Struggling with a root cause analysis - Customer Returns - Escape issue
FloridaST
Recently we received back some parts where a component was not assembled correctly. The criteria is clearly shown on the assembly drawing and our work instructions also clearly call out the requirements. This has happened one time before (I wasn't here at the time) so there is likely a systemic breakdown which is allowing this to happen. The escape issue I can fix. Where I'm struggling with is explaining WHY this happened. Why did the production staff build it improperly when I know the answer is because they weren't paying attention or just didn't care? We have very clear work instructions which clearly state the requirements. These are not new employees that build these and the parts are good parts and they still get built wrong. I think it's because they don't know why the requirement is what it is so they don't put much thought into it.
I spoke with the customer about the design of this product and their explanation made a lot of sense. I can flow this down to the staff for awareness to help motivate them to build these properly. That said, the requirement is known and they shouldn't need to know why.
Anyway, it's frustrating, maybe someone can give me another perspective.
Sidney Vianna
Post Responsibly
ISO 9001:2015 7.3.d) is applicable here. When people become aware of the (potential) consequences for sloppiness, they tend to care, especially when serious consequences might exist. Further, you can direct the root cause investigation for lack of robust verification of the assembly process. Not an elegant solution, but, if there is systemic lack of discipline, you might have to strengthen the verification of the assembly process, before product ships. Much easier to address than "lack of discipline".
So, the root cause of the escape would be lack of proper verification post assembly. If the customers can detect the problem, so should you.
Good luck.
blackholequasar
The Cheerful Diabetic
I struggle with this too. When we have a process in place, and we have a work instruction and visual aid -- and yet it STILL fails not only to be created correctly but also makes it through the quality check... it's such a process breakdown that there has to be a better way to prevent it. It comes down to if people are paying attention or not sometimes, and that variable is hard to control. You reduce the risk of someone being careless when you create a quality stop along the way, but when that fails it can feel like the process is trash. You can't root cause 'people don't care' haha
You have to believe that if there is a breakdown in the process, it can be repaired. The solution, however, isn't always super visible. So I really can empathize with your situation.
Golfman25
I would argue with your premise -- that you have a systematic issue. If this is only the 2nd time it happened (the first being when you weren't even at the company), I would ask how many units ago, or how long ago. There are some things that the cost to make perfect are huge compared to the cost of a singular return every now and then. So do that analysis to determine if you really have a "problem." Then you can work from there. Good luck.
FloridaST
I hear ya and to clarify, the quantities are rather large, 1000+ pieces each, and these RMAs are only about a few months apart so it's a problem. If it were only 1 or 2% ,that's one thing, but entire lot rejects need some attention.
FloridaST
Thanks for the input everybody. I did some further research on the cove and this is a fairly common topic but your responses to my personal issue has helped get me thinking differently about it. To me, there's a condition that is allowing the operators to build these improperly and that's what I'm looking to fix. Hopefully I can implement a control poka-yoke to remove some of the burden on them.
Sidney Vianna
Post Responsibly
Frequency is important, but so is the criticality of the failure. An isolated discrepancy which could lead to very serious consequences obviously should be treated via RCA and true corrective action.
optomist1
A Sea of Statistics
could be I missed something, but generally, when it doubt poke yoke the process or operation(s)...this may be a bit off base, but depending on the type of device and process, when sporadic issues are encountered, "witness marks" are a simple but effective method for work station pesonnel or auditors to confirm it was assembled/oriented as required. The witness marks are frequently used as part of the "safe launch" phase, in automotive field...
FloridaST
Right, so my example is a real actual issue. If the parts aren't aligned properly, they won't see the pin that fits between them and then an alarm will sound on the finished unit. This pin was reduced in size recently for safety reasons so now it's extremely important that the parts are aligned in the piece that we build. Before this occurred, we could get away with alignment issues but not any longer. I never would have known about the pin until I asked them how this assembly is used by them. At least now I have something to work with when explaining why it's important to our assemblers.
