Surface Finish - Callout as 8 - 16 Rq
We have a customer stating their interpretation of the below surface finish callout as 8 - 16 Rq, when I read this I see the call-out for Ra. Please chime in with supporting information. As I understand, this is a basic surface finish call-out.
Those are definitely Ra callouts. See also. To specify Rq, the arm should be added and the Rq specification added below in brackets. See the second picture for an example.
GoKats78 Callout on Surface Finish General Measurement Device and Calibration Topics 11
J Gear Surface Finish - Print with the word "calibrated" Manufacturing and Related Processes 2
S Difference between Surface Finish (Ra) and Flatness (GD&T) Inspection, Prints (Drawings), Testing, Sampling and Related Topics 6
Proud Liberal Surface finish measurement (roughness) - Rz under the ISO standard vs ANSI standard Inspection, Prints (Drawings), Testing, Sampling and Related Topics 0
Proud Liberal Measuring axial and radial surface finish (16 Rz) on a broached internal radius Inspection, Prints (Drawings), Testing, Sampling and Related Topics 1
B Surface Finish Equipment MSA (Measurement System Analysis) Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 5
kedarg6500 Surface Finish Measurement Methods Inspection, Prints (Drawings), Testing, Sampling and Related Topics 13
P Surface Finish measurement for machined (finished) component/part Inspection, Prints (Drawings), Testing, Sampling and Related Topics 2
J Definition Standards for Dimensions and Surface Finish on a Rod Definitions, Acronyms, Abbreviations and Interpretations Listed Alphabetically 11
A Is it mandatory to have a profilometer to inspect >16 surface finish? General Measurement Device and Calibration Topics 8
T Interpretation of Surface Finish Specification Manufacturing and Related Processes 2
D Surface Finish Inspection Company (Laboratory) (Detroit area) needed Manufacturing and Related Processes 1
A Conducting a DOE in Minitab - Improving Surface Finish of an Impeller Using Minitab Software 10
N PCB (medical device) Surface Finish Selection. Manufacturing and Related Processes 2
S Surface Finish - Conversion factor to transform Rz Jis in Rz Inspection, Prints (Drawings), Testing, Sampling and Related Topics 6
N MSA (Measurement Systems Analysis) for Surface Finish Equipment Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 3
P Inner Diameter Surface Finish Ra Value vs. Surface Finish Graph Output Manufacturing and Related Processes 11
ScottK Inspecting surface finish on SS on a piece that can't be measured with current equip. Inspection, Prints (Drawings), Testing, Sampling and Related Topics 2
ScottK Surface Finish on machined brass (or other metals)- Attribute or Variable inspection? Inspection, Prints (Drawings), Testing, Sampling and Related Topics 8
ScottK Measuring Capability on a One Sided Variable (Surface Finish) Capability, Accuracy and Stability - Processes, Machines, etc. 17
W Surface Finish parameters - Mechanical stylus based testing of a cylindrical part Manufacturing and Related Processes 2
W Surface Finish Measurement Technique Manufacturing and Related Processes 3
T Surface Finish Requirements (Ra 150) for Blasted Titanium Surfaces Manufacturing and Related Processes 12
J Surface Finish Tester Recommendations with both Ra and Rz (english and metric) scales Inspection, Prints (Drawings), Testing, Sampling and Related Topics 1
Ron Rompen Conversion of surface finish measurements Inspection, Prints (Drawings), Testing, Sampling and Related Topics 4
U How to do Gage R&Rs on Surface Finish Gages Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 3
Geoff Cotton Surface Finish - G5 - Where is this from and how can I measure it? Manufacturing and Related Processes 6
Marc Surface Finish Gage R&R Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 4
J The best way to define a surface finish General Measurement Device and Calibration Topics 1
J Surface Finish - What is the meaning of the term ?LAY?? Coffee Break and Water Cooler Discussions 4
D Air Gauging: Are the results affected by surface finish of the bore? General Measurement Device and Calibration Topics 1
R Design and Manufacture Guidelines for Surface Mount Technology Misc. Quality Assurance and Business Systems Related Topics 8
M Active Surface Disinfectant Claims - FDA vs EPA and Hands vs Objects Other Medical Device and Orthopedic Related Topics 0
P Gas Nitriding Surface Hardening of Stainless Steel 304 ISO 13485:2016 - Medical Device Quality Management Systems 4
N Creepage - Does a surface mount isolator body negate a PCB slot? IEC 60601 - Medical Electrical Equipment Safety Standards Series 6
CCaantley Where to get a good test indicator stand for a granite surface plate General Measurement Device and Calibration Topics 8
M Interesting Discussion Surface Cleanliness Real Time Test Tools General Measurement Device and Calibration Topics 2
P Romer Arm - Profile of a Surface Changing General Measurement Device and Calibration Topics 4
R Reporting Profile of a surface with U modifier Inspection, Prints (Drawings), Testing, Sampling and Related Topics 3
S Response Surface Method to create design matrix in Minitab Using Minitab Software 5
B Profile of a Surface Callout on this Drawing General Measurement Device and Calibration Topics 4
O Can a Profile of a Surface have a Diameter Symbol? Inspection, Prints (Drawings), Testing, Sampling and Related Topics 3
Q Surface Roughness - Conversion of RS on a Print to RZ General Measurement Device and Calibration Topics 3
S ARP 1820 Surface Contamination Testing Various Other Specifications, Standards, and related Requirements 1
N Projection welding of nuts on zinc coated surface Manufacturing and Related Processes 3
K Can a Surface of a profile be applied to a feature of size? GD&T questions Inspection, Prints (Drawings), Testing, Sampling and Related Topics 1
alonFAI Component Failure (Relay) during ICT Testing after Surface Mount Assembly Manufacturing and Related Processes 5
W Profilometer Surface Roughness Tester Issue - Ball Bearings ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 7
H Stainless Steel Surface Quality for Ophthalmic Surgical Device Other Medical Device Related Standards 11
J Profile of Surface with Basics and Angle Inspection, Prints (Drawings), Testing, Sampling and Related Topics 10
