Successful 1st Gage R&R Study...but
E
energy
#11
Seen one used a couple of times
Bob_M said:
My BASIC understanding of Gage R&R tell me you SHOULD be using production stock/material/parts during the test.
Not knowing what a profilmeter is exactly, are you CALIBRATING the gage as well against a standard? Was the calibration results prior to the R&R within tolerance?
The Profilometer? has a stylus that moves back and forth over a surface and measures surface finish. It kind of looks like those things on a polygraph moving back and forth on chart paper. Anyway, the instrument is calibrated against a know standard. I wasn't aware that it leaves marks on the surface. We requested profilometer results on polished Stainless seamless piping and it was on the actual part we purchased. No evidence of "etching". :p ;)
N
noboxwine
#12
Msa
Bob_M said:
Shoulld some REALLY be out of spec? Would the AIAG MSA manaul really tell me to make BAD parts on purpose just for R&R? To be honest, some of our parts couldn't possibly be made "bad" unless the die broke or the wrong material thickness was used... *shrug* Maybe our real conditions are better than the "typical" user.
Metal B: I believe (only one coffee so far today..) the MSA says the parts must be selected from the process itself and represent the entire operating range. I have always done that but found it not a bad idea to have at least part outside one limit just to further quantify the system. Never had a customer or auditor question it and most importantly, I like the additional assurance. (Wish I could only make a bad part when a die explodes...... :vfunny:)
Bob_M
#13
OK that makes sense. I've typically taken the ten randoms parts from production (or from a 100 pc PPAP sample run). I was not trying to brag, but we make basic metal stampings that typically do not deviate much (thus we need stuff like SPC readings to often). If instructed to, we still couldn't make too many bad parts on purpose without risking die destruction (well not the ones we COULD use for R&R studies).
Bill Ryan - 2007
#14
Although this is off the original profilometer question, we don't produce parts out of tolerance specifically for a Gage R&R either. I have taken parts for attribute studies and physically altered them (with a BFH :eek: ) so I did have "bad" parts to show on the form. I have done the same thing for a variable study, but rarely. The whole intention of a Gage R&R is to prove out that the gaging methodolgy, as well as the gage itself, are adequate to tell you what you need to know about a particular feature (good data in = good data out). It's just as important (if not more important) that the gage "tells" you when you have a nonconforming part as it is when "telling" you it is conforming. Therefore, the more of your tolerance you can cover (even out of tolerance) during the study, the more confident you would be in your measurement "system".
Wow, that's way too much for me to be writing on a Friday :ko:
Bill
cslauenwhite - 2009
#15
My reason for asking is that using a profilometer on a casting can be/is considered a "destructive" test as the material actually gets etched and when we perform an R&R on the part, the results are, typically, well over 20%. Don't know if it's the same thing on a steel surface.
Bill
:agree:
Bill.
Profilometers and surface finish testers in general are considered a destructive test for C1010-C1020 steel. The point of the gauge which is measuring is a sharp diamond being dragged across the surface. Now don't get me wrong the damage is very minimal but for the sake of accuracy the first reading and the last reading in the same spot will be effected by this dragging. Will you see this as error in a GR&R sure. Will it be a contributing factor to the outcome; probable not.
My only advice is that for TS keep a good record of the GR&R failing the 10% but have the validation stating that 12% was evaluated and found to be acceptable in this circumstance.
cslauenwhite - 2009
#16
Re: Seen one used a couple of times
:2cents:
Energy,
The stylus does not move back and fourth like a record player but rather A diamond stylus is moved vertically in contact with a sample and then moved laterally across the sample in a stright line for a specified distance and at specified contact force.
Also the stilus does leave a mark as it is a diamond and harder always marks softer material but the radius of diamond stylus ranges from 20 nanometers to 25 μmso the mark left will be very narrow, shallow and short. Unless you know the location of the inspection it will be very hard to find.
