Supplier Laboratory Requirements - 4.10.6 - Requirements for an In-House Laboratory
mniem
We don't really have a lab, just do dimensional measurements with a CMM. ? Lab is not a controlled area, other than the walls around it. They have procedues for what they do, but nothing as in-depth as the standarad states. Can I just refer to their measurements as inspection and testing process and say that the lab requirements do not apply to us? If I say they do not apply do I have to get a waiver from our customers, or is this between the registrar auditor and me?
Dan De Yarman
We also have an inspection department with a CMM. All that is performed is dimensional verification, with the exception of our hardness tester. I was recently told that we would have to consider ourselves having a lab because of the hardness tester. IS THIS TRUE?!! All we use the hardness tester for is to check how hard something we had heat treated is, after it breaks (just to see how hard the piece is). Other than that we occasionally test copper to see if it is 110 or what have you. This is sometimes done before machining and sometimes after machining. It is tested after machining if the machinist suspects the copper isn't as hard as it should be.
If I have to become a lab because of one hardness tester, that is ridiculous. I will get rid of the hardness tester or use it for R&D purposes if this is the case. Is there anything else that can be done in this situation?
Dan
Rich S.
This is from the AIAG website, and is guiding our compliance development (i.e scope statement, generic operations manual, operator qualifications):
Labs and Calibration
Compliance to ISO Guide 25 is not required per se
Compliance to QS-9000 Requirements, including 4.10.6.1 - 4.10.6.6, is required
What is a lab? A facility, a building, a special room, a designated area, etc., that facilitates (makes possible) an activity where testing is done.
What isn't a lab? Places where testing occurs as a part of a process, which are within the parameters of that process. In other words, if testing is adequately controlled by in-process testing and inspection, and the items to be tested are not taken out of the process to a "facility," the in-house laboratory requirement does not apply.
Lab requirements:
Scope - answers the questions:
-What is the reason for the activity?
-What are the elements/rules/laws/procedures that will be included in the activity?
-Who or what is affected by the activity?
More specifically, the definition from QS-9000: A quality record (see 4.16) containing the following:
1) the specific tests, evaluations and calibrations a supplier laboratory has the ability and competency to perform,
2) a list of the equipment used to perform the above,
3) a list of the methods and standards to which it performs the above.
Lab personnel - professional judgments require theoretical and practical experience.
Test samples - must be retained and/or disposed of by procedures.
Environment controls - must be adequate.
Methods - must meet the needs of the customer and meet current standards. The lab must verify its capability to perform to standard specifications.
Statistics - must be appropriate to the work done.
L
louie
Additional Clarification please
Do I need "lab" facilities in which to "certify" my calibrated items?
If I have my micrometers, calipers, etc. calibrated by an outside lab once a year, can I certify that they are still within acceptable range using calibrated gage blocks, without having a true lab?
B IATF 16949 Cl. 7.1.5.3.2 - External Laboratory Sub-Supplier Requirements IATF 16949 - Automotive Quality Systems Standard 2
M Do we really need to meet the Supplier Laboratory Requirements (4.10.6)? General Measurement Device and Calibration Topics 3
L What is defined as a Laboratory? Supplier Laboratory Requirements - QS-9000 4.10.6 General Measurement Device and Calibration Topics 7
P 4.10.6 Supplier laboratory requirements - applicability QS-9000 - American Automotive Manufacturers Standard 11
L Supplier Laboratory Requirements 4.10.6 QS-9000 - American Automotive Manufacturers Standard 38
G Audit & Agreements for "Test Laboratory" Supplier? US Medical Device Regulations 4
M Is Notification of the Test Laboratory always necessary for Supplier Changes? IEC 60601 - Medical Electrical Equipment Safety Standards Series 12
S Supplier Laboratory Assessments General Measurement Device and Calibration Topics 1
M QS-9000 Section 4.10.6 Supplier Laboratory Requirement QS-9000 - American Automotive Manufacturers Standard 4
