Suzeku
I am a first time poster so be gentle. I scoured the threads and didn't see an answer, so I'll try now.
A colleague and I are discussing supplier evaluation and ASL, both in relation to AS9100C and D. Here’s where the discussion gets heated:
Colleague states that if you have 100 vendors that do work for you product related, you only have create a core group of them (they are suggesting a core of 5) to track OTD and Quality and evaluate. Their reasoning being that those handful you pick are ones that you have to use, there is no alternative, so your hands are to the fire.
I read the standard as having to track all of the OTD and Quality and evaluate all that are directly product related. Perhaps, to lighten the load, you can create Core, and Tier 2. Cores you’d be required to do all the metrics and evals and alert them if they fall below your standards, and would be companies that are used most regularly. Tier 2 you’d have all the data on and available for eval, but they are ones you might use once a year when you are in bind, and therefore their scoring could be abysmal. Therefore, they would not be part of the “alert group”. This would allow a company with limited team members to fulfill the needs and wants of the standard without creating an additional full time job.
The question I pose to you guys is, do you track and alert EVERY SINGLE vendor that is product related, or do you have wording like above to allow yourself leniency? Do you feel the above would be acceptable to an auditor?
