Suppliers Problem - One of our material suppliers is not ISO certified
L
Lincole
My company is attempting to have an ISO 9001 audit. As I found out that one of the material suppliers is not ISO certified, will this affect our auditing chance to get certified?:cfingers:
Mark Meer
Re: Suppliers Problem
Hi Lincole. Welcome! :bigwave:
There is no requirement that all your suppliers have to also be 9001 certified.
...Unless, of course, you yourself have specified this as a requirement in your quality procedures.
Generally, however, supplier evaluations are based on an assessment of the potential risk...and this will determine a scope for evaluations.
Very risky to your production schedule (e.g. one-of-a-kind item), or to end-users (e.g. a critical safety component)? Maybe on-site inspections are warranted.
Medium risk? Maybe you'd like to see a Quality System certification to show that they are commited to quality.
Negligable risk? Maybe just a matter of gauging their responsiveness and get a few samples to evaluate.
Ultimately, how you "approve" your suppliers is up to you, but should be documented. ...and your records should show that you've approved all your suppliers according to your procedure.
Welcome to the Cove. I presume you have an ISO 9001 registration audit coming up? There is no requirement in the standard for suppliers to be certified. They must be qualified according to the criteria that your company has established. If one of those criteria is ISO 9001 registration, the fact that you have a supplier that's not registered could result in an audit nonconformity. In most cases, if it's an isolated case, it wouldn't affect your chances of getting certified.
Marc
Fully vaccinated are you?
ISO 9001 does not require suppliers to be ISO 9001 certified.
Also see:
http://Elsmar.com/Forums/showthread.php?t=54765 - ISO 9001 Clause 7.4.1 Purchasing Process (Supplier Approval)
http://Elsmar.com/Forums/showthread.php?t=60771 - Clarification of ISO 9001 Clause 7.4.1 - Supplier Evaluation
The organization shall ensure that purchased product conforms to specified purchase requirements. The type and extent of control applied to the supplier and the purchased product shall be dependent upon the effect of the purchased product on subsequent product realization or the final product.
The organization shall evaluate and select suppliers based on their ability to supply product in accordance with the organization's requirements. Criteria for selection, evaluation and re-evaluation shall be established.
Records of the results of evaluations and any necessary actions arising from the evaluation shall be maintained.
Another consideration is your customer specific requirements. If one or more of your customers require ISO registration of your suppliers, then you will have to show that the suppliers supplying product/service for that customer meet your customer requirements. Failure to do so might mean a noncompliance to 5.2 which requires ensuring customer requirements are determined and met...
L
Lincole
Wow, I love this forum! Everyone is so helpful!
All these advices have been very helpful to me. You guys are awesome.
Thanks to all of you!
Bjourne
Hmmm...I did not know that...
Thanks for this post I am enlightened (--beginner here). I remember a customer auditor from Dallas Semiconductor during a performance audit we had some years ago. He asked who was the supplier of our mold cleaning material (a compression type rubber cleaner) as we just started using it on our semiconductor molds to speed-up the cleaning time and if they are ISO qualified. I remember that my boss (Process Engineer - process owner) replied that the aren't. I remember the auditor continued to check all the documentation about the material and the qualification of the supplier. In the end he agreed not to count the non-ISO certified as a non-conformity but requested to draft a new set of guidelines "for non-ISO certified suppliers" to follow. I do not remember what happened after that.
If I might ask, is that correct? Is there a need to draft a separate rules/guidelines for suppliers?
Marc
<snip> If one or more of your customers require ISO registration of your suppliers, then you will have to show that the suppliers supplying product/service for that customer meet your customer requirements. <snip>
Good point, db with consideration to a specific customer requiring suppliers related to products for that customer. A single customer can not realistically require a company to have all its suppliers ISO 9001 registered if the company makes products for other customers that are different and/or don't use all of the same materials.
I have worked with companies which required ISO 9001 registration of the company's suppliers and several of the companies had to buy some parts from ISO 9001 registered suppliers for that customer - And they charged more for it because the parts from registered suppliers (in those case) cost more.
The issue here, as I see it, is a customer requirement, as opposed to an ISO requirement. As mentioned above, ISO provides a tremendous amount of flexibility on how you select and evaluate your suppliers. Customers on the other hand, tend to be more prescriptive. In my opinion, the customer may be telling you that they were not confident in your selection and evaluation process. It might have appeared to them that you were not considering the effect on the product on the process or the final product. I find this happens most often when companies don't defend their system, and then it appears wishy-washy. In your case, I think the customer wants some level of confidence that all your suppliers are looked at.
Thanks for this post I am enlightened (--beginner here). <snip>
I'm not sure this is what db is referring to. Having a customer auditor ask a question about "ISO" suppliers (not sure what relevance that has to mold release sprays) is not the same as having a line item in your customers' contracts/agreements to "flow down" ISO certification through the suppliers who are associated with the product you supply such customers.
