Stuck in the middle of ISO 9001:2008 Implementation
Dommy
#21
Couldn't agree more. Doing this will also help with your constant revisions to documents and also help document process which are now undocumented. Be sure to make a calendar and follow it. If you set dates, times and goals then you will be able to show top management where they can help and where you need to be.
As for updating revisions in your forms, the best answer I would have is to go electronic. Electronic is more suitable for any business that aims to constantly improve.
Just to reiterate what everyone else has said; It is hard enough to be the QMR for one system let alone many. I would focus all energy on one QMS with different divisions. I feel like you are adding more weight on your shoulders than you need to.
Good luck
Dubai_capi
#22
Good luck
any 1 can help to provide a template for schedling the project more effectively..
thanks for the input
SteelMaiden
#23
issue their business forms with the new revision numbers and issue dates
Why would you issue new revision numbers and issue dates? Your forms could all be considered "issued" the date you call your system implemented. There is no way I would change all my forms to include a revision number on them until the first time I actually revised them. A form with no revision number would be an original form as issued with the implementation of your system.
to finish their quality policy and quality objectives
Does your top management understand that this is a requirement for registration? If they do and they are not helping with this, it appears as though you have some commitment issues that need to be taken care of prior to bringing in your registrar. BTW, I see no problem with your divisions being autonomous. We operate that way, with over 30 divisions.
to finalise the date for first internal audit
Why are you waiting? Go out and audit something.
and the most important thing is to document many un-docmented processes..
Go to each area with a pen and notepad. Start asking questions, and writing down the answers. Why do you do this? How often? Who is responsible? Show me, step by step, what happens in this process. What do you do if you find nonconforming material? When you are done, you pretty much have a rough draft of your work instruction. Type it up, have the responsible (process owner) party approve it, then implement it.
so what do u advice to give it a kick.. am planning for the certification in june2011
I cannot remember how many divisions you said you are working with, but to tell you the truth, I wouldn't worry about getting them ready on the same date. I'd set up a schedule to stagger them somewhat, take what you learn from the first and apply it to the second and continue to trickle it down. Each division would be one step behind its higher priority sister. And, I'd really rethink that June date considering that you seem to have a problem with commitment issues.
Dubai_capi
#25
"Why would you issue new revision numbers and issue dates? Your forms could all be considered "issued" the date you call your system implemented. There is no way I would change all my forms to include a revision number on them until the first time I actually revised them. A form with no revision number would be an original form as issued with the implementation of your system."
thanks, i have a procedure for document control to mention a revision number and issue date on the forms. so how i can identify the forms being changed or not if i dont identify the change so the users can know that the form that they are using is the latest revision. am confused. i like your point of not puting any revision status once the system implemented but how you can identify the changes if it happen..
JaneB
#26
I'd stop fiddling around with form revision numbers - given what you say, they should be very low down on the 'to do' list in importance.
And I don't think a lack of 'template' for managing it is really the biggest thing either - if you want one, there are plenty in the Post Attachments List.
But you haven't responded at all when people have queried the multiple systems, the multiple quality manuals and multiple objectives without any overall one in place.
What Steel Maiden said about the failure of divisions to address this IS important:
No commitment? No system - I'm sorry, that may not be what you want to hear, but you cannot do a system from the bottom up, no matter what plan you have or template you use. It just isn't possible.
If division management isn't 'making these things happen which need to happen, something has to change: them, the desire for certification, or the June date.
Her suggestion of staggering dates is a good one.
#27
While I agree with this in principle - one caveat. Make sure that you have a "secure copy" of all our documents at the time of implemetion of the system.
A document with no rev date is not proof that this is the same document used, unchanged, since the inception of the system. Having a "secure" copy allows you to show an auditor that the document on the floor matches the document in the "master folder" and is unchanged.
Peace
James
Dubai_capi
#28
well, the idea behind approaching iso per division separately is to make it easier for them and for me.. am going to do it for the timebeing separately but once i implement it for every division am going to make it one system.. the scope of the system is limited to few divisions which are the core to our organisation.. and your feedback is logical about the one system and not making it multiple systems.. the problem is that i already communicated to them about the multiple quality manuals and i dont know how to communicate again the concept of one quality manual..
also we have a division with external customers that are different from other divisions' customers entirely and the division provide them with entirely different services and if i include it in the same manual it will be confusing..
Dubai_capi
#29
Yes, I would like to thank everyone who participated in this thread and appreciate your feedback..
V
vk20000
#30
I am also QMS,EMS MR for my organization.
I have not understood your problem. Please brief it again. I will definately help you in all respect.
