Submit under a new product code in a 510k?
SSchoepel
Hello, we have a class II device that has two product codes under which companies have cleared their device. One is more software and one is more hardware, but neither exclude the other wholesale so there is a mix of devices (hardware only, hardware/software, software only) in one and mostly software in the other. The benefit of the "other" code is that it can be reviewed by a third-party reviewer. We'd prefer not to use both codes since they are under two different groups in the FDA so would then be reviewed by the third-party AND the FDA.
Is it possible/allowable to submit under a new product code with a new 510k submission? We would then change our listings once cleared under the new code. However, I'm not sure if that would fly with the FDA.
Does anyone have experience switching codes?
shimonv
It depends on how well the new product code describes your product and also what is the product code of your predicate. FDA may ask you to change the product code to something more suitable.
SSchoepel
That's the problem, both could describe the product. Many new ones have used the "other" code because it's a 3rd party review and seems to be a little less scrutinized. I'm not sure if the FDA would push back on the re-categorization. (I also believe they have two codes that are too similarly used but have different requirements and should combine them.)
I hope others have experiences so I can see if this is a viable thing to do given that I am being asked about making that change.
mihzago
I don't understand why you wouldn't want to include both codes. It's very common to identify the primary and secondary (subsequent) product codes.
Why would your device be reviewed by the FDA and a third-party?
Your primary code should be the same (in most cases) as the main predicate you use to claim substantial equivalence.
SSchoepel
The two codes are in two different areas so would get review by both teams at the FDA, which could lengthen the review process.
Historically the product was cleared under the more product code that doesn't allow 3rd party review and has a FDA review group that seems to hold the devices to a much stricter set of claims. The other product code wasn't supposed to have devices like ours but has expanded as companies have pulled apart their devices into "modules" and used the same code, reviews seem to move faster, and have fewer requirements for documentation submitted and proof based on a review of the two codes.
mihzago
The submission would not be reviewed by both teams or assigned to two lead reviewers, unless you send two separate submission. FDA does not have that many resources. At most, a lead reviewer may ask for a consult from an SME in another branch, but that will not extend the time beyond FDA's review goal, i.e., 90 days.
3rd party review is a an option to you, but it's not a requirement or something automatically imposed on you. Just because a 3rd party review is available for a product code does not mean your submission will go to them. They charge a lot of money for it so the FDA cannot force you to do that either.
And even when a 3rd party performs the review, FDA still reviews parts of the submission and 3rd party's recommendation, and make final determination, so the 3rd party cannot be simply less strict.
It is possible that one branch may be more difficult than another, so if you have a predicate with the primary product code within the preferred branch, then submit under that classification/product code. The agency could still assign it to another branch depending on reviewer availability and expertise.
If reviewers have less to review because the device is simpler (e.g., software only vs. software/hardware) or if they have to review fewer modifications, then naturally the review will go smoother and possibly faster, but that's because the submission is simpler, not because somehow two branches are involved or two codes are applicable.
I don't know what your device is or what product codes in question, so maybe you are in a really weird situation, but still my advice is to select the product code based on your most appropriate predicate device.
