Supporting Site Quality Manual and References Requirements
Angie
I am currently conducting supporting site audit I am being told by the certification site (for the supporting site) that the supporting site does not use their Quality Manual. I do not think this is the case, the supporting site must use the Quality Manual for the site they support, but is this plainly documented anywhere?
I received the same response when I requested the "turtle diagrams" for the processes in which the support site supports, the certification site stated the "support site" would not be mentioned on their "turtle diagrams"? I would think the support site would be listed as "support" but again not sure?
Any help would be greatly appreciated.
Hi Angie:
Tell us more about your audit: Internal? What's the scope? What criteria are you using to audit against? What's the objective of the audit?
Experience tells me that when people post such questions and seek help trying to find where these (your questions) are answered, the planning of the audit wasn't effective. So, to help you, tell us about your audit...
Angie
Re: Supporting Site
Hello.
We are preparing for new IAFT 16949 audit (internally) The manufacturing site Company A is located in China, and company A remote/supporting site is in US, we support the process of Sales, Delivery, Customer Satisfaction and Warranty.
I am auditor from our office in UK sent to US to conduct Internal Audit prior to our IAFT 3rd party audit next year. To prepare for the Internal Audit I requested a Copy of Company A Quality Manual, so that I could see the process/and interactions of the process concerning remote site in US. The China site stated US site would not use their Quality Manual for audit, that US would need to make their own manual, and processes.
With the training I received for Internal Auditing IAFT 16949, when preparing for audit you look at the Manual and Processes (in the case of this company they choose "turtle diagrams", so I also asked for diagrams on Sales, Delivery, Customer Satisfaction and Warranty so I can see the entire process and how the support site supports the process, again I was told"this is not correct, for remote site audit you should only look at the documentation created by and for the remote site-US. " If you can not look at Manual/Diagrams from China Site, how can you show linkage to US support site?
When there is Support Site (in this case the US site), their role is to support the site receiving the certification (in this case China site), so US must follow the process/guidelines set by China? The US will have their own set of instructions, but those instructions must be in line with China I would think?
Hope this clears up my question a bit... thanks for your help
Sebastian
There is one important thing missing. Certification scheme of US supporting site and China manufacturing site. Probably US supporting site is certified together with some US manufacturing site. If so, there are two separate management systems and US supporting site is not bound by system established by China manufacturing site. There is rather "commercial" relation between them even both entities are members of same "family".
Scope of your audit is limited to management system of supporting site only. Manufacturing site is an interested party and you should focus on activities performed by supporting site to determine expectations and needs of manufacturing site, how they are addressed in management system of supporting site, implemented and monitored.
This is same relation like manufacturing site and customer, where customer is interested party. You shall not audit according to QM, procedures of China manufacturing site, as long US supporting site is not obliged to treat these documents as CSR and follow them.
I might be wrong, but should'n be. Wait for 3rd party auditors comments, I still have to learn a little bit in this matter. ;)
Re: Supporting Site
Hello.
Since you are auditing a Quality Management System, it should be understood that the manual and documentation should be as "common" as needed. Since support sites have processes which feed/respond to the Manufacturing site, it makes zero sense to have one set of documents in the US and another in China. The documentation should, as you correctly suggest, show the hand off from US processes to the China ones.
I don't believe this is correct at all. Treating a support site with one QMS and a manufacturing site with another QMS isn't what this is about...
Angie
No the US site does not have any other certification only support to the China Manufacturing plant. That is why I think they should use the same manual, but could not find where it is requirement of IAFT 16949?
Sadly you won't. It's - in general terms - considered in section 4 under the context etc. Were you ISO/TS 16949 in the past? Or is this a new certification?
Dave Cx
Angie
From your description the US site is not an extended manufacturing site (as it does not manufacture) so it would be a remote support location, by that it is remote to the parent site in China. If that is the case I would expect the scope for the China management system to reference the US site as an RSL.
If China system does not reference the US then the US certification is standalone & hence has its own management system - context / policy / processes, etc.
[QU.OTE=Angie;612915]No the US site does not have any other certification only support to the China Manufacturing plant. That is why I think they should use the same manual, but could not find where it is requirement of IAFT 16949?[/QUOTE]
Clause 4.3.1 asks to include remote locations in the scope of QMS. And hence all requirements apply accordingly. There has to be minimum a process map showing interaction between this site and remote location and documents showing how the remote location supports the site (clause 4.4.1). As Andy suggested, its better to have a common quality manual, since it is a single QMS.
