Suggest a Poka Yoke (Mistake Proof) Method for my Product
DRAMMAN
#21
Adding counters is always a good thing. The challenges I have had in the past with counters is if you have times when the PEM's get stuck and don't feed. Regardless, adding a counting set-up is always a good approach. My experience is that these types of assembly scenarios require reduntant controlls. Good operator training, extra inspection, automated counters,etc.
Wes Bucey
Prophet of Profit
#22
This is a common problem in sheet metal shops so after posting my last idea I did some more investigation and think I have come up with a ?better? idea. My last suggestion was to check the parts on a CMM, but that adds an extra operation and time to the process. I am now working with our maintenance man to build a counter that can be programmed to count the number of strokes on our PEM Setter. It will have a red LED and a green LED. The setup man can program the number of strokes the PEM Setter is supposed to cycle based on the number of inserts in the part. The red light will remain on until the correct number of strokes is counted and then the red will go out and the green will come on. At this point the operator will know that the correct number of PEMs have been inserted. The operator will then grab a new part and hit the reset button turning out the green light and relighting the red light to start the cycle again. This will preclude having to handle the parts another time and thus cut down on the cost. Theoretically this should work.
Of all the foregoing suggestions, this one strikes my fancy as being the most economical and elegant solution.
It eliminates cost and time to design and build a jig. It eliminates programming optical inspection machine and then moving the assembly to a scale or optical inspection machine, positioning it, then moving it again.
The spaghetti diagram of some of the solutions offered would defeat me before I began.
tori2432
#23
I would suggest a jig that doesn't release the part until it is full. But without seeing it firsthand, I can't really tell.
Ronen E
Problem Solver
Moderator
#24
Problems?...
1. It doesn't address the OP's question (too specific).
2. It assumes a counter already installed.
3. It only addresses assembly of identical parts in a single operation (otherwise, multiple counters will be required)
4. I'm not sure how robust it is (need more details about the specific process). The post above yours discusses some vulnerability, and suggests that redundancy will be required.
DRAMMAN
#25
Counters are great, but are usually not fool prof. What about misfeeds? Just want to make sure you have that covered. Regardless a stroke counting system can greatly reduce error rates. Also, check with your equipment supplier. They may already sell counters for your PEM setter. I look forward to pics of your counting system.
T Help to Suggest name for a new certification and inspection company Coffee Break and Water Cooler Discussions 7
0 Suggest a Lean Book for Upper Management Lean in Manufacturing and Service Industries 6
V Suggest Packing Instructions for Electrical Control panel Document Control Systems, Procedures, Forms and Templates 4
A Please suggest analysis for identifying the warranty Reliability Analysis - Predictions, Testing and Standards 1
Q Please suggest how to improve Cosmetic Visual Inspections Inspection, Prints (Drawings), Testing, Sampling and Related Topics 10
S Suggest a book that clearly demonstrates ISO 13485 Implementation Book, Video, Blog and Web Site Reviews and Recommendations 1
S Can you suggest a Root Cause supporting Out of Specification Process AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 7
K Can you Suggest KPIs for a Business Process Improvement Team? Pls. Benchmarking 4
N Which Seminars Would You Suggest For Me? Career and Occupation Discussions 3
A Suggest Computer Aided Quality Assurance (CAQ) software for Medical Devices Quality Assurance and Compliance Software Tools and Solutions 3
V Suggest an expert in Food Supplement Quality Standards in India Food Safety - ISO 22000, HACCP (21 CFR 120) 1
Ajit Basrur Pls suggest good M.S. Biotech universities Misc. Quality Assurance and Business Systems Related Topics 7
M Document for the management of employee activity - Suggest? Document Control Systems, Procedures, Forms and Templates 3
C What do you suggest in order to improve your department activity Quality Manager and Management Related Issues 5
kedarg6500 How to suggest amendments or changes to ISO 9001 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 11
S What Corrective Action would you suggest in this instance? Internal Auditing 14
P Beginning with ISO - Suggest any diploma course or online learning course Training - Internal, External, Online and Distance Learning 3
Z Lean Manufacturing Conferences - Could anyone suggest some good conferences? Lean in Manufacturing and Service Industries 1
S Ndc less than 5 (purchased part) - Auditor suggest I get waiver from customer Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 8
G What does a Process Capability Index of greater than 1 suggest? Capability, Accuracy and Stability - Processes, Machines, etc. 3
P CMQ/OE Preparation Material - What do you suggest? Professional Certifications and Degrees 1
R Can anyone suggest regarding advanced improvements on 5S Quality Tools, Improvement and Analysis 2
N Could anybody suggest a routemap for CE marking for invitrodiagnostic medical device? ISO 13485:2016 - Medical Device Quality Management Systems 4
A Can you suggest meaningful KPI's for our Design and Development process? Design and Development of Products and Processes 5
Manix Automotive Interior Trim - Vibration Standards - Anyone suggest One? Various Other Specifications, Standards, and related Requirements 5
R Suggest a source? Cheap Online GD&T (Geometric Dimensioning and Tolerancing) Training Training - Internal, External, Online and Distance Learning 1
chris1price Suggest a recognised qualification for a Quality professional in the UK Professional Certifications and Degrees 3
M Please Suggest Valuable Technical or ?motivational? Training Seminars, etc. Career and Occupation Discussions 4
E Researchers Suggest Medicare QIOs Improve Quality of Care World News 0
N Error-proofing tools/methods to suggest? TS16949 Clause 8.5.2.2 IATF 16949 - Automotive Quality Systems Standard 2
M Please suggest Registrar in Emeryville, CA - Software development company Registrars and Notified Bodies 5
P Can anyone suggest a GRR procedure for a Multi step plug gage? Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 2
C Strategy for preparing CQE exam and can any one suggest some good books? Professional Certifications and Degrees 1
Marc New treatments suggest that cancer is on the run! World News 4
W Continuing Professional Development - Can anyone suggest suitable training material Professional Certifications and Degrees 2
W Internal Auditing of individuals - Can anyone suggest a format or approach? Internal Auditing 19
L Can anyone suggest a good ISO 14001 handbook? ISO 14001:2015 Specific Discussions 7
C Can anyone suggest a means of evaluating a suppliers performance? Supplier Quality Assurance and other Supplier Issues 4
F 1. Suggest a Gage for Checking Rounding of Gears 2. When to conduct Stability Study? Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 2
R Poka Yoke on Helicoils Manufacturing and Related Processes 3
F Ideas for brewery poka-yoke system - Labels that are glued to a bottle Manufacturing and Related Processes 0
S Poka Yoke Inspection Retaining Ring (C-Clip) Inspection, Prints (Drawings), Testing, Sampling and Related Topics 4
D Ideas for Poka Yoke or Improvement - Aluminum FOD in Assembly Customer Complaints 3
M What is the link between Poka Yoke and Firewall? General Auditing Discussions 2
K Poka-Yoke for Quantity Shortage caused by Human Error Quality Tools, Improvement and Analysis 7
M Poka-yoke - Key Topics and Points Problem Solving, Root Cause Fault and Failure Analysis 11
C Poka Yoke and FMEA Detection Ranking FMEA and Control Plans 3
T Error Proofing / Poka-Yoke Textbook by Productivity Inc Book, Video, Blog and Web Site Reviews and Recommendations 7
M Weld Stud Length Poka Yoke Nonconformance and Corrective Action 3
K Poka Yoke for Leaf Spring placement by Operator Misc. Quality Assurance and Business Systems Related Topics 2
