Stuck with Zero Defect target - Manufacturing Waste Target is Zero
Craig H.
#11
To build on what Jennifer had to say about Crosby, "zero defects", according to his philosophy, is NOT, IS NOT, a specification. IT IS NOT!!!!!
It is an attitude. If something goes wrong, we are not supposed to accept it as the normal way of doing business. We should try to figure out why the defect occurred and find a way to first "fix" it with a short term cure, then we should find the cause of the problem and remove it.
As with many philosophies, and IMHO especially with Crosby, it is helpful to borrow from others as well. I especially like Deming.
OK, so zero defects in this case is now the specification (sheesh). The advice given earlier to prioritize the list of improvements is a good one. The best approach IMO, would be to get a measurement of the types of problems and their associated costs, and decide where the biggest improvements can be made for the least amount of investment in time and money. As noted before, trying to change too many things at once can lead to chaos.
Jen Kirley
Quality and Auditing Expert
#12
What Craig said. :agree: :applause: Craig was more clear about the true Zero Defects doctrine than I was. Mr. Director needs to also gain clarity if he has not already done so.
This thread contains a presentation of the seven basic quality tools. These tools can be used, along with the calculators, to help decide which types of defects to target first. You can use ISO system structures to help set up policies, procedures and practices to achieve the goals. After having achieved notable gains in one area, it usually becomes easier to pursue subsequent goals.
What Mr. Director said he wants is "Zero defects" and what you can present toward that is a plan for achievement of targeted defect reduction. Mr. Director needs to understand that organizational turnarounds do not happen quickly, and in most remarkable success stories the line workers are empowered to take on responsibility and authority. If the operators in your organization are not permitted to make certain decisions for high quality, possibly this cultural change may be your first, and most challenging, task.
Good luck and keep visiting!
chergh - 2008
#13
Reading your post reminded me of this post:
http://elsmar.com/Forums/showthread.php?t=13669
It's not quite the same as your goal but it is a great achievement.
Now just because Toyota managed to pull something like this off doesn't mean everyone can but it does show what is possible with the appropriate mindset and management support.
Good luck with your KPI.
ScottK
Not out of the crisis
#14
Hi all
I need some advice.
I am having a new director who recently joined our company - and the first KPI that he want our Mfg waste target to be at Zero. No make-up or re-issue material if there is any defect found in process.
I am stuck with this target "Zero" waste KPI.
Perhaps I am too inexperienced to argue.
Is it possible to set the waste target "Zero" in Mfg ?
I have to come out with a realistic plan & I have no clue how to bring down the waste to zero.
And worst, this has become my performance KPI.
Hope some expert can help.
Thanks.
Does "waste" = "defect"?
One way a former company I worked for (PVC extrusion) targeted "zero waste" was through recycling. All process waste was either recycled in house or sold to a recycler.
So physically there was very little waste material accounted for.
Of course, there was still monetary loss, but it didn't count toward the "waste material KPI".
Seems to me that in printing you can't possibly eliminate process waste because each machine needs a certain amount of set up material.
If this material can be recycled you may be able to get it out of the overall waste stream, though.
G
goallout - 2009
#16
I like what Craig has pointed out that having too many changes can create chaos. And that is exactly what my Mr Director did when he came aboard. He start changing things so fast ... it is creating tension all over the place.
And because he is Mr Director, everyone is helpless ... i am hoping he will "bounce" to this forums (one fine day) to have a better understanding.
Jen Kirley
#17
The problem with changing too many things at once is that it can be hard to tell what is working and what is not.
That's why we recommend settling on specific goals based on their value, level of criticality or perhaps their ability to contribute to another process that brings value.
When a new manager comes into position it can be terribly tempting to create a flurry of improvement. We want to look good, but again I stress that it can be hard to know what is working and why, or why not. Chaos.
Money usually talks very loudly to Directors, which is why I sent you the calculators. Such calculators can also measure effects like people leaving and replacement costs: turnover, if they become fed up with Mr. Director's methods.
If your Director is deaf to this advice, there may be little you can do except to document your best efforts to bring the company's success.
