Supply Voltage Condition for Transformer O/L and S/C (open & short circuit) testing
W
william_N
Does anyone can help clarify :
about transformer O/L and S/C testing condition.
considering the least favourable testing condition for supply voltage fluctuation (+10%, -10%) and frequency (50/60Hz)
for example, a TR rated AC 230V, 50/60Hz
When do O/L test which voltage (253V, 207V) and frequency (50/60Hz) shall be used?
When do S/C test which voltage (253V, 207V) and frequency (50/60Hz) shall be used?
sowmya
Involved - Posts
Re: Supply Voltage Condition for Transformer O/L and S/C (open & short circuit) testi
1. A open circuit test reveals the core losses ( neglecting minimal voltage drop at the wires) and hence would increase with a higher voltage , and hence the test should be done on
253 V ( higher side of fluctuation)
2. A Short circuit test reveals the copper losses and is not generally safe to be done at the rated Voltage . The test voltage needs to be arrived at based on each transformer
condition.
W
william_N
thanks sowmya, actually this test is from 60601-1 cl.15.5, I just want to find the wost case test condition from the input voltage fluctuation for TR o/l and s/c
Peter Selvey
It depends on the protection, design and the particular test.
There are three possibilities to consider:
- not really dependent on supply voltage/freq e.g. overload test with a thermal fuse, overload test based on current fuse (2.1x for 30min). In this case it does not really matter, but most test labs do it at highest volts/lowest freq by convention since this causes the highest magnetizing currents
- worst case at lowest input: example is fuse based s/c test. In this case we want to check the fuse blows quickly even with the lowest voltage. Frequency is normally irrelevant.
- worst case at highest input: there are more complex examples, e.g. a multiple winding transformer, protected by primary fuse, one big winding has a switching regulator in the secondary circuit which has less current at higher voltage, thus leading to less chance that a smaller secondary trips the fuse when shorted. Its a bad design because it's complicated and hard to know what is the worst case, but sometimes happens.
If in doubt, all conditions should be tested.
W
william_N
Thanks Peter.
How about the fuse? such as two fuses, each rate 6A, one is UL284 certified, one is iec/en60127 certified, some special cases shall be considered for the different kind certified fuse?
B 3-phase supply, overvoltage catogory, line-to-neutral and working voltage (IEC 61010-1) IEC 60601 - Medical Electrical Equipment Safety Standards Series 0
C "PEAK WORKING VOLTAGE" with a 220-240VAC nominal Power Supply IEC 60601 - Medical Electrical Equipment Safety Standards Series 5
R Reference Voltage for Switching Power Supply IEC 60601 - Medical Electrical Equipment Safety Standards Series 11
V What effect has Supply Voltage on product performance? IEC 60601 - Medical Electrical Equipment Safety Standards Series 5
L Class II (Double Insulated) Power Supply with Output Tied to Earth: FE or PE? IEC 60601 - Medical Electrical Equipment Safety Standards Series 3
D Hand Held medical device - power supply requirements IEC 60601 - Medical Electrical Equipment Safety Standards Series 2
U Supply risk management Manufacturing and Related Processes 4
A Can a power Supply be an accessory to a medical device, if it is an 'off-the-shelf' product. IEC 60601 - Medical Electrical Equipment Safety Standards Series 3
C Consequences of terminating a subcontractor re continuity of supply CE Marking (Conformité Européene) / CB Scheme 0
C Power Supply EN60601-1 vs EN62368-1 IEC 60601 - Medical Electrical Equipment Safety Standards Series 2
M MDR - eIFU - When you can supply an electronic IFU instead of a paper IFU EU Medical Device Regulations 6
Sidney Vianna Informational APQP4Wind - Advanced Product Quality Planning for the Wind Power Supply Chain APQP and PPAP 3
U Power supply - Change From 160 to 300 Watts - Significant change? EU Medical Device Regulations 2
U EU-MDR: Complicated supply chain EU Medical Device Regulations 4
Z Class I marketing regulation and supply chain Other Medical Device Regulations World-Wide 0
