Supplier Auditing - No purchases from our key suppliers in the last 24 months
Ed Panek
QA RA Small Med Dev Company
We are a small class 2 FDA ISO 13485 facility. We have made no purchases from our key suppliers in the last 24 months as we overbought our initial order. My attempts to audit these suppliers has been met with resistance because they don't see a business case in responding. What should I do?
William55401
Short answer: write a rationale. Longer answer: Keep in mind there is no explicit requirement to audit suppliers in the QSR. If you have created a written requirement, you must follow your procedures. If supplier say no / not now, define a plan on when it will be acceptable to them (when running your next order is likely outcome). Ensure you have escalated this supplier management challenge to your Purchasing / Supply chain team members. I would also be sure to have robust incoming / receiving inspection data to demonstrate balance of controls.
Sidney Vianna
Post Responsibly
Rethink your process of a mandatory supplier audit. What are you trying to accomplish by auditing the supplier? Have the products you (over) bought from them performed well? Are there any concerns over the quality of their deliveries? If their products have been performing adequately, what is the rationale for demanding an audit that creates disruption for them?
Are they certified to relevant standards, such as ISO 9001 or 13485? Request copies of their CB audit reports, instead of demanding your own audit.
Good luck.
Mark Meer
Agree with advice so far regarding re-assessing the need for audit.
However, if you determine it is appropriate (perhaps because it's a critical supplier, or because of the very isolated lots), I'd suggest revising your supplier approval criteria to associate the audits with orders. Perhaps some criteria like "a supplier audit shall be performed within X months of placing an order".
This way, audits are associated with purchases (which will mitigate supplier reluctance - supplier has something to gain), and you can confirm that all the quality controls from the last order are still in place (e.g. you can verify that they haven't changed any suppliers, equipment, processes in the interim).
Nash27
Very routine case and not to worry much as you already thought about this. You can follow up the guideline provided by William55401 also, I suppose, in your supplier OP you have listed a time frame to audit your supplier based on the product / supplier risk category (1 yr. 2yr, 3 yr etc.). If you haven't purchased any product from critical supplier within stipulated audit time frame, then in your 'Approved Supplier Register' state that audit shall be conducted prior to next purchase order placement from this supplier. You can also add a single line in your management review meeting report (as an input) that x supplier audit shall be conducted at this time (anticipated time frame) due to lack of PO. Alternatively, if you are doing supplier performance review on annual or bi-annual basis you can document the same.
If you have solid rationale and all reasoning in place, then regulator should able to accept it.
Ed Panek
Thanks all. I created a memo to file we can use that is risk based. It asks questions like - changes in materials, technology, facilities, locations, tooling. and then asks the lead time if we reorder. We then ask for their ISO certs and file it away.
A Agenda for 8D audit on Supplier's side - Auditing Corrective Actions General Auditing Discussions 5
J Recomended Values - Auditing process in a supplier IATF 16949 - Automotive Quality Systems Standard 18
Pmarszal Supplier Auditing Services (Audit Needed?) General Auditing Discussions 4
J Auditing Supplier Corrective Actions Supplier Quality Assurance and other Supplier Issues 3
S Audit Points for Auditing a Welding Supplier General Auditing Discussions 14
K Gamma Ray Sterilization Quarterly Dose Auditing Supplier Requirements ISO 13485:2016 - Medical Device Quality Management Systems 5
N Auditing a Software Code Subcontractor (Supplier) ISO 13485:2016 - Medical Device Quality Management Systems 4
B Supplier and Contractor Auditing - Report Template Needed Supplier Quality Assurance and other Supplier Issues 1
D Auditing Suppliers - Supplier audit by a customer who is also a competitor Supplier Quality Assurance and other Supplier Issues 13
K Auditing the Internal Vendor (Supplier) Management Process Supplier Quality Assurance and other Supplier Issues 2
Q ISO/TS 16949: Requirement for Auditing the Sub-Supplier IATF 16949 - Automotive Quality Systems Standard 6
G Auditing a Supplier in another country - What should I do - advice needed ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 12
S Auditor recommends better Vendor (Supplier) Auditing Supplier Quality Assurance and other Supplier Issues 20
Ajit Basrur Checklist for Auditing a Resin Supplier General Auditing Discussions 3
W AS9100 Supply Chain - Supplier evaluation and auditing Supplier Quality Assurance and other Supplier Issues 5
J Supplier not responding to PPAP request APQP and PPAP 5
D Supplier audit Medical Device and FDA Regulations and Standards News 2
S Distinction between a critical supplier and a Virtual manufacturer EU Medical Device Regulations 2
John Broomfield Five ways to botch your supplier management program Misc. Quality Assurance and Business Systems Related Topics 7
C Supplier survey - 200 to 250 duppliers Supplier Quality Assurance and other Supplier Issues 3
J Where is the definition of a critical supplier? ISO 13485:2016 - Medical Device Quality Management Systems 5
U Approved Vendor (supplier) List Supplier Quality Assurance and other Supplier Issues 8
P Training department ideas and development for automotive supplier Training - Internal, External, Online and Distance Learning 6
B Software service provider as critical supplier ISO 13485:2016 - Medical Device Quality Management Systems 5
T AS9100D Clause 10.2.1g Supplier Corrective Action for each and every nonconformity? AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 3
S Supplier protocol for the Quality Supplier Quality Assurance and other Supplier Issues 6
A API Spec Q1 Purchasing Process - Supplier Reevaluation based on Supplier Risks 5.6.1.4 Oil and Gas Industry Standards and Regulations 17
D Approved supplier list - Distributors question ISO 13485:2016 - Medical Device Quality Management Systems 6
G Supplier delivered recent PPAP, should he deliver yearly layout inspection? IATF 16949 - Automotive Quality Systems Standard 4
E ISO 13485 QMS certification as a Supplier ISO 13485:2016 - Medical Device Quality Management Systems 8
G Supplier doesn't share drawings IATF 16949 - Automotive Quality Systems Standard 15
S Use of raw materials by two supplier CE Marking (Conformité Européene) / CB Scheme 2
D Are Supplier Quality Agreements Quality Records ? Other Medical Device Regulations World-Wide 9
G Dealing with non conformity caused by Supplier Components detected in the production line IATF 16949 - Automotive Quality Systems Standard 14
G Supplier doesn't accept the complaints Supplier Quality Assurance and other Supplier Issues 20
K New supplier audit as per V3.1 by French Automotive OEM General Auditing Discussions 2
A ASL requirement when the supplier is certified for ISO 13485 ISO 13485:2016 - Medical Device Quality Management Systems 6
S Supplier Management ISO 13485: 2016- Which supplier needs to fill in a self assessment form? ISO 13485:2016 - Medical Device Quality Management Systems 6
D Approved supplier list for R&D ISO 13485:2016 - Medical Device Quality Management Systems 5
M SemaTech SSQA Standardized Supplier Quality Assessment - my favorite tool ever Manufacturing and Related Processes 1
D Supplier Quality level category help - high level ISO 13485:2016 - Medical Device Quality Management Systems 6
J Supplier Controlled Shipping (GM CS1) Condition Manufacturing and Related Processes 3
L Supplier within the Organization ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 5
D Supplier Quality - How to classify a supplier level Medical Device and FDA Regulations and Standards News 10
P Understanding DFMEA and PFMEA - Supplier Related IATF 16949 - Automotive Quality Systems Standard 21
S Can assembly manufacturing sub-supplier be certified IATF 16949? IATF 16949 - Automotive Quality Systems Standard 6
M How Supplier Capacity check is done by competitors Manufacturing and Related Processes 0