qualprod What tier number fits in a company producing paper labels stuck on automotive parts? IATF 16949 - Automotive Quality Systems Standard 7
A Stuck at 'Analyse' stage of DMAIC Improvement Cycle on Cosmetic Specification Manufacturing and Related Processes 10
A Getting Stuck Choosing a Sampling Plan Inspection, Prints (Drawings), Testing, Sampling and Related Topics 6
A PFMEA for an Assembly Process - Stuck in first steps FMEA and Control Plans 6
F Our container of pleasure toys is stuck... regulated as "medical devices" by FDA ? 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 19
D Stuck in the middle of ISO 9001:2008 Implementation ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 31
J PDCA Cycle - Stuck at D, D, D, D, D... Quality Manager and Management Related Issues 20
A Stuck with Due date as a KPI - Services like evaluation studies ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 0
K Am I the only one stuck working on the 24th Coffee Break and Water Cooler Discussions 39
Jen Kirley Stuck in the eBay help desk spider web! Service Industry Specific Topics 13
Marc 13 Dec 2007 - Stuck in Boston Coffee Break and Water Cooler Discussions 21
Randy ISO 14001 Implementation Schedule - I doing a proposal and I'm stuck! Miscellaneous Environmental Standards and EMS Related Discussions 18
P ISO 9001 certification with zero customers? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 11
D Certifying a "virtual" company with zero employees ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 11
Sam Lazzara Time Zero testing in med device aging studies Qualification and Validation (including 21 CFR Part 11) 3
C Are zero defect sampling plans relevant to AS9120B Distributor AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 4
M Zero Defect Sampling Plan Standards Inspection, Prints (Drawings), Testing, Sampling and Related Topics 4
B IATF 16949 Cl. 8.6.6 - Acceptance Criteria - Zero Defects Attribute Data Sampling IATF 16949 - Automotive Quality Systems Standard 2
WCHorn Changing Sampling Accept Number to Zero, Arbitrarily AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 15
F Zero to certification in 6 months! Covegratulations 5
C ISO 9001:2008 Audit Major Finding - Dial Calipers not set to zero ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 16
R Can Cp and Cpk be zero? Capability, Accuracy and Stability - Processes, Machines, etc. 10
W Zero setting of correlation graph when plotting best fit linear regression Statistical Analysis Tools, Techniques and SPC 7
M Zero Tolerancing on True Position using MMC (Maximum Material Condition) Inspection, Prints (Drawings), Testing, Sampling and Related Topics 6
P Rounding Uncertainty to Zero on a Calibration Certificate Measurement Uncertainty (MU) 7
S Justifying the AQL for a Zero (C=0) Acceptance Plan (Medical Device) AQL - Acceptable Quality Level 6
L What is the Cpk for Zero Defects Six Sigma 4
optomist1 Differences and Advantages of using a Zero Positional Tolerance at MMC Inspection, Prints (Drawings), Testing, Sampling and Related Topics 3
S Getting Zero for GR&R Reproducibility? Using Minitab Software 5
V C=0 Zero Acceptance Number Sampling Plan - Question Inspection, Prints (Drawings), Testing, Sampling and Related Topics 2
R Zero Acceptance Sampling Plans 5th edition by Squeglia - Question Inspection, Prints (Drawings), Testing, Sampling and Related Topics 1
M Zero Acceptance Number Sampling Plans for Isolated Lots Inspection, Prints (Drawings), Testing, Sampling and Related Topics 6
P Minitab error: Zero or negative degrees of freedom Using Minitab Software 16
T Zero Failure Sampling Plans Inspection, Prints (Drawings), Testing, Sampling and Related Topics 2
M AQL (Acceptable Quality Level) for Zero Defects AQL - Acceptable Quality Level 13
C Can you change all your WI (Work Instruction) revisions back to zero (0) ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 11
S Is "Zero Accidents" a realistic goal? Occupational Health & Safety Management Standards 101
Chennaiite High Technology Visual Inspection for Casting and Forging Parts - Zero Defects Inspection, Prints (Drawings), Testing, Sampling and Related Topics 11
M Cpk with LSL (Lower Specification Limit) at zero? Statistical Analysis Tools, Techniques and SPC 3
Q Zero-Based Sampling Plan - Governing document or main reference document Inspection, Prints (Drawings), Testing, Sampling and Related Topics 2
P Zero Acceptance Number Sampling Plans, Fifth Edition (e-Book) Inspection, Prints (Drawings), Testing, Sampling and Related Topics 2
K Design of Lot Acceptance Sampling Plan - Zero Acceptance Number Sampling Plans Inspection, Prints (Drawings), Testing, Sampling and Related Topics 27
P Definition S-type Tolerance - Unilateral tolerance where the desired value is 0 (zero) Definitions, Acronyms, Abbreviations and Interpretations Listed Alphabetically 3
C AV equals Zero in Minitab - MSA with 2 Appraisers Using Minitab Software 11
U Zero findings!!!!!!!!!!! First visit back since our registration audit ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 7
I R-sq Value is Almost Zero - Linearity Study Question Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 1
D What does Zero Defects mean? TS 16949 Clause 7.1.2 AQL - Acceptable Quality Level 6
Y What is the confidence level for a given AQL in zero sampling plan AQL - Acceptable Quality Level 4
