Substance based Medical Device Classification under MDR - Rule 21
Hello everybody!
I’m studying the new MDR for medical device and I have a question related to classification. One of the new rule introduced in the MDR is the rule 21 which includes substance based medical devices. If I well understood all these medical devices will be classified under rule 21 and the class of risk will vary depend on the product absorption.
Can you give me practical example for each risk class (IIb, IIa and III)?
I have a medical device (substance based) for the treatment of acidity and gastroesophageal reflux which acts in the stomach but is then evacuated through faeces. In which class does it fall?
I think class IIb, rule 21 but I’m not sure.
Thank you in advance!
RobertvanBoxtel
The product you refer to and when you can prove the intended purpose and related mechanism of action not to be pharmacological (Etc), most likely it will be considered a medical device. Be sure that you can prove the mechanism of action and that indeed it is not absorbed in the body.
Regarding rule 21:
that is a correct assessment, if indeed the absorption is not applicable.
pkost
Devices that are composed of substances or of combinations of substances that are intended to be introduced into the human body via a body orifice or applied to the skin and that are absorbed by or locally dispersed in the human body are classified as:
— class III if they, or their products of metabolism, are systemically absorbed by the human body in order to achieve the intended purpose;
— class III if they achieve their intended purpose in the stomach or lower gastrointestinal tract and they, or their products of metabolism, are systemically absorbed by the human body;
— class IIa if they are applied to the skin or if they are applied in the nasal or oral cavity as far as the pharynx, and achieve their intended purpose on those cavities; and
— class IIb in all other cases.
If you are looking at a sodium alginate type product then that would be Class III as it achieves its purpose in the stomach; it is irrelevent that the products are not systematically absorbed
It is introduced orally; it is intended to locally disperse in the stomach. It achieves its intended purpose in the stomach
you may be able to justify IIb if you can demonstrate that the action is achieved by coating the oesophagus (you can't do this with sodium alginate though)
Ben S UK
Is there a definition of 'systemic absorption'?
I imagine most substances that enter the stomach, will to some extent be absorbed. I'd be keen to know how this is intended to be interpreted?
cam5603
I have the same issue with a product : spray for ear hygiene.
For me the rule 21 has to be applied (Invasive medical device containing a substance (sea water) locally dispersed in ear).
I think that it could be a class IIb ? What do you think ?
I have a similar issue with that rule 21.
We produce a sterile gel intended for cleansing eyelids affectd by pathology, helping maintain hydratation and encouraging healing.
Under the MDD it is a non invasive which comes into contact with injured skin and belongs to class IIa.
Under MDR this rule still applies but there is also rule 21 and this bit :
I is still a IIa medical device but the only difference is that under rule 21 we have to perform studies such as those described in annex II 6.2c :
- absorption, distribution, metabolism and excretion;
- possible interactions of those substances, or of their products of metabolism in the human body, with other devices, medicinal products or other substances, considering the target population, and its associated medical conditions;
- local tolerance; and
- toxicity, including single-dose toxicity, repeat-dose toxicity, genotoxicity, carcinogenicity and reproductive and developmental toxicity, as applicable depending on the level and nature of exposure to the device.
Our device is not intended to be introduced into the body but is that enough to avoid this rule ?
Q
Quita
Hi TycoSQR,
What did you decide about the studies in annex II 6.2c?
Thanks in advance for your reply!
Hi TycoSQR,
Sorry for the late reply.
We will try to assess the mode of action of each substance through literature review and if possible prepare a rational to justify not performing ADME studies required.
If the information is not present our provider will propose additional tests that may be able to mitigate the need for ADME tests.
I guess I will know if it worked by the end of Q1 2019.
Q
Quita
Hi TycoSQR,
Sounds like an acceptable approach! What kind of additional tests are you referring to? And could you please let me know if it worked end of Q1? :)
Many thanks in advance!
Hi everyone,
What a interesting discussion!
As you mentioned before there are a different issues related with the new rule 21. The first question coming into my mind is about the definitions of "locally dispersed" or "sistemically absorved". Regarding these questions... do you know if it is there some documents availables related with this terms??
My feeling is that even you can prove the inteded prupose and related mechanism of action of the device correctly if there is not any definitions which match with any phenomen... The demonstration is not without doubts.
Btw, the ADME tests referred above are only placed with the aim to characterize pharma devices but no for medical devices (yet). Thus, IMO the verification and/or validation of this kind of devices -which can be related with rule 21- will be conducting through a new Commmon Specification or a new specific standard for these devices. So what's your opinion on that point? Do you recieve any feedback from NB regarding these issues?
Thanks!!
