear/exponential) that will predict the retroreflective number after 10 years.
Any suggestions will be appreciated.
Thank you very much.
Regards
Sharif
P
PaulJSmith
I suspect there is more to consider in your equation; such as how each of those materials are affected by environment (heat, cold, moisture, sunlight, etc.). You may need data from many different areas, which may give you results that vary by region/climate. I doubt it will be as simple as using just one generic formula.
Y
yasharif
Thanks for your reply.
I know that it might have the temperature and environmental effect but still trying to avoid those parameters to make the equation simplified.
What would be better approach?
Thanks.
Steve Prevette
Deming Disciple
How many different combinations of location, material, and other factors are there? Are there enough replications in a given data set to do a non-parametric analysis (the score changes by this much first year, second year, etc).
If you are talking US 17 and I-95, you must be in the Southeast . . . I live in South Carolina. Are the data in some sort of database or spreadsheet?
Steve Prevette
Deming Disciple
Also, how is the IRL measured? What does the number mean? Are we talking road signs or highway markings or both? Is the road sign have surface grime removed from it prior to taking the reading?
I assume that IRL once lost cannot be recovered (a later year's measurement can never be higher than the previous year's), correct?
Before these data were collected, was there any plan as to how to analyze the resulting data?
Y
yasharif
RL-retroreflective numbers are measured through an instrument.
The road surface asphalt/concrete are made clear and then the material(Polyurea/ Thermo/ Paint) is put at 40F temperature on the Road Surface to guide the driver.
The number basically means for instance HOW MUCH REFLECTION THE MATERIAL CAN create to the drivers eye for the visibility in day and specially at night time.(Like as right arrows, left arrows, straight arrows, edge line to prevent the driver to go off the road , yellow centre line to keep the 2 way system separate and consistent..etc)
Yes the number starts getting down after the road surface is being painted with polyurea/thermo or paint due to specially cars tire abrasion and many more things. They cant be recovered unless the road surface is painted with those material again.
No, there was no plan to analyze the data before collecting these data. I wish a DOE was done before measuring these RL. If there was a design matrix it would have been easier.
Do you have any suggestion?
Any mathematical/statistical model might give me a solution.
I am basically trying to figure out the cost/benefit ratio of those materials.
But before that I need a model to introduce which can predict the final RL after a certain year which will give me the result for cost analysis of those 3 materials..
Thank you very much for your quick reply.
Regards
Sharif
Steve Prevette
Deming Disciple
Without seeing the entirety of the data it is hard to see what to do, but here (in the blind) is what I would do:
For each family of data, calculate the percent reduction in the score from time 0 to year 1; year 1 to year 2; year 2 to year 3; etc. Then I would start examining if the error within a group fits the binomial distribution (p-chart control limits). Then look across the years to determine if the percentage reduction changes year to year. If all of these subgroups of percentage reductions are within binomial limits, then that would say there is a predictable reduction each year.
If the percent reduction is NOT stable year to year, then start looking across the different families of data to see if there is a consistent pattern to the percent reductions.
Depending on how all this goes, one should be able to come up with a IRL reduction curve versus time, with confidence limits and prediction limits.
Y
yasharif
Thanks for your quick reply.
I used to live in columbia,sc. I completed my graduation and moved to NC.
Yes, there are lots of parameters.
I am just giving one snapshot of the data I am considering for analysis. Its a huge large database.
I am trying to simplify the database with lowest parameters like ADT, Material color and Initial RL.
Problem is , the party who was engaged in collecting or measuring the data dint do their job properly. They did not collect the data properly. Sometimes they did not collect the data at the beginning and all on a sudden they are showing the data of Rl for a year later and onwards.
Although the chart has shows the column upto 9yrs but they only have data upto 4 or 3 yrs...!!
I developed an exponential equation but still was looking for something better or may be a new approach to model or develop an equation.
Thanks.
