Stuck in the middle of ISO 9001:2008 Implementation
Dubai_capi
hi,
am the QMR and quality specialist in my org.. the divisions have already made their way to implement the iso:9001:2008.. now am struggling with them to:
issue their business forms with the new revision numbers and issue dates
to finish their quality policy and quality objectives
to finalise the date for first internal audit
and the most important thing is to document many un-docmented processes..
so what do u advice to give it a kick.. am planning for the certification in june2011
pls help
John Broomfield
hi,
pls help
Dubai_capi,
Delay certification and refocus the company on developing its process-based management system to fulfill objectives beyond certification.
Announce this because your project has lost its momentum.
Then involve your system development team (including the top management sponsor) in agreeing the system (quality) objectives, project schedule of who is going to do what by when.
Promise progress reports to top management so they can play their part in making employees aware of their commitment to requirements.
Stumbling or rushing to certification just for certification may result in a system that nobody wants or will use.
John
somashekar
hi,
pls help
1. A simple and effective quality policy can be established for your organization if you share your area of business or business scope and some help comes from the forum here. You can fix on anyone and communicate it to all within the organization. Likewise objectives can be set for your core processes
2. Let them use what forms thay are already using. Ask them to list and identify them with a name. Let them not change it without consulting you.
3. 1st Internal audit April 2011 and 2nd in May 2011
5. Document the ISO9001:2008 mandatory procedures and ask functions where processes are undocumented to make a simple flow chart of how the processes function. Also get them to identify what records come out from there processes. This must match with 1. above, and with the requirements in the ISO9001:2008 standard. The process people must be well trained in the process and their records maintained. All must be familier with the flowchart of the process they manage and remain consistant.
Your internal audit 1 and 2 must be strong and perhaps through some external competent agency who can identify and finetune your process. Have management reviews and records of same in April and May. Take your certification in June 2011.
The stage 1 of the June 2011 may also identify some gaps which can better your QMS and wishing you all success in the June 2011 certification ~~~
hi,
pls help
Without knowing the size of your company and divisions I cannot comment too specifically, but would it be possible for you, as QMR, to conduct an internal "systems audit"? if you can, then do so...This will provide two advantages.
1) It will allow you to get out and see exactly what the problems are, pinpoint roadblocks and brainstorm solutions with the folks in the trenches and
2) It will show them that you are serious about getting this done and that you are ready to step in and help in any way you can.
A third benefit is it will give you and them a taste "auditing".
Peace
James
JaneB
Impossible without you providing more information on the context (eg, type of organisation, number of people, products/services, org structure, management backing etc) to provide any but general advice.
But my observations:
1. Forms wouldn't be first on any list of mine!
2. Why are the divisions supposed to "finish their quality policy"? There ought to be only one quality policy, provided by top management. Is it?
3. Similarly, their objectives should cascade down from those provided by top management - have those been set and communicated clearly by top management?
4. June is barely 4 months away - if processes aren't documented yet, that's possibly too ambitious a deadline. Who set it? On what data?
N
newenglandiso
Hello - my recommendation is to schedule the audit and once you receive a reply from the Registrar, let all those involved in the completion portion of this project know the time line. Also let them know that the 3rd Party auditor will probably be speaking to them directly about each element they are responsible for. This would waken their sleepy eyes!
JaneB
Depends entirely on what's causing the issue and how effective this would be. I doubt 'sleepy' is the problem. And taking this approach could also earn the wrath of the manager/s if not properly communicated with and/or an audit goes ahead, is unsuccessful and costs the company extra money. Dangerous and quite possibly utterly ineffective path.
F
foiley
My tip - Key Management Support...
and if you are able to to, align the individual performance targets on your quality objects of the business rather than the division - number 1 to achieve and maintain Certification!
Another tip is be harder on your internal auditing and corrective/preventative actions. When you auditor pings you on a topic, as long as you have put in a realistic acitons with accountabilities and time frames it is hard to argue it is a major issue...
Best of luck
Dubai_capi
well, we are going to have a separate quality manual for each division with separate quality policy and separate quality objectives.
the divisions is about 100 staff and we have a quality section with only 2 persons. am responsible for iso project. and processes are not documentd in many divisions. am working to document them right now. the division directors delay achievement of certain required tasks from me due to their bust schedule and limited staff.. i have a coordinator in every diviion and beside their work they work with me to develop the system in their division and they are being educated about the iso by me but still i spend with them time to explain things to them.
somashekar
I do not get the logic in this. Please clarify as the ISO 9001 does not ask for anything such. Are you progressing towards certification of a division amongst many of your divisions ... ?
