Surface mount resistor as a MOPP (Means Of Patient Protection)
jmalm
#11
"One could argue that this is not "electric shock" and therefore specific requirements for MOPP do not apply."
Reading the 60601-1 annex implies that we should include other harms, including tissue necrosis, when implementing protection regimes.
The guidance I have received from test labs generally matches Peter's statements. Personally I would ensure no cascading failures can result from a single component failure that would lead to unacceptable risk. For example with an ECG if you have input diode clamps to a smaller voltage than the supply voltage of an input amplifier, a short on the input amplifier to a power rail could result in unacceptable DC current flow through the leads.
R Design and Manufacture Guidelines for Surface Mount Technology Misc. Quality Assurance and Business Systems Related Topics 9
N Creepage - Does a surface mount isolator body negate a PCB slot? IEC 60601 - Medical Electrical Equipment Safety Standards Series 6
alonFAI Component Failure (Relay) during ICT Testing after Surface Mount Assembly Manufacturing and Related Processes 5
C Carton Boxes for Surface Mount Tape and Reel Manufacturing and Related Processes 7
P SMT (Surface Mount Technology) and PCBA Process Validation ISO 13485:2016 - Medical Device Quality Management Systems 2
B Looking for Photos of Surface Mount Device (SMD) Soldering Manufacturing and Related Processes 14
S Calibration of SMT (Surface Mount) Assembly Machines Calibration Frequency (Interval) 13
J PFMEA example for SMT (Surface Mount Technology) FMEA and Control Plans 9
Marc SMT (Surface Mount Technology) Sampling Plan in a SMT & COB Assembly Company Inspection, Prints (Drawings), Testing, Sampling and Related Topics 3
S Surface roughness Rz Manufacturing and Related Processes 1
L GD&T Position for surface Inspection, Prints (Drawings), Testing, Sampling and Related Topics 9
K Surface finish (Evaluation Length) Inspection, Prints (Drawings), Testing, Sampling and Related Topics 3
Ron Rompen Surface Finish Correlation between Ra, Rz and Tp (bearing surface ratio) General Measurement Device and Calibration Topics 3
P Surface scratch measurement General Measurement Device and Calibration Topics 1
D Surface Roughness understanding Inspection, Prints (Drawings), Testing, Sampling and Related Topics 1
D Calibration of Digital thermometer with surface probe General Measurement Device and Calibration Topics 1
J Gear Surface Finish - Print with the word "calibrated" Manufacturing and Related Processes 2
8 Surface Finish - Callout as 8 - 16 Rq Manufacturing and Related Processes 1
M Active Surface Disinfectant Claims - FDA vs EPA and Hands vs Objects Other Medical Device and Orthopedic Related Topics 0
GoKats78 Callout on Surface Finish General Measurement Device and Calibration Topics 11
P Gas Nitriding Surface Hardening of Stainless Steel 304 ISO 13485:2016 - Medical Device Quality Management Systems 4
S Difference between Surface Finish (Ra) and Flatness (GD&T) Inspection, Prints (Drawings), Testing, Sampling and Related Topics 6
CCaantley Where to get a good test indicator stand for a granite surface plate General Measurement Device and Calibration Topics 8
M Interesting Discussion Surface Cleanliness Real Time Test Tools General Measurement Device and Calibration Topics 2
P Romer Arm - Profile of a Surface Changing General Measurement Device and Calibration Topics 4
R Reporting Profile of a surface with U modifier Inspection, Prints (Drawings), Testing, Sampling and Related Topics 4
S Response Surface Method to create design matrix in Minitab Using Minitab Software 5
Proud Liberal Surface finish measurement (roughness) - Rz under the ISO standard vs ANSI standard Inspection, Prints (Drawings), Testing, Sampling and Related Topics 0
Proud Liberal Measuring axial and radial surface finish (16 Rz) on a broached internal radius Inspection, Prints (Drawings), Testing, Sampling and Related Topics 1
B Profile of a Surface Callout on this Drawing General Measurement Device and Calibration Topics 4
O Can a Profile of a Surface have a Diameter Symbol? Inspection, Prints (Drawings), Testing, Sampling and Related Topics 3
Q Surface Roughness - Conversion of RS on a Print to RZ General Measurement Device and Calibration Topics 3
S ARP 1820 Surface Contamination Testing Various Other Specifications, Standards, and related Requirements 1
N Projection welding of nuts on zinc coated surface Manufacturing and Related Processes 3
K Can a Surface of a profile be applied to a feature of size? GD&T questions Inspection, Prints (Drawings), Testing, Sampling and Related Topics 1
W Profilometer Surface Roughness Tester Issue - Ball Bearings ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 7
H Stainless Steel Surface Quality for Ophthalmic Surgical Device Other Medical Device Related Standards 11
J Profile of Surface with Basics and Angle Inspection, Prints (Drawings), Testing, Sampling and Related Topics 10
E Help me with Surface Plate Calibration General Measurement Device and Calibration Topics 10
G Generally accepted Tolerance for Surface Reflectance Various Other Specifications, Standards, and related Requirements 3
M Please help to analyze Response Surface Methodology by using Minitab 16 Using Minitab Software 6
T Variation in values of the levels in Factorial/Response surface design Using Minitab Software 1
B Surface Finish Equipment MSA (Measurement System Analysis) Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 5
R When a Part Print specifies 10 Rmax on a Surface - Rmax Settings & Standards? General Measurement Device and Calibration Topics 2
kedarg6500 Surface Finish Measurement Methods Inspection, Prints (Drawings), Testing, Sampling and Related Topics 13
C Mitutoyo SJ210 Settings - Is there an Industry Standard Surface Measurement Setting? General Measurement Device and Calibration Topics 4
L Flat Surface Granite Table Calibration Requirements Calibration Frequency (Interval) 16
C Complex Surface Profile as a datum Inspection, Prints (Drawings), Testing, Sampling and Related Topics 8
K How to Calculate Sample Size at 95% Confidence Interval on Surface Roughness Inspection, Prints (Drawings), Testing, Sampling and Related Topics 1
C Measurement System to measure Hole Diameters, True Positions, Surface Profiles, etc General Measurement Device and Calibration Topics 4