M Medical device substance based-leachables Other Medical Device Related Standards 2
M How to Develop a Sampling Plan for Drug Substance? Inspection, Prints (Drawings), Testing, Sampling and Related Topics 0
M Europe GMP medical devices - Combination products - Ancillary medicinal substance CE Marking (Conformité Européene) / CB Scheme 4
M ISO 10993-17 - Ancillary Medicinal substance leachables Medical Device and FDA Regulations and Standards News 3
K Contains hazardous substance symbol EU Medical Device Regulations 1
A Teamcenter Substance Module RoHS, REACH, ELV, IMDS and Restricted Substances 0
D Substance of concern (SOC) management procedure wanted Reliability Analysis - Predictions, Testing and Standards 3
S Compliance to GADSL (Global Automotive Declarable Substance List) RoHS, REACH, ELV, IMDS and Restricted Substances 4
B Mitigation of emission of flames, molten metal, poisonous or ignitable substance IEC 60601 - Medical Electrical Equipment Safety Standards Series 2
P Dimethylnitrosoamine CAS:62-75-9 as prohibited substance acc. GADSL RoHS, REACH, ELV, IMDS and Restricted Substances 5
W REACH - Candidate List Substance vs. Authorisation List Substance in EEE RoHS, REACH, ELV, IMDS and Restricted Substances 1
T Mercury is covered under RoHS but is not a substance of very high concern (SVHC) ? RoHS, REACH, ELV, IMDS and Restricted Substances 2
Q Restricted Substance in my Product - How to declare problem? RoHS, REACH, ELV, IMDS and Restricted Substances 3
Q SVHC (Substance of Very High Concern) Declaration for Packaging Material RoHS, REACH, ELV, IMDS and Restricted Substances 1
Kales Veggie Ford RSMS (Restricted Substance Management System) 2008 released / GADSL categories RoHS, REACH, ELV, IMDS and Restricted Substances 16
Kales Veggie Global Automotive Declarable Substance List (GADSL) 2009 released..... Miscellaneous Environmental Standards and EMS Related Discussions 2
M How To Include Substance of Concern (SOC) Free Into TS16949 Internal Audit Plan IATF 16949 - Automotive Quality Systems Standard 1
Z 'Duty to Declare' substance - Is submission of IMDS sufficient? RoHS, REACH, ELV, IMDS and Restricted Substances 2
E The EU regulation for 'Restriction of hazard substance' (RoHS)? RoHS, REACH, ELV, IMDS and Restricted Substances 5
G Trying to find CAS numbers - The Database of chemical substance information IATF 16949 - Automotive Quality Systems Standard 3
S Is Toluene (Methylbenzene) a banned or restricted substance Miscellaneous Environmental Standards and EMS Related Discussions 4
M Substance reporting for PPAP GMW 3059 APQP and PPAP 41
N Incoming Product Quality - Receiving inspection for chemical substance Inspection, Prints (Drawings), Testing, Sampling and Related Topics 3
A ISO 9001- any advise please with transitioning from a paper based system to eQMS and multi site scope ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 1
L Do non-EU based manufacturers require an importer/distributor? EU Medical Device Regulations 18
D Integrated Management System (IMS) - Process Vs Clause Based Audits ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 19
C Need help in determining applicable clause for an audit finding (based on AS9120B) ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 4
A Information on Process-based Internal Auditing Needed Internal Auditing 6
M ADME data- substances based MD EU Medical Device Regulations 0
E Which regulatory framework for an app-based study for research purposes? EU Medical Device Regulations 1
J Cloud Based System Qualification and Validation (including 21 CFR Part 11) 7
R Does anyone use iQMS for their ISO based document control? Manufacturing and Related Processes 1
C What Theory is MIL-STD-105E Sample Size Code Letters Based on? Quality Tools, Improvement and Analysis 3
N QMS standard for a research based Organisation Quality Manager and Management Related Issues 1
R Cloud-based SaMD Validation IEC 62304 - Medical Device Software Life Cycle Processes 8
S How many tester quantity we need on the line based on the cycle time and peak volume Manufacturing and Related Processes 3
S Alcohol based cleaner for Food Contact Surface? Food Safety - ISO 22000, HACCP (21 CFR 120) 0
I Excel based Gage R&R VS Minitab calculation Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 5
P Scenario based risk assessment IEC 27001 - Information Security Management Systems (ISMS) 1
C CBD based products registration in EU and UK EU Medical Device Regulations 4
L Economic Operator based in UK EU Medical Device Regulations 10
C Biologic Evaluation based on ISO 10993-1 EU Medical Device Regulations 2
R Select the 1 Supplier based on the Parts Durability from 6 Supplier Samples using Minitab Using Minitab Software 11
H Existing cloud based medical device - questions regarding improving the processes IEC 62304 - Medical Device Software Life Cycle Processes 6
A % of defects on the whole batch based on result from inspection under AQL Level II Inspection, Prints (Drawings), Testing, Sampling and Related Topics 6
Ed Panek Does this FDA Requirement Apply to international (not USA) distributors for USA based manufacturing companies? 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 0
R X-RAY Based Diagnostic Veterinary medical Devices Medical Device and FDA Regulations and Standards News 2
M Reduce occurrence rating based on the PMS data and customer complaint data ISO 14971 - Medical Device Risk Management 2
K Interesting Discussion "World Class Product" based QM. I need advice. Quality Management System (QMS) Manuals 14
