Statistical Significance and SPC Control Chart Reports
JAG2013
Hi all,
I've been working for a while with SPC and have a few questions. First of all, I monitor an X-bar - R chart for a process. The subgroup size is 6. I have setup alarms for out of control points and significant shift (8 points above or below the center line per WECO rules). First question, I've been told that when a shift is noticed a statistical analysis must be performed to determine if there is statistical significance. How should I calculate the statistical significance? Do I have to use an Anova to compare the 8 subgroups that cause the shift with the center line/average and determine statistical significance?
Another thing is that I prepare reports of the results of the control charts. For every alert/alarm triggered I have to generate a report. Also, on a weekly basis, I have to analyze the results and assign actions to improve the deficiencies. In addition, I have to prepare quarterly reports that should provide a summary of the alerts and alarms that occur during the quarter. Any recommendations in regards to how reporting should be done? Any templates for SPC control chart reporting I can look to have a reference? Seems I can report biweekly the SPC data and not quarterly, but how can I justify this?
What kinds of things are being measured, and how?
Who told you that, and what was the basis? To be honest, this sounds a little like Six Sigma Overkill?, but perhaps it's not. In general WECO and other "rules" are more like guidelines to tell you that something improbable is happening (or has happened) in the process. Improbable ≠ impossible, though. I'm not sure what statistical analysis is going to do for you. You need to see if you can identify the cause of what happened, if you can.
Tell us more about the process and the measurement.
JAG2013
Thanks for your reply Jim,
1.What kinds of things are being measured, and how?
I'm measuring the length of a device. It is measured with the aid of an Inspection Vision System.
I'm trying to establish a way to calculate the statistical significance if 8 points continously are above or below the center line. I know the 8 subgroups above or below the center line are address as a non-random pattern but how can I calculate whether that non-random pattern is significant? I have attached a control chart for reference.
Steve Prevette
Deming Disciple
1. There is no need nor desire in SPC to calculate statistical significance of a shift. I would agree that sounds like sick sigma hogwash. Dr Deming and Wheeler definitely point out that SPC is not an exercise in probability and it does not further learning to try to calculate levels of significance.
2. On display formats, take a look at http://www.efcog.org/wg/esh_es/Statistical_Process_Control/. One thing I do propose in that set of materials is a color coded scorecard based upon the SPC results.
This is nothing taught in Six Sigma (at least not by mainstream companies). We typically teach Nelson's Rules for Minitab users. WECO or AIAG rules are also common. It sounds like something said by someone that knows just enough to be dangerous.
Bill McNeese
There is no need to check the significant of the Western Electric patterns. The patterns do represent significant changes in the process. Someone does not understand what they are asking for.
But since you asked, the Western Electric Statistical Quality Control handbook does the give the probabilities for the various patterns. The eight above the average is easy to determine. It is simply .5^8 or 0.0039.
As far tracking signals, I would use a control strategy approach that provides a record for what was found for each out of control point as well as what was done. It is easy to set up on a computer. Here is a link on my web site of one such approach: http://www.spcforexcel.com/my-process-out-control-now-what-do-i-do
You need to include those closest to the process in this approach.
Just as a qualifier, it should be noted that the WECO "rules" are based on the underlying statistical assumptions being true, and the further away from those assumptions being true the process gets, the less reliable the rules become. In the OP's case, there is a chart posted that shows 19 of 25 points either at or below the mean, which means that there's something going on with the charting that renders the 8 points in a row mostly meaningless. It appears that there might have been a significant shift in the mean at some point and process wasn't adjusted or the mean and control limits weren't recalculated.
Darius
rules..., Wheeler put it into the article, I added in this post
Which rules must I apply for SPC
:2cents:As I see in your chart, this trend "problem", is common when the specs limits are to wide in compare to the variation of the process, a way to disminish this behabiur is to sample with less frequency, or don't take that as a problem.
bobdoering
Stop X-bar/R Madness!!
Here is the point of the "rules" with Shewhart charts. The assumption is that all special causes have been removed. That leaves a truly random "noise" (random variation of common causes) centered about a central value. If out of this noise arises anything that has "pattern", then it can no longer be deemed noise, and is evidence of a special cause. Common patterns observed are found in Western Electric rules, et. al. The cause must be identified and removed to get back to the common cause noise level.
The fundamental assumption is the process you are evaluating has a steady state of random noise with its particular common causes. Not all common causes behave in that manner, and if not Shewhart charts may not be appropriate.
those who have said that the person asking you to determine statistical significance doesn't understand SPC are correct. the limits - if properly calculated - and rules provide the statistical significance of the change. It will be around .3% to 5%. Donald Wheeler has many easy to read and informative articles at Quality Digest.
the 8 points you see are not a repeating pattern - at this point. however, it looks like it may be an anomaly of how the limits were calculated. it looks like the limits were calculated using all of the data present in the chart. limits should be calculated from a stable period and SET. points ar plotted against these limits in the future. limits are not supposed to be recalculated each time a new data point is entered.
