Statistically Comparing Technician Techniques
Steve Prevette
Deming Disciple
#11
You may not like the idea of more work, but I'd really suggest you also ought to do a check of the other technician also. You'd basically be trying to compare if the difference between your check and the questioinable techinician is significantly different from the difference between your check and the "good" technician.
You may also want to throw some known bad parts into this "test" to see if both can detect bad parts.
It's possible you could also look at past data from the two technicians, and check using p-chart control charts or binomial tests to see if their failure rates for "bad parts" are statisically the same or different. If we assume all parts have an equal chance of being bad, then both inspectors should have the same failure rate for bad parts, within statistical uncertainty levels.
#12
if you have been redoing her measurements how often have you foudn a different result? how often has it changed the disposition of the material as pass/fail???
#13
This isn't necessary unless the measurements produce only attributes results. The expectation for a variables study (standard GR&R) is use of parts that reflect the range of variation in the process.
Y
Yew Jin
#14
The quick comparison technique we may use is to study the average and standard deviation of the 2 sets of data with a same sample provided to 2 technician for few trials.
We might have the desire location (target) that we need to meet. Compare the 2 set of the sample average, are they significant difference and meet the target? (may use the 2 sample T test if the data is normal dist)
We may look into the data spread as well, are the spread significant difference and which is widen? (may use the F test if the data is normal dist)
We may know who is bias and precise in the quick way.
The average that far from the the desire target has more bias, however if the standard deviation is high mean he/she do not precise during test or measure a same unit in difference trials.
Most of the case is the method of measuring will give us major variable. We may standardize the method of data collection or measuring so that appraisal to appraisal variation is less. Document it properly so that everyone can follow the only method or technique to measure.
Stijloor
#15
Re: Comparing technician techniques - statistically
ahem - until there is data showing that 1. this operator's results are statistically & practically different from the other(s) and 2. that her measurements are the least accurate you - and the OP's management have no basis for assuming there is anything wrong with her.
this requires an MSA
A measuring device in the hands of an incompetent operator will have a negative impact on the MSA results. If a skills assessment shows that there is a competency issue, you don't need to perform an MSA to demonstrate that "something is wrong with her." In any statistical process (SPC, MSA, etc.) one is expected to first minimize unnecessary variation. Once all known sources of variation have been eliminated to the extent possible, further statistical analysis will demonstrate how "good" the system is.
Stijloor.
Statistical Steven
Statistician
#16
I might take a very simple approach. If you and the suspect technician measured the same part on the same instrument, then you can just do a paired t-test to see if there is a statistically difference. You will also need to determine a practical difference in case you find a statistical difference that is not meaningful.
#17
Stijloor.
yes an "incompetant" operator will yield poor results. It will show - proof - in the data. on the other hand I inferred from the OP's choice of words that the idea that this operator is 'different' has no supporting data - just opinon. The OP stated that his repeat measurement "was a waste of his time". that led me to infer that he never found a different result - otherwise, I thought that if seh was making 'wrong enough' measurements then the OP would find different answers and his questions to us would be far different: he would have asked about making her better or performance management, instead he asks how to get the data to compare her performance to himself and/or the other technician.
I think we too often jump to "incompetant operators" based on no data but a lot of opinion...the OP's post appeared to me to be going in that direction. whatever happened to "innocent until proven guilty"? As a manager I would hate to claim that an employee was incompetant wihtout proof (and HR would kill me.) additionally without the baseline data how would we know that the training worked?
