Sterilisation ISO 11135 EtO-in-a-Bag (Novel Non-Traditional EtO Sterilization)
Q
Quarma
This is about a Novel non-traditional method of ETO sterilisation:
It is called Ethylene Oxide-in-a-Bag (EtO-in-a-Bag, Diffusion method, or Injection method)
This method differs from traditional EtO methods in that Ethylene Oxide-in-a-Bag specifies a volume of EtO instead of a concentration (e.g., 7.2 grains instead of 500-600 mg/L), uses an EtO cartridge or capsule, uses humidichips, or uses a long gas dwell time (e.g., greater than 8 hours).
This method consists of injecting or inserting ETO into a 7 or 35 liter bag which contains the packed products. The ETO diffuses into the product which is in the bag and finally diffuses out of the bag. Temperature is maintained at about 50°Celsius at ambient pressure.
FDA classifies this method as Novel non-traditional
Sterilisers that use that method are marketed by Andersen.
Is there any scientific literature on this ?
Has anybody experience in validating this method ?
Does anybody use this method for sterile medical devices (US or Europe or elsewhere) ?
Would you follow ISO 11135 or ISO 14937 for validating this process ?
There is thread Sterilization Validation ISO 14937 - Sterilizer that uses EO gas diffusion with a similar question but no answer.
Thanks for answering
(Please only answer if you are familiar with this method)
Doug Tropf
I'm not real familiar with EO in a bag however, I have heard there are some unresolved questions regarding the legitimacy of the process. At one point there were rumors in the industry of a related TIR in the works but it has never materialized. Attached is a rather dated article on the topic.
Q
Quarma
Thank you all for answering.
The attached "EO in a bag article" is written by Andersen people, so I would regard it as marketing material, but not necessarily a critical approach.
Also "EOGas cycles are validated using the applicable portions of AAMI/ISO 11135" is a statement by the manufacturer who is naturally biased.
I do by now question if it is valid to simply drop the non-applicable parts, as these do contain critical things like EO-Concentration measurement. (They are non applicable because you cannot assess them - not because they do not apply to the process)
I am still wondering if there are medical device companies out there who got this process accepted with FDA or Notified Bodies or other authorities - and how they did it.
MIREGMGR
In addition to EO concentration, I'd be concerned in regard to humidity vivification of spore-form microorganisms. A key function of the conventional preconditioning process is overkill-assurance of substantially complete vivification. The bag system's approach to humidity provision so as to achieve complete vivification seems to be both less rigorous and less able to be validated.
MIREGMGR
It's funny how timing works sometimes in the regulatory world.
This morning, FDA's weekly Warning Letter report includes http://www.fda.gov/ICECI/EnforcementActions/WarningLetters/2012/ucm303395.htm issued to Andersen Sterilizers, the company responsible for the bag sterilization process discussed in this thread.
Apparently they haven't made much of an effort to comply with basic FDA requirements for either their company or their products.
I'd guess that, since at least some of their products apparently have been marketed without benefit of 510(k) and the subject matter is sterilization of (typically) surgically invasive and/or blood-communicating devices, a recall will be forthcoming.
MIREGMGR
Another follow-up: a Warning Letter has been issued to a device maker that uses an EtO sterilization machine based on a bag technique, for a variety of nonconformances. Of particular interest is the FDA's statement that the FDA Recognized Consensus Standard for EtO sterilization, ISO 11135-1:2007, may not be used as the basis for validation of a sterilization process using such a machine. As there is no other generally recognized standard, let alone an FDA Recognized Consensus Standard, for validation of a process based on such a machine, this would seem to be a major barrier to this approach.
Warning Letter FLA-12-41 issued to IsoAid, L.L.C., 16AUG2012
amooney
FDA do NOT class flexible chamber technology as "novel non-traditional". Validations are done in line with ISO11135 as applicable. The hospital paper from the library on the anderseneurope.com library is probably a good starting place for those considering this technology.
MIREGMGR
How do you reconcile this statement with the above-referenced, below-quoted Warning Letter?
The procedures titled IsoAid – Technical File: Advantage I-125 Brachytherapy Seeds, Sterilization Validation Performance Qualification Protocol, EO-PQ-01, Rev. Orig., (Reference B), references using the elements of standard ISO 11135-1:2007, Sterilization of Health Care Products – (b)(4). However, the ISO 11135-1:2007 standard – Requirements for development, validation and routine control of an (b)(4) sterilization process for medical devices, does not cover sterilization by injecting (b)(4) or mixtures containing (b)(4) directly into individual product packages, or continuous sterilization processes. Therefore, your (b)(4) sterilizer cannot be validated per the ISO 11135-1:2007 standard requirements.
I note from your profile here that you are Managing Director of Andersen Products, which I gather is the same company or perhaps a European affiliate of Andersen Sterilizers, the company referenced three posts up. Has FDA issued a Guidance or some other public document you could point us to, that reverses the position they seemed to describe in the above Warning Letter?
