Supplier completed CAR (Corrective Action Request) is unacceptable
michelle8075
I guess I just wanted to get everyone's opinion on this before I called up the customer and rejected their CAR.
Here's the highlights of the CAR (by the way there were a number of spelling mistakes - not to say that I am not guilt of it from time to time. However, this was more than a few).
Issue : "Product" not operating properly.
Interim Containment Action: "Evaluate "product" upon receipt
Root Cause " Items on Product appear to be repositioned and creating a nonperformance condition"
Corrective Action: Continue to audit and inspect "product prior to shipment to customer".
I guess I was a little put off by the lack of effort and time it seems that this customer put into this corrective action. I also feel that the root cause and corrective action are lacking. No details have been stated, and I think the root cause can keep on going down to something more. I usually send them my 8D report, but was informed that they had their own. I guess how would you handle this one? Is this what everyone else is experiencing? Or am I over-reacting?
F
fuzzy
Customer or Supplier?
It seems that it might be a supplier to you and if that is true, from what you have detailed I would (and have) reject that reply and be specific in my reasons for doing so. Give me some dimensions and sampling results for "items appear to be repositioned". Are they to print or not? There's not time or space enough to comment on the corrective action...trying to inspect Quality in are they??? Good luck with them; have they been a "good" supplier before now or has this been an ongoing thing?:eek:
michelle8075
They are actually a newer supplier to us. So, I haven't dealt much with them.
Some other details I need to know are "Was this a condition of a mfg error? if so, how is that being corrected" or "Is this a condition of the plant installing the product wrong? If so, what do they plan to do about it?"
michelle8075
Also... I am just put off by the fact that this is the final CAR that I received after waiting for a month for them to respond.
Is this a common problem that other Quality professionals are facing? Do you continuously get incomplete CAR's that you have to reject?
I guess it just seems to me that some suppliers may find CAR's as a waste of time. When I get something like this I instantly think that the supplier lacks quality, lacks quality improvement techniques, and doesn't think that the customer is important enough to ensure that conforming material is sent to them, or in fact find the customer important enough to spend time to ensure that a proper CAR is performed.
I am just letting off steam....
ralphsulser
I think you are right to demand a better answer for root cause and corrective/preventive actions. I would reject the submittal too. Hold their feet to the fire. Check with purchasing to see how bad you need them and are there alternates approved. Escalate your needs to their upper management and state your disatisfaction with the reply. Yes, a month is too long, especially for a superficial answer.
This could have a negative impact on your products with your customers.
It's already been established that you meant "supplier" and not "customer," so...
What was the "issue"? Was "not operating properly" the way you described the complaint to the supplier? If so, you need to be more descriptive and cite the actual specifications involved. If not, then the supplier should quote your complaint directly.
"Evaluate product upon receipt" is fine, as far as it goes, but what was done after the evaluation? What were the findings? Was there product "in the pipeline" that might have been affected?
The "root cause" given isn't a root cause at all, it's a symptom, or set of symptoms. The question is, why were items "repositioned."
The corrective action doesn't help much either (what was actually done to correct the condition on the "bad" products?) and there's no mention of what might be done to prevent "items" from being "repositioned" in the future.
In short, what you've described is worse than useless, because it indicates that the supplier has made no effort whatsoever to understand the problem, correct in the nonconforming products, or prevent it from happening again. A promise of more inspection shouldn't be considered an acceptable answer until efforts at prevention have been exhausted.
michelle8075
Jim Wynne said:
It's already been established that you meant "supplier" and not "customer," so....
Yes, I meant supplier... thanks!
They were given more information than just not operating properly. Our Project Manager who's plant this issue arose out of, gave them specifics... As to which line, which station, when it failed, and what the conditions were at the time.
Yeah, I thought it was fine too. I was more concerned with the root cause and corrective action.
Glad to get everyone's opinions on this. I am happy to know that was I saw wrong with this CAR, was with others were seeing too. I just was appalled by the inital CAR they sent me that I was like "unbelievable"
harry
Sometimes we have to face reality. I have seen big MNC's not taking CARs issued by my clients seriously - just because my client is small and had no or not much choice than to buy from them.
At other times, it could be an issue of communication. Picking up the phone and speak to the person at the other end may solve the problem. Even having our QA personnels dropping by may not only solve the problem but building up good and fruitful rapport. I mention this because my interpretation of the reply for 'root cause' is that the goods could have been damaged while being transported (repositioned and creating a non performance condition). I come from a country where English is not the main language and I had often need to struggle to make sense out of written replies.
ralphsulser
I will also agree that sometimes a visit works to establish intent plus clarify the expectations and communications.
CarolX
Michelle,
Could it be your supplier needs some training? If you are dealing with a small shop, they may not have anyone who is familiar with completing corrective actions.
Just thinking.
P.S. - I changed the title of this thread from "Customer" to "Supplier".