D Training for AS13000 - Problem Solving Requirements for Suppliers Training - Internal, External, Online and Distance Learning 17
R Does C = 0 have a expanded twist for problem vendors (suppliers)? Inspection, Prints (Drawings), Testing, Sampling and Related Topics 14
adir88 Qualifying Temporary Staff as Suppliers ISO 13485:2016 - Medical Device Quality Management Systems 10
T How to rank suppliers? Supplier Quality Assurance and other Supplier Issues 9
B ISO13485 Risk managment implementation for suppliers ISO 14971 - Medical Device Risk Management 2
J Outsourced Internal Audit requirements for Aerospace Suppliers AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 21
R Auditing COT's Suppliers / First Post Supplier Quality Assurance and other Supplier Issues 2
S Recommended software to send Quality scorecards to suppliers (external providers) Supplier Quality Assurance and other Supplier Issues 3
lanley liao Questions regarding the change of critical suppliers and key personnel Oil and Gas Industry Standards and Regulations 5
D ISO 9001 - 8.4.1 Evaluate All Suppliers? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 66
G Approval for tool suppliers Supplier Quality Assurance and other Supplier Issues 23
M PSA Suppliers - CSR matrix and need the quality manual of PSA APQP and PPAP 6
O How to give a score/yield more correctly to my suppliers Supplier Quality Assurance and other Supplier Issues 12
P Managing How PPAP Requirements are Communicated in the Manufacturing Process and to Suppliers APQP and PPAP 5
B General Motors and Honda Alliance - What does this mean to suppliers? IATF 16949 - Automotive Quality Systems Standard 3
S Conflict Minerals - Tin Suppliers CMRT Miscellaneous Environmental Standards and EMS Related Discussions 13
T ISO 13485 - Process validation at critical suppliers ISO 13485:2016 - Medical Device Quality Management Systems 7
P Mylar plot suppliers in accordance with D6-51991 document AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 4
T Reaction Plan To Drive suppliers to IATF 16949 registration IATF 16949 - Automotive Quality Systems Standard 6
I Approved Suppliers ISO/IEC 17025:2017 and used test equipment ISO 17025 related Discussions 6
C Critical Suppliers for EU medical device approvals May 2020 EU Medical Device Regulations 1
M Who should receive the bills from suppliers and vendors, account payable or procurement? Consultants and Consulting 4
P Qualifying commercial off the shelf (COTS) external suppliers ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 10
Nicole Desouza Are Shipping Companies Suppliers? Manufacturing and Related Processes 4
J Painted cut threads - ASME Pipe Suppliers Manufacturing and Related Processes 6
G ISO 9001 8.4 applied to 7.1.3 - Suppliers of infrastructure requirements - IT and Print solutions ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 4
P IATF 16949 Clause 8.4.2.3 - Justification for non-certified suppliers IATF 16949 - Automotive Quality Systems Standard 14
J Requirements for customer directed suppliers Customer and Company Specific Requirements 5
R Supplier Controls we can place on Single-Source Suppliers ISO 13485:2016 - Medical Device Quality Management Systems 2
L Audit boundaries - Is a Registrar permitted to audit a company's QMS by visiting their suppliers? AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 26
R ISO 9001 versus ISO 13485 for Suppliers to Medical Device Companies ISO 13485:2016 - Medical Device Quality Management Systems 2
R Critical suppliers (Definition of) and MDSAP (Medical Device Single Audit Program) ISO 13485:2016 - Medical Device Quality Management Systems 19
P IATF 16949 - Monitoring Suppliers for Premium Freight IATF 16949 - Automotive Quality Systems Standard 12
DuncanGibbons Documentation aerospace OEMs require with purchase of parts from manufacturers/suppliers Manufacturing and Related Processes 0
K Supplier Controls for Animal Tissue Suppliers for Medical Devices Other Medical Device Regulations World-Wide 0
optomist1 Survey of Tier 1 & Tier 2 suppliers APQP and PPAP 6
P Non-Active Suppliers on CE Certificate EU Medical Device Regulations 2
C Suppliers re-classification from Critical to Significant or from Significant to Non-critical Supply Chain Security Management Systems 0
eule del ayre List of Level 3 PPAP requirements for automotive suppliers APQP and PPAP 20
Q Does our material suppliers’ supplier have to be at least ISO 9001 certified? IATF 16949 - Automotive Quality Systems Standard 3
N How to deal with catalog parts suppliers who refuse to submit PPAP documents? APQP and PPAP 0
S Outsourcing manufacturing - Who controls the suppliers of parts to the CMO? ISO 13485:2016 - Medical Device Quality Management Systems 2
Ed Panek Supplier Auditing - No purchases from our key suppliers in the last 24 months ISO 13485:2016 - Medical Device Quality Management Systems 5
I IATF 16949 - 8.4.2.3 - Applicability to Shipping Suppliers IATF 16949 - Automotive Quality Systems Standard 11
A MedAccred being flowed down to Suppliers (2018) MedAccred Industry Group Program 0
T What's the quality standard adopted by BMW for its suppliers Customer and Company Specific Requirements 5
S Do suppliers of prototyping components need to undergo supplier qualification? ISO 13485:2016 - Medical Device Quality Management Systems 3
O ISO 13485 for software company - Selecting suppliers ISO 13485:2016 - Medical Device Quality Management Systems 3
M Are Medical device Raw material suppliers required to be ISO 13485 certified ISO 13485:2016 - Medical Device Quality Management Systems 13