K Supporting Site Certification - Employee Training Records Retention Location IATF 16949 - Automotive Quality Systems Standard 2
K Verify Software Architecture - supporting interfaces between items IEC 62304 - Medical Device Software Life Cycle Processes 2
J Supporting functions with no actual activity started IATF 16949 - Automotive Quality Systems Standard 2
M Informational Health Canada – Guidance Document: Supporting Evidence for Implantable Medical Devices Manufactured by 3D Printing Medical Device and FDA Regulations and Standards News 0
M Why have IATF rules required the CBs to audit remote supporting functions at first? IATF 16949 - Automotive Quality Systems Standard 11
D Supporting Process Definitions - Remote Locations IATF 16949 - Automotive Quality Systems Standard 4
C Supplier Assessment for Hardware supporting SaMD ISO 13485:2016 - Medical Device Quality Management Systems 1
S Does the cable assembly supporting a medical device gets classified accordingly? US Food and Drug Administration (FDA) 1
J Supporting Processes - Internal Audits - Need help settling a debate IATF 16949 - Automotive Quality Systems Standard 4
Z Labeling Requirements for Free Samples supporting Clinical Evaluation EU Medical Device Regulations 2
F ISO/TS 16949 - Auditing supporting activities IATF 16949 - Automotive Quality Systems Standard 1
S Can you suggest a Root Cause supporting Out of Specification Process AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 7
J Why are remote supporting functions audited first? IATF 16949 - Automotive Quality Systems Standard 2
J Example of additional Audits of Remote Supporting Functions IATF 16949 - Automotive Quality Systems Standard 2
W Supporting the Customer after Termination of a Contract Other Medical Device and Orthopedic Related Topics 2
B I wish to know about Concept of Supporting Documents (Documents of External Origin) Document Control Systems, Procedures, Forms and Templates 1
F Benefits of Internal Audits in supporting Safety and Quality Management Systems Internal Auditing 5
S Validation Plan Template for Supporting Software Tools (subversion, bugzilla,etc) IEC 62304 - Medical Device Software Life Cycle Processes 1
J Supporting Processes - Legal and Communications Department ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 8
D Process Equipment and Supporting Service ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 2
S Definition Core Procedures and Supporting Procedures - Definitions Definitions, Acronyms, Abbreviations and Interpretations Listed Alphabetically 7
Ajit Basrur Mold Material Standard - Material for making molds supporting medical devices ISO 13485:2016 - Medical Device Quality Management Systems 10
H Preventive Action procedure and supporting document Preventive Action and Continuous Improvement 2
M Supporting Sites, Separate Certificates and Audit Reports - IAOB TS 16949 rules? Registrars and Notified Bodies 9
Douglas E. Purdy 4.2.3 Reference Supporting Procedures including Technical Procedures General Measurement Device and Calibration Topics 3
D Interpretation of 6.3.c - Supporting Services ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 3
J Looking for a Quality Manual and all of it's supporting Procedures, Flowcharts Quality Management System (QMS) Manuals 7
J How many secondary/supporting documents will be associated with the new DIS version? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 5
A ISO 9001- any advise please with transitioning from a paper based system to eQMS and multi site scope ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 1
R CQI 9 site specific IATF 16949 - Automotive Quality Systems Standard 3
F Site level CMRT reporting: how? Miscellaneous Environmental Standards and EMS Related Discussions 0
T Ford Q1 MSA - Virtual Site Visit Hardware Manufacturing and Related Processes 14
R Transport of components off site for final assembly. Medical Device Related Regulations 2
Vader22 IATF 16949 extended manufacturing site help IATF 16949 - Automotive Quality Systems Standard 4
chris1price Irradiation site for dose audit Other Medical Device Related Standards 2
A Alternative to on site audit in China EU Medical Device Regulations 2
eldercare Multi-Site ISO/AS Certification Requirement for some sites ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 22
P Manufacturing site vs manufacturing date symbol Medical Device and FDA Regulations and Standards News 1
D Secondary Manufacturing Site on DoC EU Medical Device Regulations 1
B Site removal from MDSAP multi-site Certificate ISO 13485:2016 - Medical Device Quality Management Systems 4
R IATF 16949 Certification for new site with transferred product--what is the impact with CSR and scorecards? IATF 16949 - Automotive Quality Systems Standard 4
M IATF 16949 - Audit of Remote Location/Support Site and IT IATF 16949 - Automotive Quality Systems Standard 4
S Would this be a second site for the purposes of internal and third party audits? General Auditing Discussions 4
M Office and manufacturing site relocation effect on Device Technical File CE Marking (Conformité Européene) / CB Scheme 2
A OEM On-Site Calibration issues during Covid19 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 12
SANTHSH API Spec. Q1 clause 5.6.1.2 On site evaluation Oil and Gas Industry Standards and Regulations 12
D Limited Scope for second site Question? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 5
M Sites to List on Multi-Site Certifications Registrars and Notified Bodies 1
D Certifcate of Free Sale Listing Physical Site from Belgium Competant Authority EU Medical Device Regulations 3
N Address of Legal Manufacturing Site in ISO 13485 certificates? ISO 13485:2016 - Medical Device Quality Management Systems 1
