Supplier Approval of electronic document storage service
bobbyv
Hi All,
If we use a network or cloud based storage provider to store our quality system documentation and records such as Sharefile or Sharepoint for example, are they considered a "Supplier" under the definition of suppliers in ISO13485?
Do we need to perform supplier selection and supplier re-evaluation processes for them?
Cheers,
Bobbyv:bigwave:
Ronen E
Problem Solver
Moderator
Hi All,
Cheers,
Bobbyv:bigwave:
A supplier is an entity you pay, and get something in return from.
Unless the network storage is internal (on a server that belongs to you and is maintained by you) I'd say the answers to your questions are yes and yes.
Cheers,
Ronen.
bobbyv
Hi Ronen E,
The reason I ask this questions is that I understand a "Supplier" to mean any entity that impacts directly on the quality system.
Where does one draw the line with "IT" or "computer" related suppliers? Does this mean that we also need to approve microsoft since we write our quality documents in Word, or Adobe or Dell.....?
Approving "Suppliers" will never end. Surely we have to draw a line in the sand.
cheers,
Bobbyv
Ronen E
Problem Solver
Moderator
Hi Ronen E,
cheers,
Bobbyv
I'd dare say that a supplier responsible for the maintenance and accessibility of all (or most) of your quality documentation has a direct bearing on your product quality.
With reference to Microsoft, the bearing is a little less direct. Wherever software like MS Word has a direct bearing on your product quality, the application at your org should be validated. There are "canned" solutions for validating the application of mainstream software - search the Cove for threads on that topic.
About drawing the line - my approach is: where it's not obvious that there's no direct bearing, assume that there is and treat it accordingly.
Cheers,
Ronen.
Ninja
Looking for Reality
Ronen already covered your question (usually does)...
Another thing to consider beyond Approving the Supplier is your backup plan...Approved doesn't mean perfect...
Not just software and file backup, but your backup plan for when your Web connection is lost. That's not your cloud host, that's your service provider...
E-Docs are great when you can get at them...but what about when a truck takes out the pole out front and you have no connection?
Depending on your doc count and workflow, a terminal in-house with redundant files can help (and is cheap)...but if you have a low file count anyway, a master hardcopy file can also work.
The way the world is moving, you are required to have safety documents like SDS's available at all times, power or not.
bobbyv
Hi Ninja,
Agreed!
Usually there is a local copy syncronized to PC as well.
Cheers,
BoobyV
michajel86
I would say "yes" only in case they are responsible also for maintenance IT and has direct inpact on one of your supporting process (acc. to process map). In such case it is external service that has to be controled by appropriate manner . The selection of external partner has to be done acc. to local laws and its evaluation depends on your QMS . This shall be prescribed in internal documentation - procedures .
You can evaluate for example ,
comunication level ,
user satisfaction .
Response rate ,
"issue solving" period ..etc.
Depends on agreements / contract..:bigwave:
Michal.
