Surface Finish on machined brass (or other metals)- Attribute or Variable inspection?
ScottK
Not out of the crisis
This is directly realted to another thread I started about Surface Finish Capability http://elsmar.com/Forums/showthread.php?t=26288
I'm wonder what practice is out there.
In my particular application I don't see why it can't be an attribute.
As long as the surface finish is below, say, 64Ra the part will be fine. It will function the same at 63 as it will at 4.
So even though I'm "measuring" why shouldn't my device be a go/no-go?
You can do attribute gauge R&R and attribute capability studies.
Please poke holes in my logic and tell me why I might be wrong.
why do I ask? because there are people out there that are demanding that if I do not meet 1.33 Cpk based on variable capability studies (see previous thread I reference) I need to do 100% inspection.
And that's really getting up my nose because I know from history that once the machine is set, barring a crash that will mess up every other characteristic on the part , I will not exceed the maximum even if the range is such that I am below even 1.00 Cpk.
AND all of the finished parts that this component goes into are 100% tested as part of hte assembly process anway!!!
(ok - that last bit was a rant, but I'm really :frust: )
Duke Okes
Re: Surface Finish on machined brass (or other metals) - Attribute or Variable?
By definition, and assuming a normal distribution, if the Cpk is 1.0 or less you will have some parts out of specification (estimate would be 100%-99.73%, or 27 out of 1000 for a Cpk of exactly 1.0).
ScottK
yes - I understand that.
All too well I understand that.
And, if you look at the other thread, I do not believe Cpk is warranted in my case.
Jen Kirley
Quality and Auditing Expert
A scratch is an attribute. Surface finish is a variable.
An rhr comparator can be used as a go/no go gage when inspection criteria calls out "only 64 rhr and finer is acceptable" but the finish is still variable to the extent of your process refinement.
A plug go/no go gage is the same way. The size of the hole is variable, but the inspection is defined as go/no go.
So I guess the only thing I can advise is to let go of the attribute vs. variable terms unless you are charting performance; in that case, a c, np or p chart would be used instead of a u chart. I do not see why you can't find a cpk with this data. Here is a thread that talks about cpk with attribute data: Cp, Cpk calculation for np chart - No USL or LSL - SMT Production
ScottK
Yes - it's ultimately a variable as it can be measured. But I want to treat it as either good or bad.
That's excactly what our specification/inspection criteria calls out.
Max Ra for surface finish = X.
it doesn't say 0-X or Y+-Z.
Sure I can do a Cpk. It's just a calculation.
I don't believe it's a valid measure of the capability of the process in this application (not to mention I'm dealing with people who are not open to negotiation on that point :mad:).
That's based on history and the distribution, which is not normal.
WARNING: RANT COMING
...and there in lies the fallacy of the Cp-Ppk abomination perpetuated by "check the box people" who don't understand statistics or physics...most processes are NOT Normal. even minor deviations from Normality in the tails can lead to terribly innaccurate "predictions" about defect rates.
I urge you to read Bert Gunter's series on this topic - it is available thru ASQ...
The tyranny of this urban myth is unbelievable.
Kales Veggie
People: The Vital Few
:2cents: (assuming you are measuring Ra in micro inch, not microns)
I am assuming that the part is machined and would be classified as smooth turned. The Ra value is determined by the speeds and feeds of the lathe and/or machine centre (basically how fast is the tool going across the surface). Ra < 32 is usually ground or polished.
Is this surface finish a special characteristic? How significant is the surface finish for the application?
If the answers are "no" and "not" (I believe that is what you indicated) I would accept attribute data from a supplier.
The other question is if attribute data is sufficient for process control at the supplier. I believe not. Variable data must be used.
Re: Surface Finish on machined brass (or other metals)- Attribute or Variable inspect
back to the original question: yes of course you can treat the surface finish as Attributes data and then calculate the Cpk value. The effectiveness of this approach depends on how the surface finish functions in the assembly and how the specification limit was derived (anatomical, historical or engineered)
When I have found myself in this position, I have gotten the data (control charts, multi-vari chart vs spec limit, etc.) that shows that I have a stable controlled process that meets spec (no defects historically). Then I have a face to face discusion with the supplier engineer to understand the assembly need and my process's performance. When actually confronted with the data and the physics, logic typically rules. be warned however, that there have been times when the supplier engineer has explained that the spec is wrong and they are trying to control the extreme values near the limit that actually cause failures, btu the politics keeps them from actually changing the specs...
A lot depends on how critical the surface finish is. You can buy a set of exemplars called "thumbnail" (or "tactile," or "touch") comparators that provide a visual and tactile way of comparing one finish with another. You can see an example here. It's an adequate method in some instances when all you really need to know can be ascertained by a simple comparison.