D Does Manufacture can submit CE mark application under MDD with NB for his New product after May 2020? EU Medical Device Regulations 4
B How to submit Pre-submission to FDA? US Food and Drug Administration (FDA) 4
shimonv Can you submit a traditional application for a class I device? Other US Medical Device Regulations 7
L UDI needed when we submit to ON? EU Medical Device Regulations 5
S Submit to Health Canada with only MDSAP report? Canada Medical Device Regulations 5
supadrai Possible to Submit a 510(k) if you have never, do not and cannot produce the device for which you're submitting the application? US Food and Drug Administration (FDA) 4
F How to submit a PPAP when a subcontractor is the sole manufacturer IATF 16949 - Automotive Quality Systems Standard 2
gunnyshore Adding a new facility - do I need to submit an amendment to the MDL or MDEL, or both? Canada Medical Device Regulations 3
F How to submit PPAP without IMDS APQP and PPAP 10
M Informational TGA presentation: How to submit an effective good manufacturing practice clearance application Medical Device and FDA Regulations and Standards News 0
Watchcat EU Certification - What do you submit to an NB EU Medical Device Regulations 5
B Submit a 510(k) with a Predicate cleared but not Listed US Food and Drug Administration (FDA) 11
L Reasons to submit a new PPAP or notify the customer APQP and PPAP 3
L 510k exemption process - Do you still need to submit technical dossier? 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 5
N How to deal with catalog parts suppliers who refuse to submit PPAP documents? APQP and PPAP 0
I Where to submit Adverse Events Reports in Europe EU Medical Device Regulations 7
B Should I Request/Submit a PPAP from/to a Supplier/Customer for only Repackaging Parts APQP and PPAP 7
Ronen E FDA releases new draft guidance on when to submit a 510(k) for device modification Other US Medical Device Regulations 10
B Submit a Special 510(k) or "Documentation by our own" 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 5
L 20 days to submit PPAP APQP and PPAP 9
J Can we submit data with Special 510(k)? US Food and Drug Administration (FDA) 8
A Using Regulations.gov to Submit Comments on FDA Guidance Documents Other US Medical Device Regulations 5
E When to submit a Technical File for a Class IIb Medical Device EU Medical Device Regulations 3
P Do we need to submit Special 510K for a Blood Glucose System? 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 4
D Customer will not submit Purchase Orders - System for ISO 9001 Compliance ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 16
L Can we submit an AS9102 if we are not AS9100 certified? AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 10
S Guidance to prepare and submit a Level 3 PPAP to a Customer APQP and PPAP 6
I Where do we submit the FAA Preapplication forms? Federal Aviation Administration (FAA) Standards and Requirements 1
O Medical Device Registration in EU - Which Ministry to submit Technical File? EU Medical Device Regulations 9
S How to Submit ISO/TS 16949 & ISO14001 Certificates to HMMA IATF 16949 - Automotive Quality Systems Standard 4
W Submit MDR for a device cleared by FDA but not sold in US? 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 2
P Part Submission Form - Need to submit PSW only once? APQP and PPAP 5
M If I update a DFMEA do I need to submit to my Customer? FMEA and Control Plans 7
C When to submit a 510(k)? After the DMR (Device Master Record) is finished? Other US Medical Device Regulations 4
A Should I submit the entire copy of my software in a 510(k) submission?? US Food and Drug Administration (FDA) 7
Howard Atkins Is there a time frame for CBs to submit the TS 16949 Audit Report? Registrars and Notified Bodies 2
J What is the time limit for an auditor to respond to NCR's and submit audit report? AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 7
shimonv Deciding When to Submit a 510(k) for a Change to an Existing Device 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 17
sagai New Draft Guidance - When to Submit a 510(k) for a Change to an Existing Device 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 4
B Deciding when to submit a Special 510(k) US Food and Drug Administration (FDA) 10
S How to locate a Sponsor in Australia to submit Product Approval Applications by TGA Other Medical Device Regulations World-Wide 5
R In 510k application do we submit documents showing compliance with 21CFRPart820 Other US Medical Device Regulations 12
P Does our company need to be certified in order to submit a 510k Other US Medical Device Regulations 4
C How to Submit an Expansion of Claims 510(k)? 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 9
A Before the ISO-9001 certification audit can we submit the documents to our customer ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 8
N Can I submit 510(k) without Biocompatibility Test Results? 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 2
C When to Submit a 510(k) in the Product Life Cycle 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 3
W Is Foreign Exporter required to submit a 510(k)? 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 2
C Do we have to submit a new 510(k) for a device with a new MCU? 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 12
E Do I need submit a traditional 510(k) or Abbreviated 510(k) 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 10
