I'm a senior mechanical engineer and I'm preparing my end-of study project entitled "preparing the migration to the new new standard IATF 16949".
Can someone please explain to me why we are now using
documented process instead of documented
procedure and what is the main cause of this change.
Thank you for your help
I believe that the difference is in perception, and the intent is pretty much the same. Let's look at the definitions in ISO 9000:2015, which is the standard used to interpret IATF 16949.
The definition of
procedure is "specified way to carry out an activity or a process."
The definition of
process is "set of interrelated or interacting activities that use inputs to deliver an intended result"
So if you substitute the definitions for the words, you would end up with:
Documented Procedure
"Documented specified way to carry out an activity or a set of interrelated or interacting activities that use inputs to deliver an intended result."
vs
Documented Process
"Documented set of interrelated or interacting activities that use inputs to deliver an intended result"
About the only difference I see is that a documented
process would be a higher level document including a "set" of interrelated activities, while a documented
procedure would also include lower level documents which cover individual activities, such as work instructions, etc.
