Supplier Quality Management System (QMS) Audit - Formal Documented QMS does not exist
Wes Bucey
Prophet of Profit
#11
Re: Supplier Quality Management System (QMS) Audit - Formal Documented QMS does not e
We consciously use the term 'evaluation' rather than 'audit' for prospective suppliers. It's more of evaluating the capability of the Supplier fraternity to raise the bar to expected level.
Sometimes, we enjoy cost advantage in case of such 'up-gradable' Suppliers.
Obviously, this is a "first look" case. The supplier must have something worthwhile going for it or the prospective buyer would [should!] not go to the expense of assigning an in-depth audit or evaluation of the supplier.
It depends on what your product is and who the supplier is ? If this is one of the many suppliers in that commodity, search another one but if it is like a monopolistic supplier and you have no alternative but to take this supplier onboard, work with them for developing the qms.
I'd go a step further than this and let the depth of the evaluation hinge on the criticality of the product to the purchaser's requirements. (If I'm buying steel bars from a distributor, I'm primarily concerned that he keeps the lots (heats) from the mill identified and separate for traceability - I don't really care about his presence or absence of a written quality manual or his dedication to continual improvement (as long as there is no deterioration of current status.)
Normally, in my machining business, I would buy direct from a mill for ferrous or non-ferrous material, but, for short runs, I had several distributors to supply 10 or 20 bars of stock. The mills, of course, maintained pristine records of everything, but all I wanted from a distributor was assurance he kept the mill identification with the stock, so I could always go back to the mill to check traceability. Many such distributors did not have the type of documented QMS one would expect from an organization trying to be compliant to an international Standard.
Similarly, when I outsourced a job of sawing bar stock to 3 inch lengths for hopper feeding into a hydromat rather than slow the cycle time by having the hydromat do the cut-off, I was able to get the job done at a mom & pop machine job shop with no written QMS at less than half the price of a fully registered ISO 9001 shop. One of my operators went over the mom & pop machine setup and I created an SPC control sheet for the supplier to follow to assure consistent results. The mom & pop were so pleased with how much more efficiently they ran with just the tips from my operator and the assurance of the SPC routine that they signed up for courses from our ASQ Section and became fully compliant to an ISO QMS Standard within two years, WITHOUT any prodding on our part. - We just said before giving them the job,
"This is the way WE do this; would you agree to follow this routine for running our job?"
You also need to review the requirements flown-down to your organization from your customer. They may have requirements for sub-tier suppliers that you may need to take into consideration. Often you may be required to use only sub-tier suppliers they have approved. If this is the case you will need to get your customer to approve them as a source, if not already approved by them.
Yep. This can be the deal breaker. Sometimes the top dog in a supply chain can impose requirements which must be rigidly followed or enforced by the various links in the chain. Often, the profits involved do not justify alienating the head of the supply chain by asking for exceptions to the rules.
TamTom
#12
First joshubob, I don't agree with some comments here, that doing business with a supplier having no ISO certificate is not "common" (missing a better word, sorry).
So go ahead with your plan.
Then it depends on what time you have, if you need a part or a service soon, there you can give the spplier the order and audit him, during he is producing your part. This could help you to get a good quality and you see the "real" processes, than you can ask the supplier how he secure these quality in future.
Iso 9001 certifcate is not only a question of mangement, sometimes it is one of money and the size of the factory. We have a supplier, we have from time to time painting jobs for, his core business is the repair painting of cars, he didn't want to have certifacte. And he has the choice to be a supplier of us or not, we need him, not he us. But he never make a mistake, Quality is perfect!!!
So check him, get an impression and make your desicion.
TamTom
johnny xu
#13
TamTom
Actually , there exit several suppliers without ISO Certification in your supplier chain.
That’s good quality. I agree with you :agree:
mortby
#14
To me, supply chain auditing is a risk mitgation activity, or a cost reduction activity.
If you have a supplier that is delivering parts and you are able to (and financially happy to) 100% check everything that they have done and throw away (or give back) anything that is wrong then there is no need to audit them and check their processes. In other words, if you are prepared to shoulder the quality burden then you don't need to control your supply chain, you simply state that all product conformity requirements will be managed on receipt.
I my experience this is very rarely the case. Almost always, we are not able to check something, or we simply can't afford the cost or impact on timescales of this. We want the ability to go back to a supplier if they get it wrong.
So then we do a risk assessment that looks at the chances of the supplier getting it wrong and the chances of us not finding it on receipt. We can mitigate some of those risks by going out to audit - we check their processes and the controls they have in place to make sure that we get what we asked for.
So the question is - what are you asking for?