N ISO 11135 Monitoring Routine ETO Sterilisation Parameters Other Medical Device Related Standards 3
C ISO 11137:1995 Sterilisation of healthcare products - Amd1:2001 ISO 13485:2016 - Medical Device Quality Management Systems 11
chris1price EtO Sterilisation Consultant Wanted Job Openings, Consulting and Employment Opportunities 0
J EU countries and steam sterilisation protocol EU Medical Device Regulations 0
M Is there an Industry Norm for Expiry of Sterilisation Validity? EU Medical Device Regulations 6
N ETO Sterilisation Validation - EO Residual Minimum Sample Requirement ISO 13485:2016 - Medical Device Quality Management Systems 2
A Eto Sterilisation Re-Validation Requirements Other Medical Device Related Standards 4
J Sterilisation Validation of Re-Usable Hospital Instruments ISO 13485:2016 - Medical Device Quality Management Systems 1
N Sterilisation of IV Bags used for Veterinary Blood Plasma Products ISO 13485:2016 - Medical Device Quality Management Systems 7
P ETO Sterilisation of Single Use Part supplied in Non-Sterile State EU Medical Device Regulations 12
I Correct Label Symbol to be used for Steam Sterilisation ISO 13485:2016 - Medical Device Quality Management Systems 3
T ETO Product Sterilisation Testing Standard Requirements ISO 13485:2016 - Medical Device Quality Management Systems 4
B ISO13485 Sterilisation Validation, Risk Management, Post Market Surveillance ISO 13485:2016 - Medical Device Quality Management Systems 13
J Sterilisation Validation - VDmax for e-beam ISO 13485:2016 - Medical Device Quality Management Systems 12
chris1price Archiving of paper records - ISO 9001 7.5.3.1b Records and Data - Quality, Legal and Other Evidence 2
M Transferring ISO 17025 from one company to another ISO 17025 related Discussions 1
D Common practices in ISO 9001 deployment ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 16
B ISO 17025:2017 risk management Risk Management Principles and Generic Guidelines 0
P Audit check for IT company (ISO 9001) ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 7
M Label Making & Printing Standards ISO / ASTM ISO 13485:2016 - Medical Device Quality Management Systems 5
Sidney Vianna Interesting Discussion Should ISO 9004 be changed from a guidance standard to a requirements standard? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 5
Ed Panek ISO 13485:2016 Section 5.5.3 ISO 13485:2016 - Medical Device Quality Management Systems 3
Q Do these certificates of calibration meet ISO 9001 requirements for traceability to NIST? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 10
ebrahim QMS as per ISO 13485, Clause 4.2 Requirements for regulatory purposes for Medical Devices Authorized Representatives. ISO 13485:2016 - Medical Device Quality Management Systems 3
S ISO 2768-mk print call out Other ISO and International Standards and European Regulations 11
T ISO 17024, clauses 4.3.8. and 5.1.1. Other ISO and International Standards and European Regulations 4
C ISO 14001:2015 6.1.3 Compliance Obligations - Legal requirements monitoring ISO 14001:2015 Specific Discussions 0
D ISO 13485 scope (implantable) - Polymers for dental application EU Medical Device Regulations 9
W First time being audited (ISO 9001), asking for advice ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 9
John C. Abnet ISO 26262 ISO 26262 - Road vehicles – Functional safety 3
Marc ISO 26262- Road vehicles – Functional safety ISO 26262 - Road vehicles – Functional safety 0
John C. Abnet ISO 26262 IATF 16949 - Automotive Quality Systems Standard 0
A ISO/DIS 15223-1:2020 - Country of manufacture label (IEC 60417 No. 6049) - Which national law requires this symbol? Other Medical Device Related Standards 0
P ISO 14644 Class 8 Cleanroom Air Filter Requirements Other Medical Device Related Standards 4
K PDCA cycle and ISO processes alternative model Quality Management System (QMS) Manuals 14
A ISO 13485 procedure change and reflect to legacy manufacture items ISO 13485:2016 - Medical Device Quality Management Systems 2
D ISO 13485 & CE Certification for Surgical Gloves CE Marking (Conformité Européene) / CB Scheme 0
S ISO 11137- Simulated product vs SIP Other Medical Device Related Standards 2
D Which ISO Standard to purchase? ISO 13485:2016 - Medical Device Quality Management Systems 7
V ISO 10360-5: 2020 Gap analysis and Action plan Excel .xls Spreadsheet Templates and Tools 1
Q ISO 9001 - Reseller Exclusions ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 7
S Inventory Listing and ISO 13485:2016 ISO 13485:2016 - Medical Device Quality Management Systems 3
C ISO 45001 6.1.2.1 Hazard Identification Occupational Health & Safety Management Standards 1
S Any ISO standards around Artificial Intelligence and Machine Learning? Medical Information Technology, Medical Software and Health Informatics 4
M ISO 13485:2016 Certification Scope ISO 13485:2016 - Medical Device Quality Management Systems 2
