Suggestions for Textile Suppliers for use in Medical Devices
Mark Meer
Wondering if anyone can suggest some suppliers that can offer textiles suitable for use in medical devices?
Specifically, we just want reliable companies which can offer a variety of various textiles we can sample. Once we select a suitable fabric for our purposes, we will confirm biocompatibility ourselves (according to ISO10993).
Because the biocompatibility tests are expensive and time-consuming, we'd like (obviously) to minimize the chances that we have to repeat these tests. Therefore, it is important that the supplier:
a) is well established (they're not going out of business anytime soon)
b) has a consistent product catalogue (so the exact same product can be consistently purchased)
c) (ideally) has a history of supplying textiles for use in medical applications (so we can be reasonably confident chosen product will not fail biocompatibility tests).
Can anyone suggest some?
(feel free to send me a personal message if particular endorsement of a company is not appropriate)
Thanks in advance.
MM
MIREGMGR
Are you making implants, or external-unbroken-skin positioners or garments, or something in between?
Ronen E
Problem Solver
Moderator
Thanks in advance.
MM
Focusing on the biocompatibility aspect for a moment -
Your approach is reasonable, but it's also somewhat limiting and/or a bit more risky. Either you end up with a well-established medical industry supplier, with a wider product range and higher prices, or with a niche manufacturer with all the right stuff and a limited range, or with a jack of all trades where the risk of eventual failure will be higher.
I would, instead, separate the evaluation into two aspects: The supplier should be evaluated for range, reliability, stability, reputation, quality system, commercials etc. etc. The product should be evaluated independently for various aspects, including biocompatibility. The latter can be quickly screened based on generics, then you can drill down through manufacturer reports, previous applications etc. Actual biocompatibility testing should only occur once you are confident re. both material and supplier.
You'd be surprised how many gross material selection mistakes could have been prevented if only manufacturers held an orderly evaluation at the generics level :(
Cheers,
Ronen.
Mark Meer
MIREGMGR:
No implants as of yet. Just body-worn stuff. Looking therefore for stuff like cottons, nylons, polyesters, velcros, neoprenes...etc.
Like I say, we're not yet sure of the ideal fabrics... so it'd be nice to start with a known reliable, consistent & reputable supplier, and then request samples from there...
Ronen E:
The supplier should be evaluated for...reliability, stability, reputation...
I don't know how to go about this other than ask here at the Cove. I really don't trust company website testimonials/reviews or correspondence with marketing reps on this front...
I presume that by "generics" you mean reasoning such as: "cotton is widely used in body-worn applications, therefore it should be reasonably safe to assume that the cottons supplied by X are also safe."?
For a well-established supplier, maybe. But when it comes to niche suppliers, I prefer caution. No telling whats in colorants etc.
As for manufacture reports, these, in my experience, are scarce when it comes to textiles. Few textile companies actually test their fabrics, and even if they do, additional treatments such as dying might bring the validity of any reports into question...
Ronen E
Problem Solver
Moderator
Ronen E:
{1} I don't know how to go about this other than ask here at the Cove. I really don't trust company website testimonials/reviews or correspondence with marketing reps on this front...
{2} I presume that by "generics" you mean reasoning such as: "cotton is widely used in body-worn applications, therefore it should be reasonably safe to assume that the cottons supplied by X are also safe."?
{3} As for manufacture reports, these, in my experience, are scarce when it comes to textiles. Few textile companies actually test their fabrics, and even if they do, additional treatments such as dying might bring the validity of any reports into question...
Hi Mark,
1. I wouldn't go into too much detail, because supplier evaluation was discussed a lot at Elsmar, have a look please. The obvious starting point would be your own QMS Purchasing Control procedures (should be aligned with ISO 13485, part 820 or the likes). Relating specifically to reputation etc. - ask the supplier for a referee list, then call a few and have a chat. If the supplier is a big org with a long history, there shouldn't be a problem with that. If they don't have such a list (or it's very short), or won't share it, or no one on the list is willing to talk to you - it's a red flag.
2. No, by "generics" I meant things like "Polyester", "Polyamide" etc., without reference to a specific grade. I don't have a lot of experience with natural fibres like cotton, but for synthetic materials you can find a lot of scientific evidence that can tell you whether the material is likely to be suitable. Query any dyes and additive in a similar way (FDA has specific regulations for colorants). Reasoning of the sort you noted is better left only as a last resort. The purpose of the "generic" stage is to quickly close in on a subset of materials, and rule out those that wouldn't fit, regardless of grade and/or supplier. I've seen companies struggle and waste a lot of money just to find the most suitable grade within a generic type that was clearly unsuitable in the first place...
3. This relates more to niche companies that deal mostly or exclusively with medical applications. Such companies would normally be aware of the important aspects, and if they elect to test, the reports are more likely to be appropriate. I agree it's rather rare, but if a company offers it, it's a big help and maybe even a reason to prefer that particular one. A lot of R&D engineers look for the best performing material and neglect aspects such as regulatory compliance and commercials; they come up with wonderful devices that can't be put onto the market without wasting a lot of time and $$$. I recall designing a device for a start-up company - we eventually chose a polymeric material that wasn't the best engineering fit, but it had biocompatibility reports available, and was commercially very stable and affordable. It ended up passing all functional / performance testing (was good enough) and regulatory clearance was so much simpler.
Cheers,
Ronen.
F
franck7727
I would suggest Singbwo Enterprise from Taiwan, you can google them to check their website. They are present in big medical exhibitions such as Rehacare, IFAS and Medica. They supply many manufacturers of orthopedics supports, wheelchair cushions, etc
I do not work for them, but I know them coz I used to work in a medical exhibition company in Taiwan until recently (I'm still in Taiwan...).