qualprod What tier number fits in a company producing paper labels stuck on automotive parts? IATF 16949 - Automotive Quality Systems Standard 7
A Stuck at 'Analyse' stage of DMAIC Improvement Cycle on Cosmetic Specification Manufacturing and Related Processes 10
A Getting Stuck Choosing a Sampling Plan Inspection, Prints (Drawings), Testing, Sampling and Related Topics 6
A PFMEA for an Assembly Process - Stuck in first steps FMEA and Control Plans 6
F Our container of pleasure toys is stuck... regulated as "medical devices" by FDA ? 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 19
J PDCA Cycle - Stuck at D, D, D, D, D... Quality Manager and Management Related Issues 20
A Stuck with Due date as a KPI - Services like evaluation studies ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 0
K Am I the only one stuck working on the 24th Coffee Break and Water Cooler Discussions 39
Jen Kirley Stuck in the eBay help desk spider web! Service Industry Specific Topics 13
Marc 13 Dec 2007 - Stuck in Boston Coffee Break and Water Cooler Discussions 21
G Stuck with Zero Defect target - Manufacturing Waste Target is Zero Inspection, Prints (Drawings), Testing, Sampling and Related Topics 17
Randy ISO 14001 Implementation Schedule - I doing a proposal and I'm stuck! Miscellaneous Environmental Standards and EMS Related Discussions 18
S 510(k) Questions - Do we as the middle-man have to have one? Other US Medical Device Regulations 1
K Implementing ISO13485:2016 in the Middle of a New Device Project ISO 13485:2016 - Medical Device Quality Management Systems 1
W IEC 60601-1-2 Testing Laboratories in the Middle East IEC 60601 - Medical Electrical Equipment Safety Standards Series 1
R Medical Device Authorised Representation Middle East Other Medical Device Regulations World-Wide 1
AnaMariaVR2 Widening Battle: Middle East Cyberattacks Target Oil Producers and U.S. Banks World News 0
I TGA and HC (Health Canada Class 4) in Middle East Countries Other Medical Device Regulations World-Wide 5
J Medical Software Regulatory Requirements for South America and Middle East Other Medical Device Regulations World-Wide 3
P IVD registration requirements in Middle East and African countries Other Medical Device Regulations World-Wide 1
M The Statistical Meaning of "Muddy Middle" - Statistics Terminology Statistical Analysis Tools, Techniques and SPC 6
G Will Artificial Intelligence Replace Middle Management? Philosophy, Gurus, Innovation and Evolution 6
Wes Bucey "In the middle of difficulty lies opportunity." - Einstein Career and Occupation Discussions 2
Marc Cable Breaks Disrupt Middle East and South Asia Internet Access After Work and Weekend Discussion Topics 0
H A Tale of that 'Middle' Finger Funny Stuff - Jokes and Humour 19
Crusader ISO 9001 Update Delayed until the Middle of 2009 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 6
J I am looking for an example of a Layer 2 audit for Middle Managment Document Control Systems, Procedures, Forms and Templates 1
D How do I sell 5s to middle management? Lean in Manufacturing and Service Industries 9
Marc Bye-Bye, Pension! The trend in the US to reduce middle class worker wages World News 17
L How Common is ISO 9001 in Europe and the Middle East? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 1
Q Has Lean Manufacturing put on weight due to Middle Age? Lean in Manufacturing and Service Industries 14
F No Response to Corrective Actions by Middle Management - How do you say sabotage? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 55
A Anxiety - ISO Re-registration Audit ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 27
M Does the scope of ISO 9001:2015 applies to tenders, pricing and sales department of a medical devices distributor? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 3
P ISO 20400:2017 Sustainable Procurement Implementation Sustainability, Green Initiatives and Ecology 0
R ISO 27001 implementation IEC 27001 - Information Security Management Systems (ISMS) 3
D Can an ISO 9001 Certificate have Remote Locations? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 4
W What is okay to use as a reference material for ISO 17025? ISO 17025 related Discussions 2
R ISO 14971 not harmonized ISO 14971 - Medical Device Risk Management 4
A ISO 14001:2015 clause 4.4 ISO 14001:2015 Specific Discussions 2
A Internal audit plan and processes for ISO 14001:2015 ISO 14001:2015 Specific Discussions 3
Moncia Implementing ISO 50001 Sustainability, Green Initiatives and Ecology 15
D Question on using audit checklist ISO 13485:2016 ISO 13485:2016 - Medical Device Quality Management Systems 12
C ISO 80601-2-56 Laboratory accuracy Other Medical Device Related Standards 7
D ISO 9001 - 8.4.1 Evaluate All Suppliers? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 66
M Looking for a copy of ISO 10651 Hospitals, Clinics & other Health Care Providers 6
M ISO 13485 and document control for programs ISO 13485:2016 - Medical Device Quality Management Systems 6
Sidney Vianna ISO 9001 News ISO 9001 Quality Check - spinning facts in LinkedIn ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 6
AllTheThings ISO-17025 accredited TEST lab performing internal calibrations (Yes: Here is how) ISO 17025 related Discussions 6
P Filled in F48/F49 for internal audit ISO 17025:2017 Internal Auditing 1
