Statistical basis for 30 pieces for FAI
ScottK
Not out of the crisis
Came up in a conversation today...
What is the statistical basis for a 30 piece sample when doing FAI on medical devices... it seems that is the standard across many of the large customers I've served in the past (Stryker, Medtronic, Zimmer/Biomet, J&J, BD, Cardinal, etc...)
Wondering where this came from. At some point in my distant past I was given the statistics behind this but that's long lost...
optomist1
A Sea of Statistics
here's a bit of info re: sample size, this is independent of industry....there is much more to this...choosing sample size...type I/II errors...if you're using Minitab the tutorial re: "Power and Sample Size" is good. Thirty (30) pieces is used across many fields...
Sampling – the greater the sample size the better the probability of detecting differences in data groups means etc, this applies to anova, t-test and doe replication as well, replication increases the degrees of freedom, reduces beta errors and increases the ability to detect differences. Small sample size gives high beta errors and harder to detect differences.
This scratches the surface, hope it helps...optomist1
I agree this is somewhat independent of industry. When I first started in automotive quality (back in the 80s), the required sample size was 30. In the 90s, it became 50, then rapidly changed to 100.
See the attached graphs for an example of how the confidence limits for the mean and the standard deviation decrease with sample size. While 30 or 50 might be reasonable for the mean OR the standard deviation, when you combine them into the Cp/Cpk indices, the confidence limits for the index become very large until you reach a sample size of 100. The automotive industry learned this the hard way when suppliers reported good capability, but the actual performance was far worse.
The history behind most of these practices was an economic balance between the cost of collecting the data and the cost of being wrong.
And when I was in the aircraft engines business the sample size was 1. I always thought that was silly for various reasons. 30, 50, 100 are the base sample sizes for capability studies so I guess that’s the intent.
nozzle
The last company I worked for in the medical devices sector required a FAI on one piece and then measurements of CTQ dimensions on 32 pieces to determine the process capability.
The FDA accepted this approach as the CTQ dimensions were identified as the highest risk.
The justification, as I originally heard it many years ago, was that after 30 pieces randomly selected, the difference between the population standard deviation and the sample standard deviation becomes insignificant for practical purposes. In other words, if the sample of 30 is truly random (which almost never happens) you will allegedly get roughly the same information as you would if the entire population were measured.
ScottK
That's ringing a bell.
Funny thing most of the time I've done this the populations is very small... a typical order size would be 20 every 6 months, for example.
So the qualification lot would often be bigger than a normal order.
But I guess that comes from working much of my career in high variety, small lot size business.
dwperron
I had always been taught that 30 was the dividing point for the sample size. Above 30 you could use z distribution, below 30 you used Student-t distribution.
Below 30 was considered a small sample size.
V Statistical basis and justification while comparing / changing sampling plans Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 11
Scott Catron Statistical basis for square-root sampling Inspection, Prints (Drawings), Testing, Sampling and Related Topics 11
S MSA clause 7.1.5.1.1 - Statistical studies on counting weight scale IATF 16949 - Automotive Quality Systems Standard 4
S How to perform verification of the Statistical Analysis Software? Qualification and Validation (including 21 CFR Part 11) 3
Bev D Statistical Alchemy Misc. Quality Assurance and Business Systems Related Topics 1
K Looking for guidance to write an SOP on Statistical Methodologies? Statistical Analysis Tools, Techniques and SPC 7
M Minimum sample size - Guidance and statistical rationale Inspection, Prints (Drawings), Testing, Sampling and Related Topics 3
N Design Verification & Process Validation - Statistical sample sizes Design and Development of Products and Processes 2
John Predmore Interactive visualization through graphical simulation of statistical concepts Statistical Analysis Tools, Techniques and SPC 3
