Supplied Product on Control Plan - Lot ranging in 40,000 pcs per product
Currently our Company receives product from over seas and wants to eliminate receiving inspection. Not all together, based of off AQL's. My question is how would I go about stating this on our Control Plans in the [Evaluation/Measurement Technique] [Size] [Frequency] [Control Method]?
Currently we have in place a DII (Detailed Inspection Instruction) and perform redundant checks on many samples that will not find the needle in the hay stack with a Lot ranging in 40,000 pcs per product.
Any help or advise would be greatly appreciated.
indubioush
Not really sure what you are asking. If your current method of inspection is not working, maybe you need to figure out why it is not working. If you are performing tedious inspections that are not value added, use a risk-based approach to determine what you should be doing. Are the lots you received really homogeneous lots? If they are, you should be able to use statistical sampling to determine whether the lot meets acceptance criteria. You should not eliminate receiving inspection.
Hello indubioush,
Thank you for responding. To answer your question, yes. Lot's received are in fact very homogenous. When an anomaly does occur, it is usually onesie/twosies that receiving inspection would not have found, unless lucky enough to pick the one.
I have put into place a procedure that allows our counterparts overseas to perform a product/process audit to ensure PFMEA, Flow, Control Plan are accurate and being followed at ea. of the suppliers. We have set in place the supplier is to provide a 6-piece dimensional layout with ea. lot shipped that is reviewed upon receipt for ea. part number along with SPC Data for SC's/EC's Etc.
With the information provided from suppliers and the product/process audits that are performed monthly, is there a necessity to perform Receiving Inspection every lot? Especially if there is no value added. As mentioned, when non-conformances are found they rarely are systemic.
indubioush
That will be up to you to decide. Your receiving inspection could involve a review of supplier data and a visual check of one component if you believe the risk to your final product is low. However, you need to consider what would happen if you accepted a bad lot. You can also change your AQL and inspect fewer parts. For any change you make, you will have to provide adequate justification of the change in your change control records.
E QS 4.7 control of customer supplied product QS-9000 - American Automotive Manufacturers Standard 10
J API Q1 5.6.1.2 (iii) Identifying how the supplied product conforms Oil and Gas Industry Standards and Regulations 1
Gman2 Coating Company, ALL customer supplied product? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 4
A Customer Supplied Product & Certifications - Drop Ship - FDA and ISO 13485 ISO 13485:2016 - Medical Device Quality Management Systems 7
B Customer supplied product ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 12
R PPAP from Customer for Customer Supplied Product - Material to be machined APQP and PPAP 2
M Customer Supplied Product - When does it become that? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 8
M Customer Supplied Product and Traceability - No Customer Requirement - Toll Processor IATF 16949 - Automotive Quality Systems Standard 8
G Customer Supplied Product - Problem with who is responsible for what Document Control Systems, Procedures, Forms and Templates 9
J Design exclusion - Service company that processes only customer supplied product Design and Development of Products and Processes 2
D Customer Supplied Product - Machine Shop Misc. Quality Assurance and Business Systems Related Topics 1
D Element 4.7 Customer supplied product QS-9000 - American Automotive Manufacturers Standard 3
J Definition Customer Supplied Product - Definition (including returnable packaging containers) Definitions, Acronyms, Abbreviations and Interpretations Listed Alphabetically 9
Marc 4.7 Customer Supplied Product vs 4.19 Servicing ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 0
D Customer Supplied Product - Is a list of all customer supplied product sufficient? Document Control Systems, Procedures, Forms and Templates 2
Marc Humans as Customer Supplied Product ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 3
lanley liao Does the customer`s trademark belong to customer-supplied property? Oil and Gas Industry Standards and Regulations 2
M Is Harmonised EN 1041 (Information Supplied By Manufacturer) Worth Looking At? EU Medical Device Regulations 7
D Supplied item design verification Supplier Quality Assurance and other Supplier Issues 5
Manix Supplied Steel Material Testing Norms and Requirements Supplier Quality Assurance and other Supplier Issues 1
R Customer supplied material - risk and policy advice needed Quality Manager and Management Related Issues 11
R Deciding if a medical device shall be supplied sterile or not Other Medical Device and Orthopedic Related Topics 5
D Sampling method that is representative of the devices supplied by that distributor EU Medical Device Regulations 5
R AS9102 FAI with No Drawings Supplied AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 1
A Identification of Customer Property: Customer-Supplied Thumb Drives & Ext Hard Drives ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 1
B Creation of CAD solid models using customers supplied drawings AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 7
R What objective evidence can/can't be supplied during a customer audit? General Auditing Discussions 3
T IMDS - MDS request for parts supplied to multiple customers RoHS, REACH, ELV, IMDS and Restricted Substances 15
N What is the easiest way to verify we have the correct customer supplied materials? Misc. Quality Assurance and Business Systems Related Topics 5
I Implant Raw Material Supplied from Customer to Contract Manufacturer ISO 13485:2016 - Medical Device Quality Management Systems 1
J CMM calibration using a perfect sphere that is supplied Inspection, Prints (Drawings), Testing, Sampling and Related Topics 8
S How can I inventory labels supplied by customer ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 4
K Procedure for Handling of Customer Supplied Material (AS9100 Requirements) AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 3
S ISO 9001 Section 7.6 - Customer has supplied torque specifications ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 16
L Sample of Solder supplied with PCB by supplier - What is this sample for? Manufacturing and Related Processes 9
R CAD Print Conflicts with the Customer Supplied Paper Drawing Manufacturing and Related Processes 19
P ETO Sterilisation of Single Use Part supplied in Non-Sterile State EU Medical Device Regulations 12
N How to apply Incoming (Receiving) Inspection to Customer Supplied Material? IATF 16949 - Automotive Quality Systems Standard 18
B Supplier Quality vs. Supplied Material Quality ISO 13485:2016 - Medical Device Quality Management Systems 9
H Can the documents supplied by the client categorised as customer property?? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 6
Q Calibration through Gage Blocks/Test Fixtures/Customer Supplied ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 11
H What can be customer supplied properties (property) for the software industry? Software Quality Assurance 18
I Traceablity of Small Part Lots Supplied to Production taken from Large Lots? Lean in Manufacturing and Service Industries 7
C Customer Changes to Customer Supplied Documents - Testing Instructions US Food and Drug Administration (FDA) 2
B PPAP approval based on information supplied by the supplier APQP and PPAP 2
L PPAP Part Supplied to Multiple Plants - Submit another PPAP or PSW to the new plants? APQP and PPAP 6
A Lot Number Assignment for Incoming Purchased Products and Customer Supplied Material Document Control Systems, Procedures, Forms and Templates 2
T Customer Supplied Material Procedure Document Control Systems, Procedures, Forms and Templates 10
T Control of Customer Supplied Material - Build to Print Company ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 4
G Customer Owned or Customer Supplied Properties - Do we need a procedure anyway? Document Control Systems, Procedures, Forms and Templates 11