S How to Statistically Prove 2 Dimensions are Related Using Minitab Software 18
F Sample Size to get Statistically Valid Data Measurement Uncertainty (MU) 6
S Statistically valid number of biopsy devices should be tested US Food and Drug Administration (FDA) 4
D Best Minitab Tool to determine a Statistically Significant Trend Using Minitab Software 5
P Sterile Packaging Validation - FDA Requirements for Statistically Valid Tests 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 9
K Statistically Valid Audit Sample for Management System Audits? Inspection, Prints (Drawings), Testing, Sampling and Related Topics 4
F How to statistically determine the maximum performance life of a chemical Statistical Analysis Tools, Techniques and SPC 4
S Statistically valid method for multiple raw material sampling Inspection, Prints (Drawings), Testing, Sampling and Related Topics 4
H How to Select a Statistically Valid Sampling Plan Inspection, Prints (Drawings), Testing, Sampling and Related Topics 10
H Process that is Not Stable vs. Not Statistically Capable - Differences Capability, Accuracy and Stability - Processes, Machines, etc. 9
J Demonstrate Receiving Inspection Sampling Method is Statistically Adequate Inspection, Prints (Drawings), Testing, Sampling and Related Topics 3
B Statistically Sound Data Sampling Technique for Internal Audits Inspection, Prints (Drawings), Testing, Sampling and Related Topics 14
S Getting started with statistically based process improvement The Reading Room 12
M Statistically Toleranced Drawing Feature Dimensions - Target Value and Range Statistical Analysis Tools, Techniques and SPC 5
L How to Monitor Corrective Actions - Statistically Monitoring Corrective Action Nonconformance and Corrective Action 34
G Pp and Ppk indices - Is it statistically possible to have a Ppk greater than Pp? Capability, Accuracy and Stability - Processes, Machines, etc. 16
M Auditing Statistically - A statistical approach to sample sizes General Auditing Discussions 11
J Statistically Determining how many Tests to conduct. Statistical Analysis Tools, Techniques and SPC 3
J Statistically Valid Sample Sizes For SPC Statistical Analysis Tools, Techniques and SPC 1
O Software for comparing text of PDF files Contract Review Process 2
M Comparing data from destructive testing Inspection, Prints (Drawings), Testing, Sampling and Related Topics 7
A Demonstration of Equivalence - Need for comparing biological characteristics for an SamD EU Medical Device Regulations 1
G Comparing Gauge Blocks - Translating the calibration between the master set and the QA set General Measurement Device and Calibration Topics 2
V Statistical basis and justification while comparing / changing sampling plans Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 11
N Does FDA allow comparing with the competitors Medical Device 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 3
L Procedure for Comparing the Monitor Reading with Laboratory Result Statistical Analysis Tools, Techniques and SPC 4
S Looking for a checklist comparing ISO 13485:2016 and 21 CFR Part 820 ISO 13485:2016 - Medical Device Quality Management Systems 14
M Comparing the MMOG (v3 or v4) with ISO / TS16949 Customer and Company Specific Requirements 3
A Comparing US/FDA Drug Regulations against US/FDA Device Regulations US Food and Drug Administration (FDA) 3
E Correct Statistical Test comparing 2 Groups Statistical Analysis Tools, Techniques and SPC 14
R Comparing Laboratory Scope of Accreditation against internal equipment General Measurement Device and Calibration Topics 3
C Comparing Two Independent Group Observations - 95% Confidence Intervals Overlap Statistical Analysis Tools, Techniques and SPC 3
D Comparing the ISO 9001:2008 standard to ISO 17025 ISO 17025 related Discussions 2
S Comparing Quality System Software Features Quality Assurance and Compliance Software Tools and Solutions 18
C Comparing Two Test Methods - Acceptable Difference(s)? Statistical Analysis Tools, Techniques and SPC 3
M pH Calibration - Comparing Electrical and CRM Methods General Measurement Device and Calibration Topics 1
I Six Sigma comparing to other National and International Models Six Sigma 6
A Comparing Effect of Process Parameters on Equipment Performance during Start Ups Statistical Analysis Tools, Techniques and SPC 3
P Acceptable Adjusted R Squared Value Comparing 2 Measurement Devices in Minitab Using Minitab Software 3
C Comparing PPM Year over Year - Determining the PPM decrease from 2009 to 2010 Benchmarking 10
M z Test vs. F Test - The most appropriate for comparing the Variances Statistical Analysis Tools, Techniques and SPC 3
T Comparing Two Measurement Systems in terms of Accuracy and Capability Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 5
R Comparing the Accuracy of Analog vs. Digital Multimeter General Measurement Device and Calibration Topics 6
T Comparing two different Ultrasonic Tester Calibration Techniques General Measurement Device and Calibration Topics 2
Q Internal Audit:Comparing Efficiency of Similar Processes ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 7
D Comparing Variation - A CMM and an On-Line Inspection Station Statistical Analysis Tools, Techniques and SPC 6
C Comparing Histograms - Bimodal Distribution? Statistical Analysis Tools, Techniques and SPC 4
K Comparing CQE vs. MSc. Professional Certifications and Degrees 1
J To PPAP or Not? Comparing two machines (one old and one new) APQP and PPAP 6
C Comparing OHSAS 18001 to the new ANSI Z10 - Where I can get information? Occupational Health & Safety Management Standards 1