Marc 4.10.6 - Calibration services are conducted by a supplier's laboratory IATF 16949 - Automotive Quality Systems Standard 12
sonflowerinwales American supplier of faulty goods into the EU After Work and Weekend Discussion Topics 2
P Product label supplier, critical or non-critical vendor ISO 13485:2016 - Medical Device Quality Management Systems 6
R 5.6.1.2 Initial Supplier Evaluation—Critical Purchases Supplier Quality Assurance and other Supplier Issues 0
A Guidance on Supplier Qualification - Phase 1 pharma manufacturing Supplier Quality Assurance and other Supplier Issues 3
S Subcontractor's subcontractor - Outsourcing of Sterilization to a sub tier Supplier ISO 13485:2016 - Medical Device Quality Management Systems 11
K "Supplier's multi-disciplinary approach to decision making" IATF 16949 - Automotive Quality Systems Standard 4
Jen Kirley Lead Supplier Quality Engineer - MR in Florence, South Carolina USA Job Openings, Consulting and Employment Opportunities 0
G Ergonomic issue caused by supplier material ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 2
I Classifying a Supplier Medical Device and FDA Regulations and Standards News 3
J API Q1 - 5.6.1.2 (b) - Initial Supplier Evaluation—Critical Purchases Oil and Gas Industry Standards and Regulations 1
M ISO 13485 Supplier Question ISO 13485:2016 - Medical Device Quality Management Systems 13
S Supplier AS9100 certificate suspended - still ship goods ? AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 7
S Supplier change management Supplier Quality Assurance and other Supplier Issues 3
Robin H Wanted: Supplier Quality Engineer Job Openings, Consulting and Employment Opportunities 0
G Root cause for outsourced pest control service not in approved supplier list ISO 13485:2016 - Medical Device Quality Management Systems 4
A Supplier capacity analysis template IATF 16949 - Automotive Quality Systems Standard 1
L PACCAR Parts Supplier Portal? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 3
G Supplier problem solving IATF 16949 - Automotive Quality Systems Standard 8
J Critical Supplier Initial evaluation for single purchases Oil and Gas Industry Standards and Regulations 16
T Supplier Evaluation - *ALL* Suppliers to business? ISO 13485:2016 - Medical Device Quality Management Systems 5
F Supplier : Product Qualification Supplier Quality Assurance and other Supplier Issues 0
M Supplier Scrap Cost Supplier Quality Assurance and other Supplier Issues 2
I Supplier Evaluation Process ISO 13485:2016 - Medical Device Quality Management Systems 4
Pmarszal Technical File - Critical Supplier List Questions CE Marking (Conformité Européene) / CB Scheme 2
W Rights of Supplier in Design & Build WP Manufacturing and Related Processes 0
D Critical Supplier will not allow us to audit Plant floor US Food and Drug Administration (FDA) 12
ScottK Opening for Manager, Supplier Quality Engineering on my team- Orangeburg, NY - On-site Job Openings, Consulting and Employment Opportunities 0
E Control of Sterile Barriers made by the supplier Design and Development of Products and Processes 4
B AS9100:D - Purchase Order required if ordering paint on supplier portal? AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 1
B Supplier Evaluation report - Validation required or not ISO 13485:2016 - Medical Device Quality Management Systems 3
E Where can i get latest toyota and honda Supplier Quality Assurance Manual (SQAM) Customer and Company Specific Requirements 3
O AS9100 8.4.3 Supplier Terms and Conditions AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 3
S AS9100 Supplier Audit Checklist example AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 1
M Supplier Evaluation for Cold Chain Distribution of Human Tissues Supplier Quality Assurance and other Supplier Issues 3
Dazzur Sharing Suppliers Performance Data with Supplier. Supplier Quality Assurance and other Supplier Issues 6
H Pre-production units & Purchasing/Supplier/Material controls ISO 13485:2016 - Medical Device Quality Management Systems 6
Quality Specialist AS9100D Approved Supplier List requirements and how to apply Supplier Quality Assurance and other Supplier Issues 11
R Customer Listed on Approved Supplier List (ASL) AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 0
F Change in address for critical supplier - does NB need to be informed? CE Marking (Conformité Européene) / CB Scheme 20
GStough Audit Nonconformances (?) for Suppliers Not Registered to ISO and No Supplier Quality Agreement Exists General Auditing Discussions 24
