Supplier made a Change without Notifying Us
Juliosalinas
This is my first question. One of our suppliers made some change on a product supplied to us. He never told us, as a consequence, we kept on rejecting their delivers. We now intent to put on the Purchase Order, a request of notification when they do intent to change the product.
On the other hand and on a different product that we supply to our customer, we are asked to have a procedure to notify any change we intent to do to a product supplied to this customer.
My question is: how should I proceed? should I create a procedure that cater for everything, PPAP and PCN applicable to our suppliers and us acting as suppliers? It must be evident that I am very confused. Can anybody clarify things for me. Thanks in advance for any response.:confused:
Howard Atkins
Forum Administrator
This is IMO a matter of ensuring that you and your supplier have agreed terms.
You ordered X but in fact you got Y and correctly rejected this
How does the supplier explain this.
You do not need a procedure, this will not help anyone as the supplier does not see this.
Purchasing MUST ensure that the POs define clearly the conditions of purchase and that the supplier agrees to these basic terms
P
pldey42
It will surely be easier to create two procedures.
One would be for your suppliers to notify you of their plans to change products they sell to you. It might specify notice period, details of planned change, etc. This procedure would guide you through evaluating the change, considering its impact upon your product, spares holdings, considering alternative suppliers and so on.
Another would be for when you plan to change your own product. It might include considerations of which customers are impacted, impact upon their products and spares holdings, impact upon their customers and maintenance of their products in the field, customer loyalty and retention, and so forth.
It might be that the two procedures have some elements in common. If so, they'll be easier to spot having first written them separately. Revisions in a continual improvement cycle could enable them to learn lessons each from the other. But trying to write them as one proc would be a false economy I think, for they are fundamentally different: one looks down the supply chain, the other looks up.
Hope this helps
Pat
amit_rd
In my opinion, this is not a matter of new procedure. When you have given a PO to a supplier, in no circumstances can the supplier make changes in the product without informing you and the same applies to you as a supplier to your customer.
To indroduce changes, you may have a procedure that caters to both communication and implementation of changes (well planned changes) keeping both your supplier and customer in consideration.
somashekar
All said and done, you as the customer must loudly and clearly make your supplier understand and make him aware that no changes can be made to your supplies without your prior information and approval. This can be as in your PO terms and conditions, or in a separate supplier quality agreement, duly attested by you and your supplier.
As an indication, the FDA 21 CFR 820 clearly states such a requirement. Off-course, this 21 CFR 820 concerns to medical devices GMP and does not apply to you, but can be a learning to implement, to avoid quality problems.
P
pldey42
The original post says, "we kept on rejecting their delivers."
Sometimes, suppliers don't know what's important to clients and what's nice but not critical. If they think the delivery date and price matters more than anything, they'll sometimes be tempted to maintain the date and delivery promise by changing something they think doesn't matter - and if you don't tell them, but continue ordering from them despite rejecting deliveries, what are they to do?
So I'd suggest that maybe some thought should be given to maintaining cordial relationships; stern letters about contracts and POs may not be the best way of maintaining their goodwill. Plus, a note with any further rejections stating the reason for rejection and asking for their corrective action plan.
Just a thought,
Pat
P
PaulJSmith
This happened to me at a previous employer. We bought a boat-load of one company's products to install in our instruments (pipe organs, in this case). Suddenly, we received a shipment of a different product ... similar, but different in overall dimensions and some performance specifications. When we asked why, they said they had discontinued the older style and replaced it with the new one. They never bothered to tell us in advance. We had one design in which the new part didn't fit. We discovered through a local rep that we were, in fact, the largest reseller of that particular product in North America. We apparently had more influence than we knew, and used it to resolve the problem. They never did that to us again, even though they are the proverbial 800-lb gorilla in their industry.
Bottom line; let your supplier know that this is unacceptable, especially if they are not the only option. Be clear about your expectations from them. If they want your business, they'll listen and respond.
normzone
On the issue of having requirements in your P.O., and having agreements with your supplier? Both are well and good, but the P.O. will see more visibility in the process, and is the most reliable method. The agreement is not without value, but usually more people see and understand the P.O., the separate agreement may be known to fewer persons in the organization.
I now read all purchase orders and terms/conditions. Some interesting loophole language is used. I saw a source control drawing that stated that the only thing that could modify the requirements of the source control drawing was language on the P.O. - all other agreements were overridden by the P.O.
bluepagen
Did your PO state a revision Level? Was the revision on the part changed? Even if the OEM changed the product to imporve it, the drawing for the part should have a revision change. Ordering the previous revision of the part may be a way to go.
This definitely will involve communication with the supplier. Good Luck.
Wes Bucey
I have NO intention of being snarky in this comment, but this would have been a no brainer if everyone in the supply chain had been inculcated with Deming's concept of a SoPK (System of Profound Knowledge) and both supplier and customer (the distributor - your organization) would have been more alert to the true relationship between these two links in the supply chain and and both links would have been looking for ways to foster the happiness and welfare of each other as well as to other links up and down the supply chain.