Bev D Profound Statistical Concepts Misc. Quality Assurance and Business Systems Related Topics 63
A Statistical Analysis - Check if these organisms at different concentrations affect the growth of wheat seedlings Using Minitab Software 4
H Statistical Techniques Procedure - What should be included Document Control Systems, Procedures, Forms and Templates 4
O Statistical justification of sampling size in V&V tests ISO 13485:2016 - Medical Device Quality Management Systems 5
optomist1 It’s time to talk about ditching statistical significance Statistical Analysis Tools, Techniques and SPC 6
Marc Steve Prevette's Statistical Process Control (SPC) "Library" Statistical Analysis Tools, Techniques and SPC 0
John Predmore A Balanced view of statistical tests Statistical Analysis Tools, Techniques and SPC 3
S SPC (Statistical Process Control) for Unilateral Tolerance - Questions Statistical Analysis Tools, Techniques and SPC 6
S IATF 16949 9.1.1.3 Application of statistical concepts - Our technicians are quizzed for statistical knowledge IATF 16949 - Automotive Quality Systems Standard 3
K Please help identify appropriate statistical treatment Statistical Analysis Tools, Techniques and SPC 13
B IATF 16949 clause 7.1.5.1.1 - Statistical studies shall be conducted IATF 16949 - Automotive Quality Systems Standard 3
A Statistical Process Control and Inspection in Footwear Production Statistical Analysis Tools, Techniques and SPC 0
M IATF 16949 Cl. 7.1.5.1.1 - Statistical studies shall be conducted IATF 16949 - Automotive Quality Systems Standard 3
Steve Prevette Statistical Process Control Library Statistical Analysis Tools, Techniques and SPC 17
Marc Happy Birthday Statistical Steven - 2015 Covegratulations 10
L When are Statistical techniques not applicable? Service Industry Specific Topics 16
M FDA 21 CFR 820.250 - Does "valid statistical" always mean math? 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 6
R Common Statistical Errors Using Minitab Software 1
Y Statistical Analysis of Road Traffic Data Statistical Analysis Tools, Techniques and SPC 11
B Class II Medical Device Manufacturer - SOP for 820.250 Statistical 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 3
E Correct Statistical Test comparing 2 Groups Statistical Analysis Tools, Techniques and SPC 14
A Statistical Software Calibration using Ford's "Sample Calibration File" Statistical Analysis Tools, Techniques and SPC 8
J Defining Martial Arts and Gymnastics Statistical Techniques Statistical Analysis Tools, Techniques and SPC 4
J Capability Analysis - Unusual Statistical Distribution of my Proccess Capability, Accuracy and Stability - Processes, Machines, etc. 5
M PhD Thesis Data Statistical Analysis Methods Statistical Analysis Tools, Techniques and SPC 2
J Statistical Significance and SPC Control Chart Reports Statistical Analysis Tools, Techniques and SPC 9
N Statistical Quality Improvement Action for Small Batch Production Statistical Analysis Tools, Techniques and SPC 17
V Validation of macro - scripts - programs used in statistical software (Minitab-SAS... Qualification and Validation (including 21 CFR Part 11) 5
Moncia Statistical Process Control Crash Course - Question Quality Manager and Management Related Issues 10
H Statistical Models for Predictive Management of Software Processes Software Quality Assurance 2
A Statistical Correlation between ordered SKUs Statistical Analysis Tools, Techniques and SPC 8
S Minitab and Crystal Ball Statistical Analysis Software Using Minitab Software 13
M Determining if two different X's have any Statistical Significance on the Y's Statistical Analysis Tools, Techniques and SPC 4
I Statistical Stability for the PQ of Analytical Equipment Qualification and Validation (including 21 CFR Part 11) 1
F Statistical Comparison of Product: High Average vs. Low Range Capability, Accuracy and Stability - Processes, Machines, etc. 13
E Using ANOVA during the PQ Validation Run to evaluate Statistical Differences Statistical Analysis Tools, Techniques and SPC 4
W Gage R&R for gage pins used to inspect a hole ID called a Statistical Tolerance Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 3
B AS 9100C sec 8.2.4 - " Recognized Statistical Principles" meaning AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 7
R What is PSW - Statistical Process Package + Level 5 APQP and PPAP 7
O Is SPC (Statistical Process Control) always required? Statistical Analysis Tools, Techniques and SPC 4