was named killer AS9100 Supplier Approval Requirements AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 10
K ISO 9001 Requirements for Raw Material Supplier Assessment and Approval ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 6
B Approval of Supplier with ISO 9001 (Automotive) General Auditing Discussions 18
L Supplier Approval Process – Should the Quality Department be Excluded? Misc. Quality Assurance and Business Systems Related Topics 7
N Raw Material Supplier Approval (Inks, Resin, Masterbatch etc) Supplier Quality Assurance and other Supplier Issues 4
L Chrysler's Supplier Request for Engineering Approval Form Quality Manager and Management Related Issues 4
S Supplier Approval Problem - Off-the Shelf Parts ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 3
V Ford SREA (Supplier Request for Engineering Approval) 2007 revision Document Control Systems, Procedures, Forms and Templates 2
T ISO 14001 Implementation Help & Question about Supplier Approval ISO 14001:2015 Specific Discussions 5
T ISO 9001 Clause 7.4.1 Purchasing Process (Supplier Approval) ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 12
K How to fill out an SREA (Supplier Request for Engineering Approval) form at Ford? APQP and PPAP 3
V Supplier?s PPAP - Production Process Control Plan Review, Evaluation and Approval? FMEA and Control Plans 5
E PPAP PSW Approval: Customer Drawing or Supplier Drawing APQP and PPAP 4
V Repercussions for Interim Approval of Supplier PPAP's APQP and PPAP 3
R Responsibility and Authority in a QMS - Approval of Supplier Accreditation Quality Manager and Management Related Issues 5
B Supplier Approval for Distributors of Equipment Misc. Quality Assurance and Business Systems Related Topics 5
J Supplier Purchase Order Review and Approval Requirements IATF 16949 - Automotive Quality Systems Standard 3
M Supplier Evaluation and Approval of a Translation company ISO 13485:2016 - Medical Device Quality Management Systems 6
F Who should Sign Supplier PPAP (Production Part Approval Process) documents? APQP and PPAP 13
K Questions about SREA (Supplier Request for Engineering Approval) Customer and Company Specific Requirements 4
M Researching Supplier Approval Processes - When Two Companies Merge Supplier Quality Assurance and other Supplier Issues 5
B PPAP approval based on information supplied by the supplier APQP and PPAP 2
B General SREA (Supplier Request for Engineering Approval) form for all OEM's? IATF 16949 - Automotive Quality Systems Standard 4
T Vendor (Supplier) Approval Procedure - Scope of the procedure ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 10
sonflowerinwales FDA approval required for a supplier to a medical device manufacturer? 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 4
A Supplier approval for special services Supplier Quality Assurance and other Supplier Issues 2
B No Supplier PPAP or PSO (process approval) Requirement APQP and PPAP 3
C Supplier Evaluation and Approval forms - Discussion and Evaluation Examples Supplier Quality Assurance and other Supplier Issues 37
J Supplier not responding to PPAP request APQP and PPAP 5
D Supplier audit Medical Device and FDA Regulations and Standards News 2
S Distinction between a critical supplier and a Virtual manufacturer EU Medical Device Regulations 2
John Broomfield Five ways to botch your supplier management program Misc. Quality Assurance and Business Systems Related Topics 7
C Supplier survey - 200 to 250 duppliers Supplier Quality Assurance and other Supplier Issues 3
J Where is the definition of a critical supplier? ISO 13485:2016 - Medical Device Quality Management Systems 5
U Approved Vendor (supplier) List Supplier Quality Assurance and other Supplier Issues 8
P Training department ideas and development for automotive supplier Training - Internal, External, Online and Distance Learning 6
B Software service provider as critical supplier ISO 13485:2016 - Medical Device Quality Management Systems 5
T AS9100D Clause 10.2.1g Supplier Corrective Action for each and every nonconformity? AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 3
S Supplier protocol for the Quality Supplier Quality Assurance and other Supplier Issues 6
A API Spec Q1 Purchasing Process - Supplier Reevaluation based on Supplier Risks 5.6.1.4 Oil and Gas Industry Standards and Regulations 17
D Approved supplier list - Distributors question ISO 13485:2016 - Medical Device Quality Management Systems 6
G Supplier delivered recent PPAP, should he deliver yearly layout inspection? IATF 16949 - Automotive Quality Systems Standard 4
E ISO 13485 QMS certification as a Supplier ISO 13485:2016 - Medical Device Quality Management Systems 8
G Supplier doesn't share drawings IATF 16949 - Automotive Quality Systems Standard 15
S Use of raw materials by two supplier CE Marking (Conformité Européene) / CB Scheme 2
D Are Supplier Quality Agreements Quality Records ? Other Medical Device Regulations World-Wide 9
G Dealing with non conformity caused by Supplier Components detected in the production line IATF 16949 - Automotive Quality Systems Standard 14
