Statistically Toleranced Drawing Feature Dimensions - Target Value and Range
martin elliott
Statistically Toleranced Dimensions
We are early days with a new end user and amongst the numerous customer background documents is the requirement for Key Characteristics to be controlled in a slightly different way to our norm.
Fortunately there are no Keys specified up to date, but I thought I had better understand it for the, hopeful, future business. But before I go back to them and look ignorant, I thought I would rather look ignorant to the Covers as you are bound to know the answer or if I am on the right track!
The requirement is that the “Target Value and Acceptable Range should be expressed in terms of a Mean, Standard Deviation and acceptable Sigma Level requirements”.
My best interpretation is:-
Assume a maximum Sigma level could be Design Tolerance/12
Assuming a 4 sigma Level, 1.33 then the Mean would need to be within 2 sigma of target.
Assume a feature was designed to be at 75.00 plus/minus 0.25mm.
Maximum Sigma = 0.50/12 = 0.0417.
So the actual drawing dimension feature would need to be shown as:-
Mean 74.917-75.083
Sigma Max 0.0417.
Cpk Min 1.33
Comments?
Martin in England
Getting Older but no wiser
Bill Ryan - 2007
Statistical Tolerancing is a relatively new concept. I have not run into it on a part drawing yet. My understanding of the concept is that a feature may be "statistically toleranced" if it is produced using statistical process control methods. It is a less restrictive tolerance that is applied only after proving manufacturing capability. If the manufacturer can not prove capability, a more restrictive tolerance must be used. I think both tolerances need to be shown on the drawing. As I mentioned, I have no experience with this concept but do remember it being discussed in a couple of GD&T classes I attended.
Statistical Steven
Statistician
It makes perfect sense, and it is how all specifications should be developed. It works backwards by using the process variability to determine what specifications yield an capable process. Of course, the statistical tolerances need to be checked against customer expectations.
Mean 74.917-75.083
Sigma Max 0.0417.
Cpk Min 1.33
Comments?
Martin in England
Bill Ryan - 2007
As more of the cobwebs melt away and a few of the synapses start clicking a bit more like the old days :rolleyes: , I seem to remember an instructor saying this concept would probably be a tough sell for a while because most "older" (even a lot of "newer"?) Design Engineers just don't grasp GD&T very well. In other words, they peformed their stackup studies and then divvied the results out to the two, three, etc. components making up an assembly. Their "safety fudge factor" in most cases is inviolate.
Mean 74.917-75.083
Sigma Max 0.0417.
Cpk Min 1.33
Comments?
Martin in England
It's not real clear what the customer is asking for (which is why you're here, I guess). If the intent was to use statistical tolerancing as it's described in Y14.5M, then the customer has apparently misunderstood the requirements. I've attached the relevant section of the standard here (fair use applies, I think) for reference. Statistical tolerancing is intended to be applied in stackup situations, not in unilateral control of key characteristics. The standard describes the language to be used on drawings when ST is applied.
As for what the customer is asking for, it doesn't seem to make much sense to me; what's accomplished that just specifying a minimum Cpk level wouldn't? What is meant by "Target values...should be expressed in terms of a mean..."? How is that different from a nominal value? What is the customer asking when he says "...standard deviation and acceptable Sigma level"? (Emphasis added) What does "Sigma level" mean in this context?
Anu number of Covers might be able to make educated guesses as to what was intended, but to be honest, the requirements as expressed here are unintelligible. When it's not possible to use the specifications to interpret what the customer wants, the only prudent recourse is to ask the customer for clarification.
martin elliott
Thank you all very much for efforts.
As Jim says, it was not clear to me what the customer means and that's why I was asking for comment. To add insult to injury, looking further into his tome, I suspect some of his other requirements are less than clear, but the customer is always right;) .
In answer to the question on capability and sigma, I thought he was asking what Cpk our process was to achieve long term.
Thank you again for your imput and it looks like I will have to appear ignorant to the customer if I am to get to the bottom of it :eek: .