You're looking to build confidence that your supplier's processes aren't going to let you down, so work out what you need him to be able to achieve and then go and see if he's able to do that.
johnny xu
#15
In terms of SIPOC, “S” represents supplier . we need to asset and control your potential supplier from source :agree1:
T Ideas for developing a Supplier Quality Management System, non automotive ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 5
A Supplier Quality Standard vs Senior Management Direction Supplier Quality Assurance and other Supplier Issues 2
S Supplier Control - Supplier quality management certificates (ISO, etc) ISO 13485:2016 - Medical Device Quality Management Systems 2
J Support and guidance with supplier quality management system Supplier Quality Assurance and other Supplier Issues 1
J IATF 16949 Cl. 8.4.2.3 - Supplier Quality Management System Development IATF 16949 - Automotive Quality Systems Standard 59
S SQM (Supplier Quality Management) - Centralized or divided per Business Group Benchmarking 0
Q Supplier Quality Management Development IATF 16949 - Automotive Quality Systems Standard 10
L Courses in Supplier quality management - Sydney or NSW Supplier Quality Assurance and other Supplier Issues 6
F What are the Performance Indicators for Supplier Quality Management Department Supplier Quality Assurance and other Supplier Issues 11
A Supplier Quality Management Strategies - Semiconductor Assembly and Test Services Supplier Quality Assurance and other Supplier Issues 6
Sidney Vianna SI 5 06 - ISO/TS 169494:2002 7.4.1.2 Supplier quality management system development IATF 16949 - Automotive Quality Systems Standard 42
P TS16949 vs. AS90001 - 7.4.1.2 Supplier Quality Management System Development IATF 16949 - Automotive Quality Systems Standard 7
J Automotive makers strategy and benchmarking on supplier quality management Supplier Quality Assurance and other Supplier Issues 2
D Supplier Quality Management including Supplier performance evaluation methods Supplier Quality Assurance and other Supplier Issues 2
T 7.4.1.2 Supplier quality management system development Supplier Quality Assurance and other Supplier Issues 3
S Supplier protocol for the Quality Supplier Quality Assurance and other Supplier Issues 6
D Are Supplier Quality Agreements Quality Records ? Other Medical Device Regulations World-Wide 9
M SemaTech SSQA Standardized Supplier Quality Assessment - my favorite tool ever Manufacturing and Related Processes 1
D Supplier Quality level category help - high level ISO 13485:2016 - Medical Device Quality Management Systems 6
D Supplier Quality - How to classify a supplier level Medical Device and FDA Regulations and Standards News 10
Ajit Basrur Quality Agreement with supplier covering medical devices and consumer requirements ISO 13485:2016 - Medical Device Quality Management Systems 2
Jen Kirley Moving on - I accepted an offer to be a Supplier Quality Engineer at GE Healthcare Coffee Break and Water Cooler Discussions 42
Tagin Measuring supplier quality with small quantities Statistical Analysis Tools, Techniques and SPC 10
A Critical Supplier/Quality Agreement Procedure ISO 13485:2016 - Medical Device Quality Management Systems 8
GStough Have You Had to Write a NC Against a Quality Manual in a Supplier Audit? General Auditing Discussions 12
P ASQ Certified Supplier Quality Professional is the certification worth it? Supplier Quality Assurance and other Supplier Issues 1
T ISO 13485:2016 Clause 7.4.2 regarding Supplier Quality Agreements ISO 13485:2016 - Medical Device Quality Management Systems 11
L Supplier Approval Process – Should the Quality Department be Excluded? Misc. Quality Assurance and Business Systems Related Topics 7
I Difference between ASQR (Aerospace Supplier Quality Requirements) and AS9100 AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 20
K NPI (New Product Introduction) Quality Plan Outsourced Manufacturer/Supplier APQP and PPAP 3
B Measuring Supplier Quality Performance Supplier Quality Assurance and other Supplier Issues 10
R Can our Supplier's Quality Mgr. conduct Supplier Audit on behalf of manufacturer? 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 4
S Supplier Quality with Prototyping Parts with no Part Number or Drawings ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 12
S Can you help me on manpower planning for Supplier Quality Engineers ? Misc. Quality Assurance and Business Systems Related Topics 4
V Quality Roadmap from Voice of the Customer way down to Supplier Quality Manager and Management Related Issues 4
G Supplier Quality Questionnaire - Asking who our customers are Quality Manager and Management Related Issues 10
D What's the future of supplier quality engineer for your worklife? Supplier Quality Assurance and other Supplier Issues 3
V Supplier Service Level Agreements (Supplier Quality Development) APQP and PPAP 2
F Supplier Quality Engineer Beginner - Potential Interview Questions Supplier Quality Assurance and other Supplier Issues 3
O Vendor (Supplier) Responsibility - Re: Quality Audits 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 5
L Does someone has experience with a Supplier "Quality Watch" Supplier Quality Assurance and other Supplier Issues 3
T World Class Supplier Quality Alert System CAR/SCAR By Email Quality Assurance and Compliance Software Tools and Solutions 2
J Quality Manager's role in Customer and Supplier Complaints Customer Complaints 10
J Implementing a Supplier Quality Portal Misc. Quality Assurance and Business Systems Related Topics 2
T Senior SQE (Supplier Quality Engineer) Specific Roles and Responsibilities Career and Occupation Discussions 5
P What is the last revision of Toyota SQAM (Supplier Quality Assurance Manual)? Customer and Company Specific Requirements 3
S SQE (Supplier Quality Engineer) Job Interview Questions Benchmarking 4
D Aftermarket Supplier Quality Requirements IATF 16949 - Automotive Quality Systems Standard 6
T Recommended Books for SQE (Supplier Quality Engineering) Book, Video, Blog and Web Site Reviews and Recommendations 20
L Avoiding Recurrence of the Supplier?s Quality Problems Supplier Quality Assurance and other Supplier Issues 5