silentmonkey Are risks in supply chain and development activities within scope of MDD? EU Medical Device Regulations 4
K Supply Agreement Regarding MDR 2017/745 - Manufacturer-supplier cooperation Other Medical Device Related Standards 0
N "Placing on the market" & "putting into service"- one time regulatory event or Continual supply event? EU Medical Device Regulations 2
B ASA Aviation Supply Association - Has anyone heard of ASA? AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 1
G Do we need to QA cert? We only plan to supply reagents Medical Device and FDA Regulations and Standards News 3
B Need For BIS Standard Mark? Imported OEM's Power supply,Li-Ion Battery Other Medical Device Regulations World-Wide 0
E IEC 61010-1 Dielectric strength test of inner power supply Other ISO and International Standards and European Regulations 0
T Is anyone working with N299.1 (Supply/service to nuclear power plants)? Various Other Specifications, Standards, and related Requirements 0
Sidney Vianna Interesting Discussion How major corporations in the West keep failing to uphold their pledges of abolishing child labor in their cocoa supply chains Sustainability, Green Initiatives and Ecology 3
P Fan filter unit (un-ducted to air supply) vs fan filter unit (ducted to air supply) Pharmaceuticals (21 CFR Part 210, 21 CFR Part 211 and related Regulations) 1
T Oversight of Distributors - Supply chain requirements under the MDR EU Medical Device Regulations 9
H External power supply - requirements in safety/EMC test? IEC 60601 - Medical Electrical Equipment Safety Standards Series 4
O Inspecting paint and having workable standards in the supply chain Supplier Quality Assurance and other Supplier Issues 1
C Electrical Power Plant Supply failure in PFMEAs FMEA and Control Plans 10
O Supply chain strategy or commodity strategy reading recommendations Supplier Quality Assurance and other Supplier Issues 6
C SVHC Lead - Communicate in the supply chain under Article 33 of the REACH Regulation REACH and RoHS Conversations 1
N What should be included in the supply contract - Annex 2 list B IVD ISO 13485:2016 - Medical Device Quality Management Systems 6
G Supply Chain PPAP Requirements APQP and PPAP 10
M Is IEC 60601 compliance possible when only generic power-supply is specified? IEC 60601 - Medical Electrical Equipment Safety Standards Series 4
E Requirements for Humanitarian supply of Medical Devices to Jamaica Other Medical Device Regulations World-Wide 3
R Good Supply Practices that will be effective on March 1 2015 in China China Medical Device Regulations 2
T What Test Certificate should accompany supply of Cable XLPE/SWA/PVC 4CX150MM2 Document Control Systems, Procedures, Forms and Templates 2
B Detachable Power Supply Cable Connection ESD Clarification IEC 60601 - Medical Electrical Equipment Safety Standards Series 7
R Selling of Medical Power Supply in Australia/New Zealand and Japan Other Medical Device Regulations World-Wide 5
R Connection to a generic separate power supply IEC 60601 - Medical Electrical Equipment Safety Standards Series 5
T EMC Tests - While certified power supply is part of device IEC 60601 - Medical Electrical Equipment Safety Standards Series 1
B IEC 60950 power supply MOOPs IEC 60601 - Medical Electrical Equipment Safety Standards Series 5
O IEC 61010-1 Ed 2: "Automatic Disconnection of the supply" CE Marking (Conformité Européene) / CB Scheme 3
O Can unit be categorized as EMI class A when it has EMI class B power supply in it? CE Marking (Conformité Européene) / CB Scheme 2
C Controls and Preventions are not "OJT", "Ample Supply" & "Supervisor Verification" FMEA and Control Plans 4
M ISO 13485 - Supply Chain Requirements ISO 13485:2016 - Medical Device Quality Management Systems 8
F Power supply certification and its effect on testing IEC 60601 - Medical Electrical Equipment Safety Standards Series 2
AnaMariaVR2 Using ISO 9001 to Strengthen Supply Chain ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 1
M IEC 60601-1 testing for device with its own 2V battery power supply necessary? 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 1