Can you tell us how the limits are calculated and how you chose to subgroup the data?
optomist1 It’s time to talk about ditching statistical significance Statistical Analysis Tools, Techniques and SPC 6
M Determining if two different X's have any Statistical Significance on the Y's Statistical Analysis Tools, Techniques and SPC 4
S How to perform verification of the Statistical Analysis Software? Qualification and Validation (including 21 CFR Part 11) 2
Bev D Statistical Alchemy Misc. Quality Assurance and Business Systems Related Topics 1
K Looking for guidance to write an SOP on Statistical Methodologies? Statistical Analysis Tools, Techniques and SPC 7
M Minimum sample size - Guidance and statistical rationale Inspection, Prints (Drawings), Testing, Sampling and Related Topics 3
N Design Verification & Process Validation - Statistical sample sizes Design and Development of Products and Processes 2
John Predmore Interactive visualization through graphical simulation of statistical concepts Statistical Analysis Tools, Techniques and SPC 3
Bev D Profound Statistical Concepts Misc. Quality Assurance and Business Systems Related Topics 63
A Statistical Analysis - Check if these organisms at different concentrations affect the growth of wheat seedlings Using Minitab Software 4
H Statistical Techniques Procedure - What should be included Document Control Systems, Procedures, Forms and Templates 4
O Statistical justification of sampling size in V&V tests ISO 13485:2016 - Medical Device Quality Management Systems 5
Marc Steve Prevette's Statistical Process Control (SPC) "Library" Statistical Analysis Tools, Techniques and SPC 0
John Predmore A Balanced view of statistical tests Statistical Analysis Tools, Techniques and SPC 3
V Statistical basis and justification while comparing / changing sampling plans Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 11
S SPC (Statistical Process Control) for Unilateral Tolerance - Questions Statistical Analysis Tools, Techniques and SPC 6
S IATF 16949 9.1.1.3 Application of statistical concepts - Our technicians are quizzed for statistical knowledge IATF 16949 - Automotive Quality Systems Standard 3
K Please help identify appropriate statistical treatment Statistical Analysis Tools, Techniques and SPC 13
ScottK Statistical basis for 30 pieces for FAI 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 7
B IATF 16949 clause 7.1.5.1.1 - Statistical studies shall be conducted IATF 16949 - Automotive Quality Systems Standard 3
A Statistical Process Control and Inspection in Footwear Production Statistical Analysis Tools, Techniques and SPC 0
M IATF 16949 Cl. 7.1.5.1.1 - Statistical studies shall be conducted IATF 16949 - Automotive Quality Systems Standard 3
Steve Prevette Statistical Process Control Library Statistical Analysis Tools, Techniques and SPC 17
Marc Happy Birthday Statistical Steven - 2015 Covegratulations 10
L When are Statistical techniques not applicable? Service Industry Specific Topics 16
M FDA 21 CFR 820.250 - Does "valid statistical" always mean math? 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 6
R Common Statistical Errors Using Minitab Software 1
Y Statistical Analysis of Road Traffic Data Statistical Analysis Tools, Techniques and SPC 11
B Class II Medical Device Manufacturer - SOP for 820.250 Statistical 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 3
E Correct Statistical Test comparing 2 Groups Statistical Analysis Tools, Techniques and SPC 14
A Statistical Software Calibration using Ford's "Sample Calibration File" Statistical Analysis Tools, Techniques and SPC 8
J Defining Martial Arts and Gymnastics Statistical Techniques Statistical Analysis Tools, Techniques and SPC 4
J Capability Analysis - Unusual Statistical Distribution of my Proccess Capability, Accuracy and Stability - Processes, Machines, etc. 5
M PhD Thesis Data Statistical Analysis Methods Statistical Analysis Tools, Techniques and SPC 2
N Statistical Quality Improvement Action for Small Batch Production Statistical Analysis Tools, Techniques and SPC 17
V Validation of macro - scripts - programs used in statistical software (Minitab-SAS... Qualification and Validation (including 21 CFR Part 11) 5
Moncia Statistical Process Control Crash Course - Question Quality Manager and Management Related Issues 10
H Statistical Models for Predictive Management of Software Processes Software Quality Assurance 2
A Statistical Correlation between ordered SKUs Statistical Analysis Tools, Techniques and SPC 8
S Minitab and Crystal Ball Statistical Analysis Software Using Minitab Software 13
I Statistical Stability for the PQ of Analytical Equipment Qualification and Validation (including 21 CFR Part 11) 1
F Statistical Comparison of Product: High Average vs. Low Range Capability, Accuracy and Stability - Processes, Machines, etc. 13
E Using ANOVA during the PQ Validation Run to evaluate Statistical Differences Statistical Analysis Tools, Techniques and SPC 4
W Gage R&R for gage pins used to inspect a hole ID called a Statistical Tolerance Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 3
B AS 9100C sec 8.2.4 - " Recognized Statistical Principles" meaning AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 7
R What is PSW - Statistical Process Package + Level 5 APQP and PPAP 7
O Is SPC (Statistical Process Control) always required? Statistical Analysis Tools, Techniques and SPC 4
V Any experience/feedback on statistical software tools...minitab -design expert -JMP Using Minitab Software 4
M SPC (Statistical Process Control) Book Recommendations wanted Book, Video, Blog and Web Site Reviews and Recommendations 1