Vijay
qualprod What tier number fits in a company producing paper labels stuck on automotive parts? IATF 16949 - Automotive Quality Systems Standard 7
A Stuck at 'Analyse' stage of DMAIC Improvement Cycle on Cosmetic Specification Manufacturing and Related Processes 10
A Getting Stuck Choosing a Sampling Plan Inspection, Prints (Drawings), Testing, Sampling and Related Topics 6
A PFMEA for an Assembly Process - Stuck in first steps FMEA and Control Plans 6
F Our container of pleasure toys is stuck... regulated as "medical devices" by FDA ? 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 19
J PDCA Cycle - Stuck at D, D, D, D, D... Quality Manager and Management Related Issues 20
A Stuck with Due date as a KPI - Services like evaluation studies ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 0
K Am I the only one stuck working on the 24th Coffee Break and Water Cooler Discussions 39
Jen Kirley Stuck in the eBay help desk spider web! Service Industry Specific Topics 13
Marc 13 Dec 2007 - Stuck in Boston Coffee Break and Water Cooler Discussions 21
G Stuck with Zero Defect target - Manufacturing Waste Target is Zero Inspection, Prints (Drawings), Testing, Sampling and Related Topics 17
Randy ISO 14001 Implementation Schedule - I doing a proposal and I'm stuck! Miscellaneous Environmental Standards and EMS Related Discussions 18
S 510(k) Questions - Do we as the middle-man have to have one? Other US Medical Device Regulations 1
K Implementing ISO13485:2016 in the Middle of a New Device Project ISO 13485:2016 - Medical Device Quality Management Systems 1
W IEC 60601-1-2 Testing Laboratories in the Middle East IEC 60601 - Medical Electrical Equipment Safety Standards Series 1
R Medical Device Authorised Representation Middle East Other Medical Device Regulations World-Wide 1
AnaMariaVR2 Widening Battle: Middle East Cyberattacks Target Oil Producers and U.S. Banks World News 0
I TGA and HC (Health Canada Class 4) in Middle East Countries Other Medical Device Regulations World-Wide 5
J Medical Software Regulatory Requirements for South America and Middle East Other Medical Device Regulations World-Wide 3
P IVD registration requirements in Middle East and African countries Other Medical Device Regulations World-Wide 1
M The Statistical Meaning of "Muddy Middle" - Statistics Terminology Statistical Analysis Tools, Techniques and SPC 6
G Will Artificial Intelligence Replace Middle Management? Philosophy, Gurus, Innovation and Evolution 6
Wes Bucey "In the middle of difficulty lies opportunity." - Einstein Career and Occupation Discussions 2
Marc Cable Breaks Disrupt Middle East and South Asia Internet Access After Work and Weekend Discussion Topics 0
H A Tale of that 'Middle' Finger Funny Stuff - Jokes and Humour 19
Crusader ISO 9001 Update Delayed until the Middle of 2009 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 6
J I am looking for an example of a Layer 2 audit for Middle Managment Document Control Systems, Procedures, Forms and Templates 1
D How do I sell 5s to middle management? Lean in Manufacturing and Service Industries 9
Marc Bye-Bye, Pension! The trend in the US to reduce middle class worker wages World News 17
L How Common is ISO 9001 in Europe and the Middle East? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 1
Q Has Lean Manufacturing put on weight due to Middle Age? Lean in Manufacturing and Service Industries 14
F No Response to Corrective Actions by Middle Management - How do you say sabotage? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 55
G ISO 13485 Certification - Can we get the ISO 13485 certification prior to shipment of the device? ISO 13485:2016 - Medical Device Quality Management Systems 6
Richard Regalado Informational ISO/IEC DIS 27001:2021, to be published soon. IEC 27001 - Information Security Management Systems (ISMS) 0
Q Audit report template ISO 9001/14001 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 13
N Does anyone use SGS for ISO 13485 / CE certification Registrars and Notified Bodies 0
Q Process matrix examples of ISO 9001 & 14001 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 2
S Need ISO 15189:2012 Documentation toolkit. Document Control Systems, Procedures, Forms and Templates 0
chris1price Archiving of paper records - ISO 9001 7.5.3.1b Records and Data - Quality, Legal and Other Evidence 4
M Transferring ISO 17025 from one company to another ISO 17025 related Discussions 1
D Common practices in ISO 9001 deployment ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 17
P Audit check for IT company (ISO 9001) ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 7
M Label Making & Printing Standards ISO / ASTM ISO 13485:2016 - Medical Device Quality Management Systems 5
Sidney Vianna Interesting Discussion Should ISO 9004 be changed from a guidance document to a requirements standard? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 7
Ed Panek ISO 13485:2016 Section 5.5.3 ISO 13485:2016 - Medical Device Quality Management Systems 3
Q Do these certificates of calibration meet ISO 9001 requirements for traceability to NIST? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 12
ebrahim QMS as per ISO 13485, Clause 4.2 Requirements for regulatory purposes for Medical Devices Authorized Representatives. ISO 13485:2016 - Medical Device Quality Management Systems 3
S ISO 2768-mk print call out Other ISO and International Standards and European Regulations 11
T ISO 17024, clauses 4.3.8. and 5.1.1. Other ISO and International Standards and European Regulations 4
