Surface Finish Gage R&R
Marc
Received in my personal e-mail"
> We have a problem to achieve good results on surface finish GR&R. We are using
> actual machined part to run GR&R. We are using 10 parts, 3 operator, 3 trial.
> GR&R calculate using minitab software, stud variation(number of standard
> deviation) is 6.0 and process tolerance i.e. spec tolerance.
> Please provide any example, I will be appreciated for your help.
Any takers on this one?
Mike S.
Happy to be Alive
I don't completely understand the writer's message, but I will suggest one thing: Don't use an "actual machined part" to do the GR&R as the SF variation within the part is unknown. I would suggest using a surface finish standard, preferably one with Ra similar to the expected values of the machined parts, to do the GR&R.
Darius
IMO, in the making of R&R, an issue is almost always missing, "RATIONAL SAMPLING & SUBGROUPING", I ask allways to the guys that work with me to tink R&R as a control chart (I tink is not new for you, but for many...).
And what is about? ,I tink almost always forget when teaching R&R, the importance of maximizate the between samples (or samples) and minimizate the within sample variation (or trials). Even I told them to try to take all th posible variation of the process in account (meanning the highest and the lowest values that can be obtained).
:bonk: IMO or the measure system doen't work or rational sampling was not achived.
The Taz!
IMHO. . . being a destructive test to start with, you cannot re-trace the same track and get suitable results. Suggest you look at Repeatability against a known standard. . . or defer to annual calibration (Or other suitable frequency) and inspection of the stylus to detect excessive wear or chipping at scheduled intervals based on usage.
Tom Slack
I'm not sure what "good results" mean, need more details. Does this person want advice on data diagnostic methods? Should expect variability in decreasing order to be part to part, operator to operator, trial to trial. I also like to take the residuals and plot them up in the order they were done.
Tom
U How to do Gage R&Rs on Surface Finish Gages Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 4
K Surface finish (Evaluation Length) Inspection, Prints (Drawings), Testing, Sampling and Related Topics 3
Ron Rompen Surface Finish Correlation between Ra, Rz and Tp (bearing surface ratio) General Measurement Device and Calibration Topics 3
J Gear Surface Finish - Print with the word "calibrated" Manufacturing and Related Processes 2
8 Surface Finish - Callout as 8 - 16 Rq Manufacturing and Related Processes 1
GoKats78 Callout on Surface Finish General Measurement Device and Calibration Topics 11
S Difference between Surface Finish (Ra) and Flatness (GD&T) Inspection, Prints (Drawings), Testing, Sampling and Related Topics 6
Proud Liberal Surface finish measurement (roughness) - Rz under the ISO standard vs ANSI standard Inspection, Prints (Drawings), Testing, Sampling and Related Topics 0
Proud Liberal Measuring axial and radial surface finish (16 Rz) on a broached internal radius Inspection, Prints (Drawings), Testing, Sampling and Related Topics 1
B Surface Finish Equipment MSA (Measurement System Analysis) Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 5
kedarg6500 Surface Finish Measurement Methods Inspection, Prints (Drawings), Testing, Sampling and Related Topics 13
P Surface Finish measurement for machined (finished) component/part Inspection, Prints (Drawings), Testing, Sampling and Related Topics 2
J Definition Standards for Dimensions and Surface Finish on a Rod Definitions, Acronyms, Abbreviations and Interpretations Listed Alphabetically 11
A Is it mandatory to have a profilometer to inspect >16 surface finish? General Measurement Device and Calibration Topics 8
T Interpretation of Surface Finish Specification Manufacturing and Related Processes 2
D Surface Finish Inspection Company (Laboratory) (Detroit area) needed Manufacturing and Related Processes 1
A Conducting a DOE in Minitab - Improving Surface Finish of an Impeller Using Minitab Software 10
N PCB (medical device) Surface Finish Selection. Manufacturing and Related Processes 2
S Surface Finish - Conversion factor to transform Rz Jis in Rz Inspection, Prints (Drawings), Testing, Sampling and Related Topics 6
N MSA (Measurement Systems Analysis) for Surface Finish Equipment Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 3
P Inner Diameter Surface Finish Ra Value vs. Surface Finish Graph Output Manufacturing and Related Processes 11
ScottK Inspecting surface finish on SS on a piece that can't be measured with current equip. Inspection, Prints (Drawings), Testing, Sampling and Related Topics 2
ScottK Surface Finish on machined brass (or other metals)- Attribute or Variable inspection? Inspection, Prints (Drawings), Testing, Sampling and Related Topics 8
ScottK Measuring Capability on a One Sided Variable (Surface Finish) Capability, Accuracy and Stability - Processes, Machines, etc. 17
W Surface Finish parameters - Mechanical stylus based testing of a cylindrical part Manufacturing and Related Processes 2
W Surface Finish Measurement Technique Manufacturing and Related Processes 3
T Surface Finish Requirements (Ra 150) for Blasted Titanium Surfaces Manufacturing and Related Processes 12
J Surface Finish Tester Recommendations with both Ra and Rz (english and metric) scales Inspection, Prints (Drawings), Testing, Sampling and Related Topics 1
Ron Rompen Conversion of surface finish measurements Inspection, Prints (Drawings), Testing, Sampling and Related Topics 4
Geoff Cotton Surface Finish - G5 - Where is this from and how can I measure it? Manufacturing and Related Processes 6
J The best way to define a surface finish General Measurement Device and Calibration Topics 1
J Surface Finish - What is the meaning of the term ?LAY?? Coffee Break and Water Cooler Discussions 4
D Air Gauging: Are the results affected by surface finish of the bore? General Measurement Device and Calibration Topics 1
S Surface roughness Rz Manufacturing and Related Processes 1
L GD&T Position for surface Inspection, Prints (Drawings), Testing, Sampling and Related Topics 9
P Surface scratch measurement General Measurement Device and Calibration Topics 1
D Surface Roughness understanding Inspection, Prints (Drawings), Testing, Sampling and Related Topics 1
D Calibration of Digital thermometer with surface probe General Measurement Device and Calibration Topics 1
R Design and Manufacture Guidelines for Surface Mount Technology Misc. Quality Assurance and Business Systems Related Topics 9
M Active Surface Disinfectant Claims - FDA vs EPA and Hands vs Objects Other Medical Device and Orthopedic Related Topics 0
P Gas Nitriding Surface Hardening of Stainless Steel 304 ISO 13485:2016 - Medical Device Quality Management Systems 4
N Creepage - Does a surface mount isolator body negate a PCB slot? IEC 60601 - Medical Electrical Equipment Safety Standards Series 6
CCaantley Where to get a good test indicator stand for a granite surface plate General Measurement Device and Calibration Topics 8
M Interesting Discussion Surface Cleanliness Real Time Test Tools General Measurement Device and Calibration Topics 2
P Romer Arm - Profile of a Surface Changing General Measurement Device and Calibration Topics 4
R Reporting Profile of a surface with U modifier Inspection, Prints (Drawings), Testing, Sampling and Related Topics 4
S Response Surface Method to create design matrix in Minitab Using Minitab Software 5
B Profile of a Surface Callout on this Drawing General Measurement Device and Calibration Topics 4
O Can a Profile of a Surface have a Diameter Symbol? Inspection, Prints (Drawings), Testing, Sampling and Related Topics 3
Q Surface Roughness - Conversion of RS on a Print to RZ General Measurement Device and Calibration Topics 3
