Suggestions for: Control of Monitoring and Measuring Devices? (see 7.2.1) (1)
AS_QualityEngineer
Does the organization determine the monitoring and measurement to be undertaken and the monitoring and measuring devices needed to provide evidence of conformity of product to determined requirements (see 7.2.1) (1)?
Does the organization maintain a register of these monitoring and measuring devices, and define the process employed for their calibration including details of equipment type, unique identification, location, frequency of checks, check method, and acceptance criteria?
For services Industry like us the equipment is Workstations, Software etc.
Will the workstation needs any kind of calibration etc?
D.Scott
Re: Control of Monitoring and Measuring Devices
It is hard to say without knowing what you do at the workstations. Assuming you confirm a measurement, you would need to show the measurements were accurate and reliable which would indicate you need to calibrate (or verify prior to use) the equipment you use. Software, when used for measurements also requires calibration (many times this is a verification using test rabbits).
If you could outline what you actually do at the workstations a more definite direction of calibration needs could be given. Without knowing more, the general rule should be if you are measuring something, do it with a calibrated device.
Dave
AS_QualityEngineer
Dave
Thanks for response. Our workstations are loaded with the software. We use workstation to perform the design work as per client requirement or specification using the loaded software.
U
Umang Vidyarthi
Control of Monitoring and Measuring Devices, falls under clause 7.6 and 7.6.2 deals with Calibration/Verification Records.
7.2.1 Determination of Requirement Related to the Product. Management has to Determine the Customer's Requirement, vis-a-vis the product. This requirement varies from product to product, and must be mentioned there in your quality manual.
Could you be a bit specific about the exact nature of your problem? You will be able to get more responses once the problem is properly understood.
:topic:
A station is something where things become stationery, viz : Railway station, Service station, Bus station etcetra. Therefore, a WORKSTATION should be referred to a place, where WORK stops!?! :lmao: :lol: :lmao:
Umang :D
AS_QualityEngineer
:topic:
Umang :D
I just want to know what kind of calibrations, Inspection or measurements required in workstation or computer which is loaded with the software
:topic:
You can’t understand Workstation, if you are not from service Industry. So better stay away :bonk:
joshua_sx1
...your workstation must be somehow a “design” station as per your descriptions (since you are performing there the design work as per your customer requirements / specifications)… and you are probably doing “design review”, “design verification” and “design validation”… and performing these tasks, requires you to use pre-loaded software…
…unfortunately (& I believe), software cannot be considered as “measuring devices”… and therefore no calibration is required… instead, your design review, verification & validation should be re-defined in accordance with ISO requirements…
...A station is something where things become stationery, viz : Railway station, Service station, Bus station etcetra. Therefore, a WORKSTATION should be referred to a place, where WORK stops!?! :lmao: :lol: :lmao:
Umang :D
...you know you are absolutely correct… but I realized also that on these stations where work starts… (you know, going to next station)...
Stijloor
Standards require equipment to be "suitable."
That (in your case) includes hardware and software.
So if your workstations are performing as intended, you should be fine.
Stijloor.
AS_QualityEngineer
Thanks. but we are not responsible for design and development. So we already excluded clause 7.3.
Our customer is the owner for the Design and Development. We are just a service organization to carry out the task as per customer specification.
Say.. Customer Requirement for us: Replace X with Y and Place it in Z.
So our designer will so the same and quality checker check out the resulted model or work. (All the work will be carried out in Workstation/Computer)
Once this has been done the drawing or model will be delivering to our customer.
Before anyone can give a clear and correct answer to this question, it's important to know what the workstation is used for.
In general terms, a computer workstation doesn't perform measurement, testing or inspection and therefore needs no calibration. If the software is being used to perform calculations and simulations of designs, then it might be considered design testing. Therefore, it's quite usual to do some kind of validation (by alternate calcs etc.) that the results of the simulation are correct.
But then, there are computer workstations which do nothing but perform testing and monitoring of test items and equipment.
As in another post of yours regarding preservation, it's difficult for us to fully answer, without more information being given to us by you.
AS_QualityEngineer
Stijloor.
Great!! :agree:
So I have to check my hardware and software configuration and all my system should have same configuration. Am i Right?
Should I schedule / hardware maintenance and back up system to make sure my hardware or software not affected by any computer worms or system failure???