L Struggling with Writing Effective Root Cause Statements Problem Solving, Root Cause Fault and Failure Analysis 13
B Struggling with using the 5.6 version Ford Capacity Analysis Report APQP and PPAP 5
Proud Liberal Struggling w/ GR&R on ID Spline Runout Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 0
T Struggling with ISO 13485:2016 Clause 6.2 - Level of Risk Associated with Work ISO 13485:2016 - Medical Device Quality Management Systems 3
I Struggling with Training and Competence ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 10
S Struggling with definition of Initial Importer and First Title 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 2
B Struggling With Writing PA (Preventive Action) Procedure Preventive Action and Continuous Improvement 11
M A newbie to RM struggling with the policy ISO 14971 - Medical Device Risk Management 1
S Are you struggling with your IEC 60601-1 3rd edition testing lab? IEC 60601 - Medical Electrical Equipment Safety Standards Series 16
K Struggling with the Gap Analysis Documentation for IEC 60601 IEC 60601 - Medical Electrical Equipment Safety Standards Series 3
A Struggling with Process and Sub-Process Validation - Brain Catheter Design and Development of Products and Processes 2
B Quality Planning process map - Struggling to define all the inputs and outputs Process Maps, Process Mapping and Turtle Diagrams 17
M ASME NQA-1-1994 Standards - Struggling with the supplement references Various Other Specifications, Standards, and related Requirements 16
C Struggling to teach a co-worker how to read dial calipers, any advice? General Measurement Device and Calibration Topics 13
K Repetitive Nonconformance (Struggling with Corrective Action Tools) - Need Help! Nonconformance and Corrective Action 14
K Struggling with keeping part-time internal auditors in our program Internal Auditing 15
H Still Struggling.... Control chart practice problems for the CQT Statistical Analysis Tools, Techniques and SPC 3
J Contingency Plan missing Utility Interruptions - Root cause support needed IATF 16949 - Automotive Quality Systems Standard 8
M Root cause for lack of quality objectives for HSE Dept. ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 26
Q Lack of transparency root cause US Medical Device Regulations 18
M Root cause General Auditing Discussions 6
J NADCAP Root Cause - Misinterpretation of Checklist Requirement Various Other Specifications, Standards, and related Requirements 5
B NADCAP Rejection Response to Root Cause Analysis and Corrective Action. Nonconformance and Corrective Action 1
Lee Taylor Indentifying human error as a root cause Human Factors and Ergonomics in Engineering 51
K HR concerns with listing human factors as root cause Problem Solving, Root Cause Fault and Failure Analysis 11
qualprod What is exactly the root cause? Nonconformance and Corrective Action 9
M Test failure Root cause not found Customer Complaints 10
Tagin You're Gonna Need a Bigger Root Cause Coffee Break and Water Cooler Discussions 12
Q IATF audit - Root Cause Analysis results IATF 16949 - Automotive Quality Systems Standard 5
S Knee Implant (Femoral -Cobalt chrome)-Sub chronic toxicity test (ISO 10993-11)choice of root Medical Device and FDA Regulations and Standards News 2
qualprod D5 of 8D clarification, how to verify root cause Problem Solving, Root Cause Fault and Failure Analysis 26
T Tactics for Root Cause Analysis Problem Solving, Root Cause Fault and Failure Analysis 4
W Misinterpretation of requirement acceptable as root cause? Problem Solving, Root Cause Fault and Failure Analysis 19
T Root Cause Failure Analysis - Not following Customer packaging Specification Problem Solving, Root Cause Fault and Failure Analysis 9
D Root Cause for Missed Audits Misc. Quality Assurance and Business Systems Related Topics 1
qualprod Always one root cause? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 35
I Root Cause Analysis as Training ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 10
G Working on a Root Cause Problem Solving, Root Cause Fault and Failure Analysis 11
I Root Cause Analysis when someone simply stops performing a task? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 16
C Neglect or legitimate deferral? Is excessive workload or lack of resources in a department or a team a valid root cause for a non-conformance? Problem Solving, Root Cause Fault and Failure Analysis 14
E CAR (Corrective Action Report) with questionable Root Cause ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 16
S Root cause analysis - The system of developing a work instruction is not effective Problem Solving, Root Cause Fault and Failure Analysis 1
I What if your root cause analysis is -- they just didn't do it?" Nonconformance and Corrective Action 3
T Root causes - operator's actions Problem Solving, Root Cause Fault and Failure Analysis 17
Ed Panek Root Cause CAPAs from internal audit ISO 13485:2016 - Medical Device Quality Management Systems 16
A Interesting Discussion Human Factors as Root Cause AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 13
D Root Cause on Non-Conformity Against Quality Manual Problem Solving, Root Cause Fault and Failure Analysis 9
A CAR from 3rd party AS9100D auditor - Root cause dilemma AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 45
P Examples of Nonconformance, Corrective Action Requests, and Root Cause Analysis Nonconformance and Corrective Action 2
N The known set of all root causes Nonconformance and Corrective Action 11