S How to perform verification of the Statistical Analysis Software? Qualification and Validation (including 21 CFR Part 11) 7
A Statistical Analysis - Check if these organisms at different concentrations affect the growth of wheat seedlings Using Minitab Software 4
J Capability Analysis - Unusual Statistical Distribution of my Proccess Capability, Accuracy and Stability - Processes, Machines, etc. 5
M PhD Thesis Data Statistical Analysis Methods Statistical Analysis Tools, Techniques and SPC 2
S Minitab and Crystal Ball Statistical Analysis Software Using Minitab Software 13
J Applicable Statistical Analysis Method for this Data Six Sigma 17
C Statistical Analysis to Demonstrate Substantial Equivalence to the FDA Other US Medical Device Regulations 5
I SPC Statistical Analysis in Metrology General Measurement Device and Calibration Topics 2
A What is Monte Carlo Simulation / Distribution in Statistical Analysis? Statistical Analysis Tools, Techniques and SPC 19
C Applying Statistical Analysis Methods to Work Safety Occupational Health & Safety Management Standards 3
S Statistical Analysis of Survey Results Quality Tools, Improvement and Analysis 8
H What is 99/90 Statistical Analysis Statistical Analysis Tools, Techniques and SPC 4
I Using validated SAS JMP to validate Excel for Statistical Analysis? Qualification and Validation (including 21 CFR Part 11) 11
O What Statistical Analysis Technique to use for Batches? Statistical Analysis Tools, Techniques and SPC 6
P Warranty Statistical Analysis in a Manufacturing Company Quality Tools, Improvement and Analysis 1
B Appropriate Statistical Analysis Technique question Statistical Analysis Tools, Techniques and SPC 4
smryan Count by weight statistical analysis Quality Tools, Improvement and Analysis 24
M SPC (Statistical Process Control) analysis and status on two manufacturing plants Statistical Analysis Tools, Techniques and SPC 4
B Statistical Analysis SPC Trend explanation needed Statistical Analysis Tools, Techniques and SPC 4
R Statistical Analysis Problem - Pooling Information for 8 Hour Shifts Statistical Analysis Tools, Techniques and SPC 5
C Statistical Analysis during Document Audit US Food and Drug Administration (FDA) 8
C Statistical Analysis of all Key Processes Statistical Analysis Tools, Techniques and SPC 1
M Statistical Analysis in Low Quantity Production of 10 to 20 products each year Six Sigma 4
antoine.dias Definition Rv and RvK in Statistical Analysis - Inner diameter between the bearing rollers Definitions, Acronyms, Abbreviations and Interpretations Listed Alphabetically 1
J Software Validation - SigmaStat for Statistical Analysis ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 3
samer Statistical Analysis for Sales Process? Can you help? Statistical Analysis Tools, Techniques and SPC 11
J Statistical Data Analysis - How to satisfy ISO 9001 : 2000, Clause 8 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 4
Q Teaching Executives about the Benefits of Statistical Analysis and Problem-solving Training - Internal, External, Online and Distance Learning 20
A Shainin vs. Fisher vs. Taguchi DOE (Design of Experiments) Statistical Analysis Quality Tools, Improvement and Analysis 10
Y Statistical Analysis applications in Human Resources Statistical Analysis Tools, Techniques and SPC 8
S Statistical Process Control and the need for Measurement System Analysis (Gage R&R) Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 5
R Analysis of Data - The former "Statistical Techniques" procedure ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 4
T Any recommendation on DOE/Statistical Analysis Software? Statistical Analysis Tools, Techniques and SPC 1
PQ Systems Better Data Visualization & Communication with Statistical Indices Using SQCpack Software 0
R Statistical Methods for comparing test and reference product equivalence for quality attributes US Food and Drug Administration (FDA) 3
S MSA clause 7.1.5.1.1 - Statistical studies on counting weight scale Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 12
Bev D Statistical Alchemy Misc. Quality Assurance and Business Systems Related Topics 1
K Looking for guidance to write an SOP on Statistical Methodologies? Statistical Analysis Tools, Techniques and SPC 7
M Minimum sample size - Guidance and statistical rationale Inspection, Prints (Drawings), Testing, Sampling and Related Topics 3
N Design Verification & Process Validation - Statistical sample sizes Design and Development of Products and Processes 2
John Predmore Interactive visualization through graphical simulation of statistical concepts Statistical Analysis Tools, Techniques and SPC 3
Bev D Profound Statistical Concepts Misc. Quality Assurance and Business Systems Related Topics 63
H Statistical Techniques Procedure - What should be included Document Control Systems, Procedures, Forms and Templates 4
O Statistical justification of sampling size in V&V tests ISO 13485:2016 - Medical Device Quality Management Systems 5
optomist1 It’s time to talk about ditching statistical significance Statistical Analysis Tools, Techniques and SPC 6
Marc Steve Prevette's Statistical Process Control (SPC) "Library" Statistical Analysis Tools, Techniques and SPC 0
John Predmore A Balanced view of statistical tests Statistical Analysis Tools, Techniques and SPC 3
V Statistical basis and justification while comparing / changing sampling plans Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 11
S SPC (Statistical Process Control) for Unilateral Tolerance - Questions Statistical Analysis Tools, Techniques and SPC 6