L ISO 13485 Document Control - Document Changes - Needing Suggestions ISO 13485:2016 - Medical Device Quality Management Systems 1
V Electronic Document Control Software suggestions wanted Document Control Systems, Procedures, Forms and Templates 14
B Suggestions on how to control a Design Dossier? Document Control Systems, Procedures, Forms and Templates 2
S SPC (Statistical Process Control) books - Suggestions and reviews please Book, Video, Blog and Web Site Reviews and Recommendations 3
T Touch Screen Capable Software suggestions for SPC (Statistical Process Control) Quality Assurance and Compliance Software Tools and Solutions 4
Q Document Control Software Suggestions - Anyone using MIPSIS? Document Control Systems, Procedures, Forms and Templates 7
R Non conforming product control for services - Looking for ideas and suggestions 8.3 Service Industry Specific Topics 4
H Procedure for Human Resource Control - Suggestions or ideas for Document Control Systems, Procedures, Forms and Templates 13
G Need Suggestions for SPC, control chart Training Training - Internal, External, Online and Distance Learning 1
A Tooling Control - Asked by our Customer to Implement a Procedure - Suggestions? Document Control Systems, Procedures, Forms and Templates 8
R Customer requirement implementation - Seeking control system example or suggestions Document Control Systems, Procedures, Forms and Templates 1
K PFMEA & Control Plan Software - Advantages over Excel? Suggestions? Recommendations? Quality Assurance and Compliance Software Tools and Solutions 1
K SPC (Statistical Process Control) Training and Courses - Seeking suggestions Training - Internal, External, Online and Distance Learning 2
D Suggestions for Ishikawa for hyperdetailed customer - plastic molding automotive parts Nonconformance and Corrective Action 9
P New Global HQ Suggestions for Virtual manufacturing/own brand labelling of medical devices? EU Medical Device Regulations 4
G ISO 17023 2017-11 - Suggestions for good books ISO 17025 related Discussions 0
M QA/RA Professional Development Suggestions Training - Internal, External, Online and Distance Learning 6
cscalise Suggestions for MDR Auditing tools EU Medical Device Regulations 1
R Suggestions for putting together a DHF (Design History File) ISO 13485:2016 - Medical Device Quality Management Systems 3
J Textiles needed for home monitoring device - any suggestions? Other Medical Device Related Standards 1
Q Calibrated Equipment Managment Software Suggestions General Measurement Device and Calibration Topics 12
N Online Internal Auditing Course for ISO 13485 - Suggestions ISO 13485:2016 - Medical Device Quality Management Systems 8
E CSR SHIPPING - Need suggestions for making SOP/WI for our shipping dept (automotive)... Customer and Company Specific Requirements 11
M Suggestions for Electronic Signature Software (FDA 21 CFR Part 11 Compliant) Qualification and Validation (including 21 CFR Part 11) 12
M Software Validation Guidance Suggestions Various Other Specifications, Standards, and related Requirements 6
Ron Rompen Dual level holes - Measurement method suggestions wanted General Measurement Device and Calibration Topics 9
E Best GD&T training - Your suggestions and recommendations please Training - Internal, External, Online and Distance Learning 3
O Suggestions for templates for formulating test plan for IEC 60601-1-2 4th ed CE Marking (Conformité Européene) / CB Scheme 0
S Need Continuous improvement Suggestions - Small (30 of us) all-CNC machine shop ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 28
M How to Document Internal & External Communications - Suggestions/examples pls IATF 16949 - Automotive Quality Systems Standard 3
Q Suggestions for a "budget-conscious" Colorimeter Device Inspection, Prints (Drawings), Testing, Sampling and Related Topics 4
J Suggestions on Inadequate Resources in a Small Machine Shop Nonconformance and Corrective Action 2
T ISO 9001:2015 Training for Management Team in NM - Seeking Suggestions and Providers ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 5
Q Tools for Risk - ISO 9001:2015 - Suggestions ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 4
A Suggestions for a UK based course in Process Auditing wanted Training - Internal, External, Online and Distance Learning 2
D Course / Conference suggestions to attend? Professional Certifications and Degrees 5
S Planning to appear for CQIA Examination - Tips and Suggestions ASQ, ANAB, UKAS, IAF, IRCA, Exemplar Global and Related Organizations 1
A Suggestions of Videos for Internal QUALITY Training Training - Internal, External, Online and Distance Learning 3
L Making a Medical Devices Registration Database - Help and Suggestions Wanted Other Medical Device and Orthopedic Related Topics 2
A Software Suggestions for Engineering Change/QMS Design and Development of Products and Processes 2
T "Customer Specific" Internal Audit suggestions needed Internal Auditing 12
A Audit report writing course - Suggestions wanted Internal Auditing 9
C Suggestions requested on handling batch record papers exposed to hormonal products Pharmaceuticals (21 CFR Part 210, 21 CFR Part 211 and related Regulations) 1
S Suggestions or advice on complying with ISO 13485:2016 ISO 13485:2016 - Medical Device Quality Management Systems 3
O Looking for IVD MD conference to attend, suggestions? 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 2
P Suggestions on conducting Internal Audit of a new site Internal Auditing 15
T Suggestions for Internal Audit OFI for ISO 14001 Internal Auditing 2
B Suggestions for job interview regarding CCD's (Charge Coupled Device) Quality Tools, Improvement and Analysis 3
S Any suggestions for ASQ CPGP (Certified Pharmaceutical GMP Professional) exam prep? ASQ, ANAB, UKAS, IAF, IRCA, Exemplar Global and Related Organizations 4
S Suggestions for a 100% Paperless Manufacturing Shop Floor Quality Tools, Improvement and Analysis 10