G Simplifying Supplier Surveys and the time they take to be completed Supplier Quality Assurance and other Supplier Issues 15
M Do you need to have a supplier assessment completed prior to the audit? Supplier Quality Assurance and other Supplier Issues 3
D Supplier OTD Slip Due to Shipping Delays or Natural Disaster AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 2
D Re-labeler - audit the supplier EU Medical Device Regulations 2
Evelyn7E The fastest way to get supplier to ship good parts to you Supplier Quality Assurance and other Supplier Issues 10
J Verification of purchased product / supplier questionnaires ISO 13485:2016 - Medical Device Quality Management Systems 2
D Question on Supplier Quality (SCAR) ISO 13485:2016 - Medical Device Quality Management Systems 6
Z REACH: contradictory statement from supplier? REACH and RoHS Conversations 4
G How to implement H&S and Quality Control Requirements in Contract for Potential Supplier? Contract Review Process 6
R Select the 1 Supplier based on the Parts Durability from 6 Supplier Samples using Minitab Using Minitab Software 11
K Why does load cell supplier requires force verification General Measurement Device and Calibration Topics 3
D Question and advice for a supplier self audit questionnaire ISO 13485:2016 - Medical Device Quality Management Systems 6
D Special IATF audit of sub-supplier IATF 16949 - Automotive Quality Systems Standard 18
S IATF 16949 Supplier selection criteria 8.4.1.2 IATF 16949 - Automotive Quality Systems Standard 2
M Supplier approved list - Notified body, regulatory body Supply Chain Security Management Systems 4
N Making improvements in supplier relationship last? Supplier Quality Assurance and other Supplier Issues 6
K Supplier Qualification for Engineering Consultant? Supplier Quality Assurance and other Supplier Issues 3
M Supplier evaluation Supplier Quality Assurance and other Supplier Issues 5
briteme4 ASL - AS9100 / Supplier Survey Supplier Quality Assurance and other Supplier Issues 3
A System for Supplier Documents Quality Assurance and Compliance Software Tools and Solutions 7
T IMDS submission without supplier's input? RoHS, REACH, ELV, IMDS and Restricted Substances 4
J Supplier not responding to PPAP request APQP and PPAP 5
D Supplier audit Medical Device and FDA Regulations and Standards News 2
S Distinction between a critical supplier and a Virtual manufacturer EU Medical Device Regulations 2
John Broomfield Five ways to botch your supplier management program Misc. Quality Assurance and Business Systems Related Topics 7
C Supplier survey - 200 to 250 duppliers Supplier Quality Assurance and other Supplier Issues 3
J Where is the definition of a critical supplier? ISO 13485:2016 - Medical Device Quality Management Systems 5
U Approved Vendor (supplier) List Supplier Quality Assurance and other Supplier Issues 8
P Training department ideas and development for automotive supplier Training - Internal, External, Online and Distance Learning 6
B Software service provider as critical supplier ISO 13485:2016 - Medical Device Quality Management Systems 5
T AS9100D Clause 10.2.1g Supplier Corrective Action for each and every nonconformity? AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 3
S Supplier protocol for the Quality Supplier Quality Assurance and other Supplier Issues 6
A API Spec Q1 Purchasing Process - Supplier Reevaluation based on Supplier Risks 5.6.1.4 Oil and Gas Industry Standards and Regulations 17
D Approved supplier list - Distributors question ISO 13485:2016 - Medical Device Quality Management Systems 6
G Supplier delivered recent PPAP, should he deliver yearly layout inspection? IATF 16949 - Automotive Quality Systems Standard 4
E ISO 13485 QMS certification as a Supplier ISO 13485:2016 - Medical Device Quality Management Systems 8
G Supplier doesn't share drawings IATF 16949 - Automotive Quality Systems Standard 15
S Use of raw materials by two supplier CE Marking (Conformité Européene) / CB Scheme 2
D Are Supplier Quality Agreements Quality Records ? Other Medical Device Regulations World-Wide 9
G Dealing with non conformity caused by Supplier Components detected in the production line IATF 16949 - Automotive Quality Systems Standard 14
G Supplier doesn't accept the complaints Supplier Quality Assurance and other Supplier Issues 20
K New supplier audit as per V3.1 by French Automotive OEM General Auditing Discussions 2
A ASL requirement when the supplier is certified for ISO 13485 ISO 13485:2016 - Medical Device Quality Management Systems 6
S Supplier Management ISO 13485: 2016- Which supplier needs to fill in a self assessment form? ISO 13485:2016 - Medical Device Quality Management Systems 6
D Approved supplier list for R&D ISO 13485:2016 - Medical Device Quality Management Systems 5
M SemaTech SSQA Standardized Supplier Quality Assessment - my favorite tool ever Manufacturing and Related Processes 1
D Supplier Quality level category help - high level ISO 13485:2016 - Medical Device Quality Management Systems 6