At least it is something for you to compare with any other leads.
Fran?ois
D Suggestions for Ishikawa for hyperdetailed customer - plastic molding automotive parts Nonconformance and Corrective Action 9
P New Global HQ Suggestions for Virtual manufacturing/own brand labelling of medical devices? EU Medical Device Regulations 4
G ISO 17023 2017-11 - Suggestions for good books ISO 17025 related Discussions 0
M QA/RA Professional Development Suggestions Training - Internal, External, Online and Distance Learning 6
cscalise Suggestions for MDR Auditing tools EU Medical Device Regulations 1
R Suggestions for putting together a DHF (Design History File) ISO 13485:2016 - Medical Device Quality Management Systems 3
J Textiles needed for home monitoring device - any suggestions? Other Medical Device Related Standards 1
Q Calibrated Equipment Managment Software Suggestions General Measurement Device and Calibration Topics 12
N Online Internal Auditing Course for ISO 13485 - Suggestions ISO 13485:2016 - Medical Device Quality Management Systems 8
E CSR SHIPPING - Need suggestions for making SOP/WI for our shipping dept (automotive)... Customer and Company Specific Requirements 11
M Suggestions for Electronic Signature Software (FDA 21 CFR Part 11 Compliant) Qualification and Validation (including 21 CFR Part 11) 12
M Software Validation Guidance Suggestions Various Other Specifications, Standards, and related Requirements 6
Ron Rompen Dual level holes - Measurement method suggestions wanted General Measurement Device and Calibration Topics 9
E Best GD&T training - Your suggestions and recommendations please Training - Internal, External, Online and Distance Learning 3
O Suggestions for templates for formulating test plan for IEC 60601-1-2 4th ed CE Marking (Conformité Européene) / CB Scheme 0
S Need Continuous improvement Suggestions - Small (30 of us) all-CNC machine shop ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 28
M How to Document Internal & External Communications - Suggestions/examples pls IATF 16949 - Automotive Quality Systems Standard 3
Q Suggestions for a "budget-conscious" Colorimeter Device Inspection, Prints (Drawings), Testing, Sampling and Related Topics 4
J Suggestions on Inadequate Resources in a Small Machine Shop Nonconformance and Corrective Action 2
T ISO 9001:2015 Training for Management Team in NM - Seeking Suggestions and Providers ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 5
Q Tools for Risk - ISO 9001:2015 - Suggestions ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 4
A Suggestions for a UK based course in Process Auditing wanted Training - Internal, External, Online and Distance Learning 2
D Course / Conference suggestions to attend? Professional Certifications and Degrees 5
S Planning to appear for CQIA Examination - Tips and Suggestions ASQ, ANAB, UKAS, IAF, IRCA, Exemplar Global and Related Organizations 1
A Suggestions of Videos for Internal QUALITY Training Training - Internal, External, Online and Distance Learning 3
L Making a Medical Devices Registration Database - Help and Suggestions Wanted Other Medical Device and Orthopedic Related Topics 2
A Software Suggestions for Engineering Change/QMS Design and Development of Products and Processes 2
T "Customer Specific" Internal Audit suggestions needed Internal Auditing 12
A Audit report writing course - Suggestions wanted Internal Auditing 9
C Suggestions requested on handling batch record papers exposed to hormonal products Pharmaceuticals (21 CFR Part 210, 21 CFR Part 211 and related Regulations) 1
S Suggestions or advice on complying with ISO 13485:2016 ISO 13485:2016 - Medical Device Quality Management Systems 3
O Looking for IVD MD conference to attend, suggestions? 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 2
P Suggestions on conducting Internal Audit of a new site Internal Auditing 15
T Suggestions for Internal Audit OFI for ISO 14001 Internal Auditing 2
B Suggestions for job interview regarding CCD's (Charge Coupled Device) Quality Tools, Improvement and Analysis 3
S Any suggestions for ASQ CPGP (Certified Pharmaceutical GMP Professional) exam prep? ASQ, ANAB, UKAS, IAF, IRCA, Exemplar Global and Related Organizations 4
S Suggestions for a 100% Paperless Manufacturing Shop Floor Quality Tools, Improvement and Analysis 10
A Internal Calibration Process Suggestions General Measurement Device and Calibration Topics 6
N Suggestions for Management Review Presentation Management Review Meetings and related Processes 2
L ISO 13485 Document Control - Document Changes - Needing Suggestions ISO 13485:2016 - Medical Device Quality Management Systems 1
K Process Writing Software Suggestions for Internal Procedures ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 7
hogheavenfarm Suggestions for next Professional Certification Professional Certifications and Degrees 11
E Empty Test Tube Storage - Suggestions Please Manufacturing and Related Processes 8
C Suggestions on Sample Plans for High Volume/Low Cost/Low Risk Components Inspection, Prints (Drawings), Testing, Sampling and Related Topics 2
C Suggestions for the RAC Regulatory Affairs Spring 2014 - US exam Professional Certifications and Degrees 1
Q Requirements and suggestions for ISO/TS 16949 Internal Auditor Preparation IATF 16949 - Automotive Quality Systems Standard 1
S Suggestions for Six Sigma Online Training Training - Internal, External, Online and Distance Learning 6
M Suggestions for Medical Device System Identification 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 1
S Looking for Air Sampler Suggestions Manufacturing and Related Processes 4
drgnrider Suggestions for conducting a Spill Clean-up Exercise Miscellaneous Environmental Standards and EMS Related Discussions 8
