Statistics and Sampling - Accounting for Failed Tests
SRQAAuditor
Hi, I haven't seen this question on here, and need some help. I work for a medical device manufacturer. I am the internal auditor. While auditing one of our production lines, I requested that a specific test be demonstrated. The individual demonstrated the test, and since we deal with thin wires, I asked what happens if the wire breaks during the test? He told me that he just scraps the broken wire, and chooses another one to do the test again.
This doesn't feel right to me.
Any suggestions?
Thank you,
Re: Statistics and sampling
Welcome to the Cove. :bigwave:
It's impossible to say whether it makes sense or not without knowing more about the product, the test method and the purpose of the testing. Could you give us a little more information?
SRQAAuditor
I can provide some more information:
The product is used to retrieve stones in the human body (gall stones, etc), so it is a thin wire.
The test method is pushing the wire through a fixture that has bends. To simulate the wire passing through the human body.
Let me know if you need more information.
Thanks for your questions.
sounds like the wire shouldn't break...is he "testing to pass"?
this is often done when the (all too convenient and denial based) the tester 'believes' that the test was incorrectly performed.
Bill McNeese
Nothing wrong with doing the test again, but if the failure does not get recorded anywhere, that is a problem. The process performance is not what the data would indicate in this case. How often does this happen is a question to ask.
Steve Prevette
Deming Disciple
Yes, this sounds very questionable to me. A few things to consider:
1. What is the cost to the company of the product that fails the "test" and gets scrapped?
2. How do you know that performing the test doesn't shorten the life of the wire since you have now bent it and presumably straightened it again? Have you put in some fatigue cracks?
3. Yes, if the test is intended to test the wire, a failure is a failure of the test and should be recorded as such. If the "test" is considered part of the manufacturing process, I suppose it could be excused, but then how do you know how the wire will behave in its use? What is the test then that you, the manufacturer performs?
SRQAAuditor
Thank you for the additional thoughts to follow up with! This test is not performed every day, but I have requested to be present during the next test, and will follow up!
Is this written down anywhere?
You should pay special attention to Marc's question. If this is a required test, it should be documented:
  • Reason for testing
  • Frequency of testing
  • Method of testing, including gages, equipment, etc.
  • Objective pass/fail criteria
  • Reaction plan--what to do in the event of failure
  • Record keeping, including retention of test specimens if necessary or prudent
If the test is important enough to be doing on a continual basis, it should be properly documented.
A Statistics Sampling Inspection, Prints (Drawings), Testing, Sampling and Related Topics 1
S Statistics and / or Forecasts on medical products exports from China Other Medical Device and Orthopedic Related Topics 1
Richard Regalado What could go wrong with information: Ransomware statistics and facts (2018 to present) IEC 27001 - Information Security Management Systems (ISMS) 0
I Good resources for learning statistics (quality engineering related) Statistical Analysis Tools, Techniques and SPC 10
qualprod Statistics - Where to start in ISO 9001? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 5
Ninja Visitor Statistics - How to see a poster's stats easily? Elsmar Xenforo Forum Software Instructions and Help 3
D How do you use statistics in your job Statistical Analysis Tools, Techniques and SPC 6
J Excellent Resource on Statistics / Lean / Six Sigma Book, Video, Blog and Web Site Reviews and Recommendations 2
V Accelerated Learning and Simulations / Scenarios - Statistics Statistical Analysis Tools, Techniques and SPC 0
P Where to find conformance statistics for ISO 15189 Other Medical Device Regulations World-Wide 1
V Statistics - Designs - Differences between Orthogonality and Confounding Using Minitab Software 5
M Statistics Question - What percent falls above 105? Statistical Analysis Tools, Techniques and SPC 2
A Assessing a Preventive Maintenance Strategy - Reliability or Maintenance Statistics Reliability Analysis - Predictions, Testing and Standards 2
T Metrics and Statistics for Improvement - Easy to implement Statistical Analysis Tools, Techniques and SPC 4
C Statistics equation to determine the number of samples in a lot Statistical Analysis Tools, Techniques and SPC 8
A ASQ CQE statistics training in Australia? Training - Internal, External, Online and Distance Learning 2
E Online Degrees and Graduate Certificates in Statistics Training - Internal, External, Online and Distance Learning 1
AnaMariaVR2 Guide to Microsoft Excel for Calculations, Statistics, and Plotting Data Excel .xls Spreadsheet Templates and Tools 11
C Basic Statistics Template .xls Document Control Systems, Procedures, Forms and Templates 0
S Statistics in Check/Replicate Analysis - HPLC Assay (Sample Duplicates) Statistical Analysis Tools, Techniques and SPC 1
R Student Question - Help needed with statistics questions Statistical Analysis Tools, Techniques and SPC 6
M The Statistical Meaning of "Muddy Middle" - Statistics Terminology Statistical Analysis Tools, Techniques and SPC 6
B Descriptive Statistics where the Data Type is Text? Using Minitab Software 4
R Industry Statistics on the benefits of Quality Management Systems ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 8
Jim Wynne xkcd on Statistics and Mainstream Media Funny Stuff - Jokes and Humour 2
A R using RExcel - Non GUI Statistics Program Statistical Analysis Tools, Techniques and SPC 1
Wes Bucey Job recovery? or "statistics don't lie, people do" Career and Occupation Discussions 37
G Statistics Question from Production and Operations Management Course Statistical Analysis Tools, Techniques and SPC 3
O Information on the extent of Statistics in the Six Sigma Green Belt Exam Professional Certifications and Degrees 9
J Gage R&R Module for R (Statistics Program) Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 4
T Survey or Statistics on the use of OHSAS 18001 Worldwide Occupational Health & Safety Management Standards 66
T Survey or Statistics on the use of the AS 9100 Standard Worldwide AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 2
H Elsmar Cove Statistics Found Online Coffee Break and Water Cooler Discussions 2
Chennaiite Quotable Quotes - Statistics Funny Stuff - Jokes and Humour 10
S Statistics of Gage R&R & Boundary Specifications Statistical Analysis Tools, Techniques and SPC 15
K Sample Statistics on HR (Human Resources) Key Processes ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 3
bio_subbu FDA released guidance on use of Bayesian statistics in Clinical Studies 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 0
O Weighting Problems (Statistics) - Weight distribution for a machine setup Capability, Accuracy and Stability - Processes, Machines, etc. 5
S "Human Error" statistics Quality Manager and Management Related Issues 3
S ASQ CSSBB Exam & Knowledge of Statistics Professional Certifications and Degrees 3
J Are there PPM statistics kept by Industry Manufacturing and Related Processes 4
Marc Battery-Life Statistics After Work and Weekend Discussion Topics 4
F Error in Minitab (no statistics can be calculated with these data) Using Minitab Software 10
O The Basis of %GRR (% Gage R&R) and other Statistics - Minitab Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 21
V Management Review Meeting - Statistics for Customer Complaints and Non Conformances ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 2
T The use of Statistics at a Medical Device Manufacturer US Food and Drug Administration (FDA) 16
Y Statistics and MiniTab - Example Problems Using Minitab Software 4
W Application of Statistics/ SPC tools in Oil Refineries Statistical Analysis Tools, Techniques and SPC 11
Q Specific requirements for Statistics in CQE exam Professional Certifications and Degrees 3
A Best certification combination with Masters in Statistics Professional Certifications and Degrees 2
