Re: Statistical Process Control
Hello, my name is Juan,
My opinion on the matter is:
To my experience in statistical control of process I consider and e been able to observe in different processes, that the variation of the process is hit directly by the properties statistical that the measurement system has that is used. The analysis of the measurement system looks for:
1. to identify the suitable equipment, (depending the objective of the measurement, or to control the process by means of control graphs or simply to accept or to reject product) for the characteristic that is desired to measure and / or to control, for this task I apply the following principle, my equipment of measurement must cover the following aspects:
a.- He forms: The form of the measurement equipment must be adapted to its use (feasible, adaptable to the atmosphere where it was used).
b.-Exactitude: The measurement equipment must be able to detect but minimum variation of the process, a general rule says to you that your equipment must have a relation of 1/10 discrimination. That is your equipment must be able to detect one tenth part of the tolerance or variation of your process like minimum.
c. It reaches: When one works with electronic equipment, this recommendation is due to take care of that the reach or total rank of measurement of the equipment is a greater 20% to the maximum value of the characteristic to measure, is because when the equipment is exposed to greater measurements to 80% of their reach, they lose in gradual form the exactitude of the equipment
2.- To compare a system of measurement with another system of measurement
3.- To identify when the measurement systems begin to lose the exactitude that have
4 .- To assure that the statistical properties of the systems stay in you limit them allowed, after repair activities have been made or fits to the equipment of measurement
5.- To assure that the users of the equipment, has the ability adapted in the use of the equipment.
To very personal opinion, first it is required to evaluate if the equipment is the adapted one to measure the selected characteristic, before using it and but even though it is tried to use graphs of control in the process, since the capacity which you calculate for your process can not be the true one since you can be using an inadequate equipment, this is very dangerous and much to confusion is lent.
I hope helps this you, for something but detailed on the matter, send me a mail and we can chat more in detail on situations you specify......
