Statistical Techniques Procedure - What should be included
Mike S.
Happy to be Alive
I don't have a stand-alone statistical techniques procedure and never have. I may mention the statistical techniques used in process documentation or a procedure document.
What ST do you use? Let's say it's sampling and control charts. Document your sampling plan and maybe your justification for using it. For control charts -- to borrow a phrase, just do it. If you feel you need to document it, write a SPC work instruction. Don;t make it any more complicated than it needs to be.
JMO -- other likely do it differently.
Can someone share statistical techniques procedure or an overview of what this procedure should include?
Thanks,
Hila
The nature of the question seems to indicate that you feel you need a procedure but you aren't sure why you need one. I'm with Mike S. on this one--don't do it unless there's a specific reason for it. Documentation should never be created unless there's a clear purpose for it. When there is a clear purpose, you should also know, at least in a general sense, what it should contain. Tell us more about why the procedure is being created.
Jean_B
@Jim Wynne
The origin is probably found as regulatory expectations from two commonly applicable sources.
ISO 13485:2016 states the requirement for procedures (there's also plans but let's exclude those) related to statistics in two clauses.
7.3.7 Design of development validation
The organization shall document procedures for validation of processes, including:
d) as appropriate, statistical techniques with rationale for sample sizes;
8.4 Analysis of data
The procedures shall include determination of appropriate methods, including statistical techniques and the extent of their use.
While 21 CFR Sec. 820.250 Statistical techniques.
(a) Where appropriate, each manufacturer shall establish and maintain procedures for identifying valid statistical techniques required for establishing, controlling, and verifying the acceptability of process capability and product characteristics.
(b) Sampling plans, when used, shall be written and based on a valid statistical rationale. Each manufacturer shall establish and maintain procedures to ensure that sampling methods are adequate for their intended use and to ensure that when changes occur the sampling plans are reviewed. These activities shall be documented.
As such the flavor is likely that of enabling appropriate selection and correct application of statistical methods. You'd have a tendency to a 'catalogue' with criteria to select an appropriate method (e.g. try 'selecting a control chart' in a search engine and look at the images), and then another policy matter on what you find appropriate levels of statistical rigor to produce confidence (aha, assurance) or changes in trends (often loosely based in risk/reliability management). And then comes the eternal debate about which abstract parameters matter, and whether you are strict enough, 'should have seen it coming', or are using the 'best' method when multiple could apply.
R Analysis of Data - The former "Statistical Techniques" procedure ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 4
L When are Statistical techniques not applicable? Service Industry Specific Topics 16
J Defining Martial Arts and Gymnastics Statistical Techniques Statistical Analysis Tools, Techniques and SPC 4
I Critical success factors for efficient use of statistical techniques Other Medical Device and Orthopedic Related Topics 14
P Deming - Management of Statistical Techniques for Quality and Productivity Philosophy, Gurus, Innovation and Evolution 9
M Statistical techniques for determining which factors are affecting the yield? Statistical Analysis Tools, Techniques and SPC 2
G Statistical Techniques Measureables for Application Development Company Statistical Analysis Tools, Techniques and SPC 3
A Statistical techniques in ISO 9001:2000 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 8
D Statistical Techniques in Research - Application of 820.250 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 4
S 21 CFR 820 QSR 820.25 Statistical Techniques Procedures Requirements ISO 13485:2016 - Medical Device Quality Management Systems 5
T Asking Suppliers about Statistical Techniques they use Supplier Quality Assurance and other Supplier Issues 4
G Shainin statistical engineering techniques Quality Tools, Improvement and Analysis 7
C ISO 9000:2000: Question about Statistical Techniques Statistical Analysis Tools, Techniques and SPC 2
Marc 4.20 Statistical Techniques QS-9000 - American Automotive Manufacturers Standard 2
C What will auditors review when going over statistical techniques? QS-9000 - American Automotive Manufacturers Standard 1
PQ Systems Better Data Visualization & Communication with Statistical Indices Using SQCpack Software 0
R Statistical Methods for comparing test and reference product equivalence for quality attributes US Food and Drug Administration (FDA) 3
S MSA clause 7.1.5.1.1 - Statistical studies on counting weight scale Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 12
S How to perform verification of the Statistical Analysis Software? Qualification and Validation (including 21 CFR Part 11) 7
Bev D Statistical Alchemy Misc. Quality Assurance and Business Systems Related Topics 1
K Looking for guidance to write an SOP on Statistical Methodologies? Statistical Analysis Tools, Techniques and SPC 7
M Minimum sample size - Guidance and statistical rationale Inspection, Prints (Drawings), Testing, Sampling and Related Topics 3
N Design Verification & Process Validation - Statistical sample sizes Design and Development of Products and Processes 2
John Predmore Interactive visualization through graphical simulation of statistical concepts Statistical Analysis Tools, Techniques and SPC 3
Bev D Profound Statistical Concepts Misc. Quality Assurance and Business Systems Related Topics 63
A Statistical Analysis - Check if these organisms at different concentrations affect the growth of wheat seedlings Using Minitab Software 4
O Statistical justification of sampling size in V&V tests ISO 13485:2016 - Medical Device Quality Management Systems 5
optomist1 It’s time to talk about ditching statistical significance Statistical Analysis Tools, Techniques and SPC 6
Marc Steve Prevette's Statistical Process Control (SPC) "Library" Statistical Analysis Tools, Techniques and SPC 0
John Predmore A Balanced view of statistical tests Statistical Analysis Tools, Techniques and SPC 3
V Statistical basis and justification while comparing / changing sampling plans Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 11
S SPC (Statistical Process Control) for Unilateral Tolerance - Questions Statistical Analysis Tools, Techniques and SPC 6
S IATF 16949 9.1.1.3 Application of statistical concepts - Our technicians are quizzed for statistical knowledge IATF 16949 - Automotive Quality Systems Standard 3
K Please help identify appropriate statistical treatment Statistical Analysis Tools, Techniques and SPC 13
ScottK Statistical basis for 30 pieces for FAI 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 7
B IATF 16949 clause 7.1.5.1.1 - Statistical studies shall be conducted IATF 16949 - Automotive Quality Systems Standard 3
A Statistical Process Control and Inspection in Footwear Production Statistical Analysis Tools, Techniques and SPC 0
M IATF 16949 Cl. 7.1.5.1.1 - Statistical studies shall be conducted IATF 16949 - Automotive Quality Systems Standard 3
Steve Prevette Statistical Process Control Library Statistical Analysis Tools, Techniques and SPC 17
Marc Happy Birthday Statistical Steven - 2015 Covegratulations 10
M FDA 21 CFR 820.250 - Does "valid statistical" always mean math? 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 6
R Common Statistical Errors Using Minitab Software 1
Y Statistical Analysis of Road Traffic Data Statistical Analysis Tools, Techniques and SPC 11
B Class II Medical Device Manufacturer - SOP for 820.250 Statistical 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 3
E Correct Statistical Test comparing 2 Groups Statistical Analysis Tools, Techniques and SPC 14
A Statistical Software Calibration using Ford's "Sample Calibration File" Statistical Analysis Tools, Techniques and SPC 8
J Capability Analysis - Unusual Statistical Distribution of my Proccess Capability, Accuracy and Stability - Processes, Machines, etc. 5
M PhD Thesis Data Statistical Analysis Methods Statistical Analysis Tools, Techniques and SPC 2
J Statistical Significance and SPC Control Chart Reports Statistical Analysis Tools, Techniques and SPC 9