Martin in England
Getting very much Older but no wiser
S How to Statistically Prove 2 Dimensions are Related Using Minitab Software 18
F Sample Size to get Statistically Valid Data Measurement Uncertainty (MU) 6
S Statistically valid number of biopsy devices should be tested US Food and Drug Administration (FDA) 4
D Best Minitab Tool to determine a Statistically Significant Trend Using Minitab Software 5
P Sterile Packaging Validation - FDA Requirements for Statistically Valid Tests 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 9
K Statistically Valid Audit Sample for Management System Audits? Inspection, Prints (Drawings), Testing, Sampling and Related Topics 4
F How to statistically determine the maximum performance life of a chemical Statistical Analysis Tools, Techniques and SPC 4
S Statistically valid method for multiple raw material sampling Inspection, Prints (Drawings), Testing, Sampling and Related Topics 4
H How to Select a Statistically Valid Sampling Plan Inspection, Prints (Drawings), Testing, Sampling and Related Topics 10
H Process that is Not Stable vs. Not Statistically Capable - Differences Capability, Accuracy and Stability - Processes, Machines, etc. 9
J Demonstrate Receiving Inspection Sampling Method is Statistically Adequate Inspection, Prints (Drawings), Testing, Sampling and Related Topics 3
N Statistically Comparing Technician Techniques Reliability Analysis - Predictions, Testing and Standards 16
B Statistically Sound Data Sampling Technique for Internal Audits Inspection, Prints (Drawings), Testing, Sampling and Related Topics 14
S Getting started with statistically based process improvement The Reading Room 12
L How to Monitor Corrective Actions - Statistically Monitoring Corrective Action Nonconformance and Corrective Action 34
G Pp and Ppk indices - Is it statistically possible to have a Ppk greater than Pp? Capability, Accuracy and Stability - Processes, Machines, etc. 16
M Auditing Statistically - A statistical approach to sample sizes General Auditing Discussions 11
J Statistically Determining how many Tests to conduct. Statistical Analysis Tools, Techniques and SPC 3
J Statistically Valid Sample Sizes For SPC Statistical Analysis Tools, Techniques and SPC 1
D Multiple Features With Only One Toleranced on the Print Inspection, Prints (Drawings), Testing, Sampling and Related Topics 12
L ASME Y14.5 Coaxial Feature Toleranced with Position w/o Reference Datum Design and Development of Products and Processes 2
S Inspection to Non-Toleranced Drawings Inspection, Prints (Drawings), Testing, Sampling and Related Topics 10
U Variables Control Chart options - Tightly toleranced machined components Statistical Analysis Tools, Techniques and SPC 1
M How to calculate a True Position toleranced at MMC - Capability of True Position Statistical Analysis Tools, Techniques and SPC 12
T How to conduct R&R Study for Runout Measurement & for unilateral toleranced features Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 4
T CSE 5.01 reference on drawing Inspection, Prints (Drawings), Testing, Sampling and Related Topics 2
2 GDT of datums - Putting Datum C on a drawing Inspection, Prints (Drawings), Testing, Sampling and Related Topics 6
D Partial FAI - AS9102 - One single drawing has 10 part numbers AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 5
A Help with Drawing Review - ISO 9001:2015 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 6
V Manufacturing without a Formal Drawing ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 12
V ISO 9001: 2015 Production drawing Control ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 3
D Engineering Drawing Review and Approval Requirements ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 10
C Thread Tolerance - Can I use a 3A Ring on a part that the drawing calls out for a 2A? Manufacturing and Related Processes 5
D GD&T Drawing Question - I have a drawing and it makes no sense to me whatsoever Inspection, Prints (Drawings), Testing, Sampling and Related Topics 7
Prashant G AS9100 Requirement - Verification of characteristics results with drawing requirements AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 13
Q How do you interpret this dimension in my drawing Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 2
D Drawing (print) does not specify restrained or free state Inspection, Prints (Drawings), Testing, Sampling and Related Topics 2
A Drawing Issue with Supplier - xb file did not match that of the pdf drawing Nonconformance and Corrective Action 4
M Best Practice for setting tolerances on a Drawing Inspection, Prints (Drawings), Testing, Sampling and Related Topics 8
M PCBA Drawing Best Practices IPC Class 3 ISO 13485:2016 - Medical Device Quality Management Systems 1
G Decimal places on Drawing (Print) Callouts Measurement Uncertainty (MU) 7
M True Position / GD&T - I'm staring at this drawing and I'm lost Inspection, Prints (Drawings), Testing, Sampling and Related Topics 4
I Engineering Drawing = Record or Document? Document Control Systems, Procedures, Forms and Templates 8
B Profile of a Surface Callout on this Drawing General Measurement Device and Calibration Topics 4
J Is there a specification that provides directions on Drawing Revision Changes Inspection, Prints (Drawings), Testing, Sampling and Related Topics 5
R Location Interpretation on Drawing - Hole to Hole? Inspection, Prints (Drawings), Testing, Sampling and Related Topics 7
I Delta FAIR due to a Drawing Change AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 3
J Drawing Callout - Arrow pointing to an inner edge where there is a radius Inspection, Prints (Drawings), Testing, Sampling and Related Topics 2
M What is 'Loft' which is used in Boeing company to express 1/1 scale 2D drawing Inspection, Prints (Drawings), Testing, Sampling and Related Topics 2