P Surface Finish measurement for machined (finished) component/part Inspection, Prints (Drawings), Testing, Sampling and Related Topics 2
K Surface finish (Evaluation Length) Inspection, Prints (Drawings), Testing, Sampling and Related Topics 3
Ron Rompen Surface Finish Correlation between Ra, Rz and Tp (bearing surface ratio) General Measurement Device and Calibration Topics 3
J Gear Surface Finish - Print with the word "calibrated" Manufacturing and Related Processes 2
8 Surface Finish - Callout as 8 - 16 Rq Manufacturing and Related Processes 1
GoKats78 Callout on Surface Finish General Measurement Device and Calibration Topics 11
S Difference between Surface Finish (Ra) and Flatness (GD&T) Inspection, Prints (Drawings), Testing, Sampling and Related Topics 6
Proud Liberal Surface finish measurement (roughness) - Rz under the ISO standard vs ANSI standard Inspection, Prints (Drawings), Testing, Sampling and Related Topics 0
Proud Liberal Measuring axial and radial surface finish (16 Rz) on a broached internal radius Inspection, Prints (Drawings), Testing, Sampling and Related Topics 1
B Surface Finish Equipment MSA (Measurement System Analysis) Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 5
kedarg6500 Surface Finish Measurement Methods Inspection, Prints (Drawings), Testing, Sampling and Related Topics 13
J Definition Standards for Dimensions and Surface Finish on a Rod Definitions, Acronyms, Abbreviations and Interpretations Listed Alphabetically 11
A Is it mandatory to have a profilometer to inspect >16 surface finish? General Measurement Device and Calibration Topics 8
T Interpretation of Surface Finish Specification Manufacturing and Related Processes 2
D Surface Finish Inspection Company (Laboratory) (Detroit area) needed Manufacturing and Related Processes 1
A Conducting a DOE in Minitab - Improving Surface Finish of an Impeller Using Minitab Software 10
N PCB (medical device) Surface Finish Selection. Manufacturing and Related Processes 2
S Surface Finish - Conversion factor to transform Rz Jis in Rz Inspection, Prints (Drawings), Testing, Sampling and Related Topics 6
N MSA (Measurement Systems Analysis) for Surface Finish Equipment Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 3
P Inner Diameter Surface Finish Ra Value vs. Surface Finish Graph Output Manufacturing and Related Processes 11
ScottK Inspecting surface finish on SS on a piece that can't be measured with current equip. Inspection, Prints (Drawings), Testing, Sampling and Related Topics 2
ScottK Measuring Capability on a One Sided Variable (Surface Finish) Capability, Accuracy and Stability - Processes, Machines, etc. 17
W Surface Finish parameters - Mechanical stylus based testing of a cylindrical part Manufacturing and Related Processes 2
W Surface Finish Measurement Technique Manufacturing and Related Processes 3
T Surface Finish Requirements (Ra 150) for Blasted Titanium Surfaces Manufacturing and Related Processes 12
J Surface Finish Tester Recommendations with both Ra and Rz (english and metric) scales Inspection, Prints (Drawings), Testing, Sampling and Related Topics 1
Ron Rompen Conversion of surface finish measurements Inspection, Prints (Drawings), Testing, Sampling and Related Topics 4
U How to do Gage R&Rs on Surface Finish Gages Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 4
Geoff Cotton Surface Finish - G5 - Where is this from and how can I measure it? Manufacturing and Related Processes 6
Marc Surface Finish Gage R&R Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 4
J The best way to define a surface finish General Measurement Device and Calibration Topics 1
J Surface Finish - What is the meaning of the term ?LAY?? Coffee Break and Water Cooler Discussions 4
D Air Gauging: Are the results affected by surface finish of the bore? General Measurement Device and Calibration Topics 1
S Surface roughness Rz Manufacturing and Related Processes 1
L GD&T Position for surface Inspection, Prints (Drawings), Testing, Sampling and Related Topics 9
P Surface scratch measurement General Measurement Device and Calibration Topics 1
D Surface Roughness understanding Inspection, Prints (Drawings), Testing, Sampling and Related Topics 1
D Calibration of Digital thermometer with surface probe General Measurement Device and Calibration Topics 1
R Design and Manufacture Guidelines for Surface Mount Technology Misc. Quality Assurance and Business Systems Related Topics 9
M Active Surface Disinfectant Claims - FDA vs EPA and Hands vs Objects Other Medical Device and Orthopedic Related Topics 0
P Gas Nitriding Surface Hardening of Stainless Steel 304 ISO 13485:2016 - Medical Device Quality Management Systems 4
N Creepage - Does a surface mount isolator body negate a PCB slot? IEC 60601 - Medical Electrical Equipment Safety Standards Series 6
CCaantley Where to get a good test indicator stand for a granite surface plate General Measurement Device and Calibration Topics 8
M Interesting Discussion Surface Cleanliness Real Time Test Tools General Measurement Device and Calibration Topics 2
P Romer Arm - Profile of a Surface Changing General Measurement Device and Calibration Topics 4
R Reporting Profile of a surface with U modifier Inspection, Prints (Drawings), Testing, Sampling and Related Topics 4
S Response Surface Method to create design matrix in Minitab Using Minitab Software 5
B Profile of a Surface Callout on this Drawing General Measurement Device and Calibration Topics 4
O Can a Profile of a Surface have a Diameter Symbol? Inspection, Prints (Drawings), Testing, Sampling and Related Topics 3
Q Surface Roughness - Conversion of RS on a Print to RZ General Measurement Device and Calibration Topics 3
