Randy Stewart
Thorough?
It sounds more like your auditor had insider information that made their audit easier. But that's beside the point - you let the cat out of the bag and now you're in recovery mode. Check out the QS-9000 QSA in there you will see questions with the * by them. Those were label to be used as a base for a supplier audit. In all actuality, you not your auditor, decide what is necessary for your suppliers to be deemed "approved". I don't care if you have to do 2 hours of rework per supplied part, that is your choice (not a good one but yours to make) as long as they made it on the as you have documented. The auditor is comparing you to a standard and by what your documentation states. It is not their responsibility to make you more profitable nor is it to set company policy. ISO doesn't require a supplier audit, however if you choose to do one it still doesn't make the results auditable.
