Sufficient measurement of length - 4:1 TUR - Basic 25ft tape measures
N
NWrubberQA
With products that indicates the length in mm with +/- 3 to 5 mm tolerance we have used basic 25ft tape measures with inches and metric. Problem is that I can only find them reading to 1 mm. For 4:1 TUR I would need graduations of at least .5 mm. I can't find any like that. Any ideas or suggestions?
Hershal
Metrologist-Auditor
What is the tape being used to measure?
Typically a tape of that length may have only graduations of 1mm, but the lines themselves will come close to that. The line width also needs to be accounted for in your uncertainty budget.
The metal rules with very fine markings will provide the resolution you seek I believe, but they are usually not very long and not well suited to a field environment.
Hope this helps.
brahmaiah
Generate an error of 0.5mm in the tape exactly. You will get 0.5 marking automatically.
V.J.Brahmaiah
Hershal
Metrologist-Auditor
You may be able to find a metal rule that long with fine lines, but it is not likely to be cheap. If you get one, make sure you get an accredited cal, with actual reported uncertainty or you will be unable to calculate TUR.
Hope this helps.
A MSA - Measurement System Analysis: Is compliance to 2nd edition sufficient? Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 5
C Where to draw the line for "sufficient evidence" to verify safety/performance of a device? CE Marking (Conformité Européene) / CB Scheme 2
M Informational How to perform a clinical evaluation of medical devices – Part 2 – Level of clinical evidence and what sufficient clinical evidence means Medical Device and FDA Regulations and Standards News 9
M GDPR - Is anonymizing sufficient to address right to erasure? Medical Information Technology, Medical Software and Health Informatics 3
R Demonstrate how sufficient levels of access to data is achieved - Claims of equivalence EU Medical Device Regulations 3
CPhelan Do you require MDSAP for CE Marking of a Medical Device or is ISO13485:2016 with clinical data sufficient? CE Marking (Conformité Européene) / CB Scheme 6
M Is referenced content sufficient to meet record content requirements? 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 4
R Is PFMEA (Process FMEA) for OEM sufficient to address Risk? ISO 13485:2016 - Medical Device Quality Management Systems 7
J Is it sufficient to send in my instruments for calibration every second year? Manufacturing and Related Processes 2
J Is MS Outlook a sufficient reminder to perform yearly supplier evaluations? Quality Manager and Management Related Issues 10
S Read Only & Password Protected - Sufficient to Control Documents under 4.2.3? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 4
GStough Is "Did Not Follow Procedures" Sufficient for RCA? Problem Solving, Root Cause Fault and Failure Analysis 30
C Is our method of Traceability sufficient? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 2
A Are RoHS compliance certs sufficient to qualify material? RoHS, REACH, ELV, IMDS and Restricted Substances 6
R ISO 17025 sufficient enough to drop ISO 10005 Quality Plan? ISO 17025 related Discussions 1
T Does FDA consider Flow Charts sufficient instruction for SOPs? 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 2
W Is an Oven I/O/Q Validation Required or is Calibration Sufficient? Qualification and Validation (including 21 CFR Part 11) 7
P Rework Notification - Is it sufficient to show how we control rework process Manufacturing and Related Processes 1
D ISO 2859 - Probability that sample size is sufficient Inspection, Prints (Drawings), Testing, Sampling and Related Topics 2
N Preparation time for the 'spring' RAC Exam - sufficient time? Professional Certifications and Degrees 1
J Determining sufficient data points to commence sampling for in-process inspections Inspection, Prints (Drawings), Testing, Sampling and Related Topics 3
K Recall or advisory notice sufficient for software ISO 13485:2016 - Medical Device Quality Management Systems 9
J Coming up with initial policies sufficient to get everyone headed on the right track ISO 13485:2016 - Medical Device Quality Management Systems 3
D Would Design & Process FMEA (PCBA) be sufficient to fulfill requirement of Cl 7.1? ISO 13485:2016 - Medical Device Quality Management Systems 2
Z Design and Development Planning - Is It Sufficient and Practical or Not Design and Development of Products and Processes 0
Z 'Duty to Declare' substance - Is submission of IMDS sufficient? RoHS, REACH, ELV, IMDS and Restricted Substances 2
I Controlled Documents - Would storing documents as PDFs be sufficient for control? Document Control Systems, Procedures, Forms and Templates 12
R Corrective actions which are not sufficient or are rejected for minor nonconformances ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 12
R Process Auditing - Identifying/Monitoring "Key" Processes Sufficient? Process Audits and Layered Process Audits 5
D Are measuring equipment manufacturer calibration certificates (certs) sufficient? QS-9000 - American Automotive Manufacturers Standard 6
D Customer Supplied Product - Is a list of all customer supplied product sufficient? Document Control Systems, Procedures, Forms and Templates 2
Marc Brute Force Validation - Difficult to show 10-year calibration cycle is sufficient General Measurement Device and Calibration Topics 0
P Type of MSA study according to measurement equipment Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 2
CaliperJim Temperature and Humidity Effects on Measurement Devices General Measurement Device and Calibration Topics 2
E Audit Finding - Measurement of Process - Continuous Improvement - Trend Analysis Oil and Gas Industry Standards and Regulations 22
Rene Minassian Control of (TMME) Testing and Measurement Equipment Oil and Gas Industry Standards and Regulations 2
R DIGITAL MEASUREMENT DEVICE Manufacturing and Related Processes 2
R First Time Managing Calibration and Measurement System. Need Help. General Measurement Device and Calibration Topics 19
J Not able to repeat measurement at the same location General Measurement Device and Calibration Topics 7
Ron Rompen Convert Linear Measurement to Angular Measurement General Measurement Device and Calibration Topics 3
Q Resolution of Measurement Device for a 50' Coil Reliability Analysis - Predictions, Testing and Standards 1
Ron Rompen Assistance with perpendicularity measurement Inspection, Prints (Drawings), Testing, Sampling and Related Topics 10
G QSB+ : capability of measurement equipment IATF 16949 - Automotive Quality Systems Standard 15
B Measurement Calculations vs ASME Y14.5 Various Other Specifications, Standards, and related Requirements 2
S Measurement of threaded holes ISO10578 or ASME standard Measurement Uncertainty (MU) 3
S Comparing measurement results for a part from two ring gage General Measurement Device and Calibration Topics 3
B Building my own measurement equipment General Measurement Device and Calibration Topics 3
P Test Method Validation (TMV) for all Measurement Methods in Rec/Inspection Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 1
J Keyence Measurement Systems General Measurement Device and Calibration Topics 3