:thanks::thanx::thanks:
E How to start running a successful 5S program? Lean in Manufacturing and Service Industries 11
V Characteristics & Objectives of successful QbD (Quality by Design) program US Food and Drug Administration (FDA) 8
harrysons Thanks to Elsmar Cove - Successful TS16949:2009 Certification Covegratulations 10
M Which are essential qualities to become successful in Medical Device QA & RA? US Food and Drug Administration (FDA) 7
K Successful Audit: Thanks for your help! ISO 13485:2016 - Medical Device Quality Management Systems 10
C Successful AS9100 Audit - Thank You to everyone here AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 5
C Certificate statement for Successful Completion of Training Document Control Systems, Procedures, Forms and Templates 1
D Successful Validation = Reduced Inspection? No Inspection?? ISO 13485:2016 - Medical Device Quality Management Systems 7
L Successful AS9100 certification audit AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 13
E Successful Gage R&R Anova or X/R? Need example Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 6
C Examples of successful 5S projects - Introducing 5S on the shopfloor and the offices Lean in Manufacturing and Service Industries 8
Marc German Scientist Reports Successful Tests Of ?Anti-Stupidity? Pill... Coffee Break and Water Cooler Discussions 13
Crusader ISO 9001 Registration Audit Successful! ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 4
D Successful ISO 9001:2000 Certification Audit and questions on auditors ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 4
E TS 16949 Registration Audit - Successful! IATF 16949 - Automotive Quality Systems Standard 14
M Successful Registration! ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 6
M ISO 9001 Certification - Successful First Registration Audit? (Poll) ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 76
T Opinions from Successful Registrations??? IATF 16949 - Automotive Quality Systems Standard 4
S Successful TS 16949:2000 Registration Audit IATF 16949 - Automotive Quality Systems Standard 17
J Successful ISO 9001:2000 - Celebration!!! ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 11
A Successful 9001:2000 Certification Stories ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 2
D Successful Registration QS-9000 - American Automotive Manufacturers Standard 1
T Sample of 1st Article Inspection Report wanted APQP and PPAP 3
K China UDI Implementation for October 1st 2019 China Medical Device Regulations 4
J AS9100D Sections related to 1st Piece and In-Process Inspection Manufacturing and Related Processes 15
V Handling decomissioned line/equipment during 1st time product-based inspection US Food and Drug Administration (FDA) 1
A 1st Time Purchase of Aluminum Extrusion - First Article? Inspection, Prints (Drawings), Testing, Sampling and Related Topics 3
Q Effective 1st Piece Inspection Sign Off Procedure Quality Manager and Management Related Issues 8
S 1st AHWP-RAPS Joint Conference @ KL, Malaysia 2-3 Dec 2013 Other Medical Device Regulations World-Wide 2
A Publication Dates of MSA Manuals (1st & 2nd Ed.) Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 4
D QMS 1st Cycle - Indicators and Data ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 18
N 1st Shift vs. 2nd Shift Production Crews - How to end this war? Career and Occupation Discussions 15
W Is there an IEC 60601 3rd Edition 1st Amendment? IEC 60601 - Medical Electrical Equipment Safety Standards Series 3
Q Using Traceable Standards - AIAG MSA Manual Chapter II, Section B, 1st bullet Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 4
M Class I Medical Device - 1st notification and change notification EU Medical Device Regulations 4
K Raw Materials from 3rd World Countries vs. Finished Products from 1st World Countries Philosophy, Gurus, Innovation and Evolution 23
somashekar Medical Device Regulation - Singapore - 1st May 2010 Other Medical Device Regulations World-Wide 4
N What is a ?Reasonable? failure rate for an electronic device in the 1st year? Quality Tools, Improvement and Analysis 7
J FAA Training suggestions wanted for Sept 1st week Federal Aviation Administration (FAA) Standards and Requirements 5
N Nonconforming Product - 1st Piece Rejection Nonconformance and Corrective Action 3
G APQP 1st edition VS APQP 2nd edition - what are the main changes APQP and PPAP 2
CarolX Blueprint numbering for 1st Article submission Misc. Quality Assurance and Business Systems Related Topics 13
C Passed the CQE (Certified Quality Engineer) exam 1st time Professional Certifications and Degrees 23
C 1st Gage R&R Results help Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 48
J Final Inspection - 1st Article Dimensions before Anodize and Passivation Inspection, Prints (Drawings), Testing, Sampling and Related Topics 4
P Digital Camera 1st DSLR Coffee Break and Water Cooler Discussions 10
ScottK ISO9001 - 1st Surveillance less than 6 months after registration ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 8
R AIAG's FMEA Manual 4th Edition pushed back to 1st quarter 2008 FMEA and Control Plans 16
CarolX Definition 1st, 2nd and 3rd Party Audits - Definition Definitions, Acronyms, Abbreviations and Interpretations Listed Alphabetically 29
