Statistical Models (Sigma - Restricted Vs Over- parameterized parameterisation)
F
fed-up
Hi
Can some1 please explain to me what is meant by sigma-restricted parameterization and over-parameterized parameterization?
the only information i could find on this is the following. But it didnt make any sense to me. Any help would be greatly appreciated. Thanks
Sigma Restricted Model. A sigma restricted model uses the sigma-restricted coding to represent effects for categorical predictor variables in general linear models and generalized linear models. To illustrate the sigma-restricted coding, suppose that a categorical predictor variable called Gender has two levels (i.e., male and female). Cases in the two groups would be assigned values of 1 or -1, respectively, on the coded predictor variable, so that if the regression coefficient for the variable is positive, the group coded as 1 on the predictor variable will have a higher predicted value (i.e., a higher group mean) on the dependent variable, and if the regression coefficient is negative, the group coded as -1 on the predictor variable will have a higher predicted value on the dependent variable. This coding strategy is aptly called the sigma-restricted parameterization, because the values used to represent group membership (1 and -1) sum to zero.
Overparameterized Model. An overparameterized model uses the indicator variable approach to represent effects for categorical predictor variables in general linear models and generalized linear models. To illustrate indicator variable coding, suppose that a categorical predictor variable called Gender has two levels (i.e., Male and Female). A separate continuous predictor variable would be coded for each group identified by the categorical predictor variable. Females might be assigned a value of 1 and males a value of 0 on a first predictor variable identifying membership in the female Gender group, and males would then be assigned a value of 1 and females a value of 0 on a second predictor variable identifying membership in the male Gender group.
Statistical Steven
Statistician
Hi
Not sure if you are looking for a theoretical answer or just the impact on the analysis. I will give you a little of both. The predictive nature of the different models are identical assuming the sigma restricted parameterization sums to zero. In other words, if you had three levels of a categorical level, you would need to use 1, 0 and -1. In the overparameterization you create excessive parameters because each level for the categorical factor becomes its own factor. This requires one extra degree of freedom in the model, so usually you get that DF back by fitting a non-intercept model (not sure why theoretically, but it seems to work).
I tend to use the sigma restricted because the model is easier to explain.
Not sure I helped any :)
H Statistical Models for Predictive Management of Software Processes Software Quality Assurance 2
Marc SPC (statistical process control) charts and SD (System Dynamics) models Preventive Action and Continuous Improvement 18
S How to perform verification of the Statistical Analysis Software? Qualification and Validation (including 21 CFR Part 11) 2
Bev D Statistical Alchemy Misc. Quality Assurance and Business Systems Related Topics 1
K Looking for guidance to write an SOP on Statistical Methodologies? Statistical Analysis Tools, Techniques and SPC 7
M Minimum sample size - Guidance and statistical rationale Inspection, Prints (Drawings), Testing, Sampling and Related Topics 3
N Design Verification & Process Validation - Statistical sample sizes Design and Development of Products and Processes 2
John Predmore Interactive visualization through graphical simulation of statistical concepts Statistical Analysis Tools, Techniques and SPC 3
Bev D Profound Statistical Concepts Misc. Quality Assurance and Business Systems Related Topics 63
A Statistical Analysis - Check if these organisms at different concentrations affect the growth of wheat seedlings Using Minitab Software 4
H Statistical Techniques Procedure - What should be included Document Control Systems, Procedures, Forms and Templates 4
O Statistical justification of sampling size in V&V tests ISO 13485:2016 - Medical Device Quality Management Systems 5
optomist1 It’s time to talk about ditching statistical significance Statistical Analysis Tools, Techniques and SPC 6
Marc Steve Prevette's Statistical Process Control (SPC) "Library" Statistical Analysis Tools, Techniques and SPC 0
John Predmore A Balanced view of statistical tests Statistical Analysis Tools, Techniques and SPC 3
V Statistical basis and justification while comparing / changing sampling plans Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 11
S SPC (Statistical Process Control) for Unilateral Tolerance - Questions Statistical Analysis Tools, Techniques and SPC 6
S IATF 16949 9.1.1.3 Application of statistical concepts - Our technicians are quizzed for statistical knowledge IATF 16949 - Automotive Quality Systems Standard 3
K Please help identify appropriate statistical treatment Statistical Analysis Tools, Techniques and SPC 13
ScottK Statistical basis for 30 pieces for FAI 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 7
B IATF 16949 clause 7.1.5.1.1 - Statistical studies shall be conducted IATF 16949 - Automotive Quality Systems Standard 3
A Statistical Process Control and Inspection in Footwear Production Statistical Analysis Tools, Techniques and SPC 0
M IATF 16949 Cl. 7.1.5.1.1 - Statistical studies shall be conducted IATF 16949 - Automotive Quality Systems Standard 3
Steve Prevette Statistical Process Control Library Statistical Analysis Tools, Techniques and SPC 17
Marc Happy Birthday Statistical Steven - 2015 Covegratulations 10
L When are Statistical techniques not applicable? Service Industry Specific Topics 16
M FDA 21 CFR 820.250 - Does "valid statistical" always mean math? 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 6
R Common Statistical Errors Using Minitab Software 1
Y Statistical Analysis of Road Traffic Data Statistical Analysis Tools, Techniques and SPC 11
B Class II Medical Device Manufacturer - SOP for 820.250 Statistical 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 3
E Correct Statistical Test comparing 2 Groups Statistical Analysis Tools, Techniques and SPC 14
A Statistical Software Calibration using Ford's "Sample Calibration File" Statistical Analysis Tools, Techniques and SPC 8
J Defining Martial Arts and Gymnastics Statistical Techniques Statistical Analysis Tools, Techniques and SPC 4
J Capability Analysis - Unusual Statistical Distribution of my Proccess Capability, Accuracy and Stability - Processes, Machines, etc. 5
M PhD Thesis Data Statistical Analysis Methods Statistical Analysis Tools, Techniques and SPC 2
J Statistical Significance and SPC Control Chart Reports Statistical Analysis Tools, Techniques and SPC 9
N Statistical Quality Improvement Action for Small Batch Production Statistical Analysis Tools, Techniques and SPC 17
V Validation of macro - scripts - programs used in statistical software (Minitab-SAS... Qualification and Validation (including 21 CFR Part 11) 5
Moncia Statistical Process Control Crash Course - Question Quality Manager and Management Related Issues 10
A Statistical Correlation between ordered SKUs Statistical Analysis Tools, Techniques and SPC 8
S Minitab and Crystal Ball Statistical Analysis Software Using Minitab Software 13
M Determining if two different X's have any Statistical Significance on the Y's Statistical Analysis Tools, Techniques and SPC 4
I Statistical Stability for the PQ of Analytical Equipment Qualification and Validation (including 21 CFR Part 11) 1
F Statistical Comparison of Product: High Average vs. Low Range Capability, Accuracy and Stability - Processes, Machines, etc. 13
E Using ANOVA during the PQ Validation Run to evaluate Statistical Differences Statistical Analysis Tools, Techniques and SPC 4
W Gage R&R for gage pins used to inspect a hole ID called a Statistical Tolerance Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 3
B AS 9100C sec 8.2.4 - " Recognized Statistical Principles" meaning AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 7
R What is PSW - Statistical Process Package + Level 5 APQP and PPAP 7
O Is SPC (Statistical Process Control) always required? Statistical Analysis Tools, Techniques and SPC 4