A Supplier Audit Request - Made be laugh ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 7
bobdoering Survey:Toyota loses luster with suppliers-Ford has made strides in supplier relations World News 7
J Supplier not responding to PPAP request APQP and PPAP 5
D Supplier audit Medical Device and FDA Regulations and Standards News 2
S Distinction between a critical supplier and a Virtual manufacturer EU Medical Device Regulations 2
John Broomfield Five ways to botch your supplier management program Misc. Quality Assurance and Business Systems Related Topics 7
C Supplier survey - 200 to 250 duppliers Supplier Quality Assurance and other Supplier Issues 3
J Where is the definition of a critical supplier? ISO 13485:2016 - Medical Device Quality Management Systems 5
U Approved Vendor (supplier) List Supplier Quality Assurance and other Supplier Issues 8
P Training department ideas and development for automotive supplier Training - Internal, External, Online and Distance Learning 6
B Software service provider as critical supplier ISO 13485:2016 - Medical Device Quality Management Systems 5
T AS9100D Clause 10.2.1g Supplier Corrective Action for each and every nonconformity? AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 3
S Supplier protocol for the Quality Supplier Quality Assurance and other Supplier Issues 6
A API Spec Q1 Purchasing Process - Supplier Reevaluation based on Supplier Risks 5.6.1.4 Oil and Gas Industry Standards and Regulations 17
D Approved supplier list - Distributors question ISO 13485:2016 - Medical Device Quality Management Systems 6
G Supplier delivered recent PPAP, should he deliver yearly layout inspection? IATF 16949 - Automotive Quality Systems Standard 4
E ISO 13485 QMS certification as a Supplier ISO 13485:2016 - Medical Device Quality Management Systems 8
G Supplier doesn't share drawings IATF 16949 - Automotive Quality Systems Standard 15
S Use of raw materials by two supplier CE Marking (Conformité Européene) / CB Scheme 2
D Are Supplier Quality Agreements Quality Records ? Other Medical Device Regulations World-Wide 9
G Dealing with non conformity caused by Supplier Components detected in the production line IATF 16949 - Automotive Quality Systems Standard 14
G Supplier doesn't accept the complaints Supplier Quality Assurance and other Supplier Issues 20
K New supplier audit as per V3.1 by French Automotive OEM General Auditing Discussions 2
A ASL requirement when the supplier is certified for ISO 13485 ISO 13485:2016 - Medical Device Quality Management Systems 6
S Supplier Management ISO 13485: 2016- Which supplier needs to fill in a self assessment form? ISO 13485:2016 - Medical Device Quality Management Systems 6
D Approved supplier list for R&D ISO 13485:2016 - Medical Device Quality Management Systems 5
M SemaTech SSQA Standardized Supplier Quality Assessment - my favorite tool ever Manufacturing and Related Processes 1
D Supplier Quality level category help - high level ISO 13485:2016 - Medical Device Quality Management Systems 6
J Supplier Controlled Shipping (GM CS1) Condition Manufacturing and Related Processes 3
L Supplier within the Organization ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 5
D Supplier Quality - How to classify a supplier level Medical Device and FDA Regulations and Standards News 10
P Understanding DFMEA and PFMEA - Supplier Related IATF 16949 - Automotive Quality Systems Standard 21
S Can assembly manufacturing sub-supplier be certified IATF 16949? IATF 16949 - Automotive Quality Systems Standard 6
M How Supplier Capacity check is done by competitors Manufacturing and Related Processes 0
C One Time Service Supplier - Temperature and Humidity Testing Service ISO 13485:2016 - Medical Device Quality Management Systems 5
M Supplier Audits - Stop Wasting Everyone's Time! General Auditing Discussions 15
G Supplier management when the supplier is your headquarter IATF 16949 - Automotive Quality Systems Standard 3
V Supplier wants to perform pre-qualifications prior to every run instead of locking in parameters. Supplier Quality Assurance and other Supplier Issues 7
D Class 3 Device - Change of supplier of material Canada Medical Device Regulations 6
D List A IVD - Change to material supplier EU Medical Device Regulations 3
J Minimum Supplier Certifications for Food Supplements Food Safety - ISO 22000, HACCP (21 CFR 120) 4
R Supplier/Vendor Surveys (360) Supplier Quality Assurance and other Supplier Issues 1
was named killer AS9100 Supplier Approval Requirements AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 10
B AS9100 8.4.1 Supplier Selection/Evaluation criteria and reevaluations AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 13
J Sub-supplier change from manual to automated process - same specs - Report to FDA? 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 2
M Supplier Audit Report - Template for second party audit wanted Lean in Manufacturing and Service Industries 1
T Difference between a subcontractor and a supplier ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 21
