Surface Plates Resurfaced and Calibrated yearly - Is this necessary?
O
Oriondad
Howdy All,
We have in the past had our plates resurfaced and calibrated yearly. I am now questioning whether that is practical. Some plates get very little usage, while others may be used daily. I contend that we can set our calibrations based on usage. Therefore, some plates we may only need to resurface and calibrate every other year, while the high usage plates need calibration yearly. I haven't found anything is any standard to contradict this position. We do this for our gage blocks, so hence, why not for our plates?
Any input is appreciated.
Re: Surface Plates
Oriondad said:
Howdy All,
There's no reason that you shouldn't base your calibration schedules on practical experience. You can use "as found" results as your justification. In other words, if you have records that demonstrate that no resurfacing or other adjustment was necessary after calibration, you can base your schedule(s) on those findings.
Cari Spears
Oriondad said:
Howdy All,
Howdy to you too!:bigwave:
We get all of ours done yearly here - but I used to work at a company with dozens of surface plates scattered between the three buildings they occupied. They did exactly as you're proposing - each plate had it's own schedule based on usage and justified by past "as found" results. It saved them a lot of money.
G
Grizz1345
Our calibration procedure states that if no adjustments are made in the last three calibration cycles that we can extend the cycle time. This has passed both QS9000 and ISO 9001-2000 registration audits with no trouble.:)
Hershal
Metrologist-Auditor
It depends on your use.
First thing to do is determine for each plate what grade you require for that usage, whether AA, A, or B.....then you have a solid point to determine - based on what your cal lab finds - whether to extend the cycle and by how much. I would not go beyond three years, even for an AA, kept in a tightly controlled environment.
Also, ask the cal lab for recommendations on extending the cycle.....a reputable lab will try to give a realistic answer that is workable for you.
Hope this helps.
Hershal
O
Oriondad
Thanks for your input.
I am rather ignorant regarding calibrations and such. Mainly manage the ISO program and am somewhat familiar with calibration requirements. We have a trainee handling our gages and they are doing, from what I can tell, a good job of managing it.
Just so you all know, I check our reports from our supplier (Inspec) and for the most part all the plates, last year, checked out of tolerance. So I guess we are destined to have all 30 plates redone yet again!!!!
Thanks :applause:
Helmut Jilling
Auditor / Consultant
Thanks :applause:
If the calibration last year showed them to be out of tolerance, why weren't they repaired (resurfaced) at that time. If they were placed back into service without repair, all the calibrations they were used for in the last year are suspect.
A Calibrated Surface Plates treated as General Use Tables General Measurement Device and Calibration Topics 9
C I need to verify the surface profile of a part - Sine plates General Measurement Device and Calibration Topics 4
D Calibration Method for Small Surface Plates (6" x 6") General Measurement Device and Calibration Topics 8
M Surface plates - Questioning the need for periodic calibration of surface plates General Measurement Device and Calibration Topics 12
S Granite Surface Plates - Maintenance, DOs and DON'Ts Manufacturing and Related Processes 9
S Surface roughness Rz Manufacturing and Related Processes 1
L GD&T Position for surface Inspection, Prints (Drawings), Testing, Sampling and Related Topics 9
K Surface finish (Evaluation Length) Inspection, Prints (Drawings), Testing, Sampling and Related Topics 3
Ron Rompen Surface Finish Correlation between Ra, Rz and Tp (bearing surface ratio) General Measurement Device and Calibration Topics 3
P Surface scratch measurement General Measurement Device and Calibration Topics 1
D Surface Roughness understanding Inspection, Prints (Drawings), Testing, Sampling and Related Topics 1
D Calibration of Digital thermometer with surface probe General Measurement Device and Calibration Topics 1
J Gear Surface Finish - Print with the word "calibrated" Manufacturing and Related Processes 2
R Design and Manufacture Guidelines for Surface Mount Technology Misc. Quality Assurance and Business Systems Related Topics 9
8 Surface Finish - Callout as 8 - 16 Rq Manufacturing and Related Processes 1
M Active Surface Disinfectant Claims - FDA vs EPA and Hands vs Objects Other Medical Device and Orthopedic Related Topics 0
GoKats78 Callout on Surface Finish General Measurement Device and Calibration Topics 11
P Gas Nitriding Surface Hardening of Stainless Steel 304 ISO 13485:2016 - Medical Device Quality Management Systems 4
S Difference between Surface Finish (Ra) and Flatness (GD&T) Inspection, Prints (Drawings), Testing, Sampling and Related Topics 6
N Creepage - Does a surface mount isolator body negate a PCB slot? IEC 60601 - Medical Electrical Equipment Safety Standards Series 6
CCaantley Where to get a good test indicator stand for a granite surface plate General Measurement Device and Calibration Topics 8
M Interesting Discussion Surface Cleanliness Real Time Test Tools General Measurement Device and Calibration Topics 2
P Romer Arm - Profile of a Surface Changing General Measurement Device and Calibration Topics 4
R Reporting Profile of a surface with U modifier Inspection, Prints (Drawings), Testing, Sampling and Related Topics 4
S Response Surface Method to create design matrix in Minitab Using Minitab Software 5
Proud Liberal Surface finish measurement (roughness) - Rz under the ISO standard vs ANSI standard Inspection, Prints (Drawings), Testing, Sampling and Related Topics 0
Proud Liberal Measuring axial and radial surface finish (16 Rz) on a broached internal radius Inspection, Prints (Drawings), Testing, Sampling and Related Topics 1
B Profile of a Surface Callout on this Drawing General Measurement Device and Calibration Topics 4
O Can a Profile of a Surface have a Diameter Symbol? Inspection, Prints (Drawings), Testing, Sampling and Related Topics 3
Q Surface Roughness - Conversion of RS on a Print to RZ General Measurement Device and Calibration Topics 3
S ARP 1820 Surface Contamination Testing Various Other Specifications, Standards, and related Requirements 1
N Projection welding of nuts on zinc coated surface Manufacturing and Related Processes 3
K Can a Surface of a profile be applied to a feature of size? GD&T questions Inspection, Prints (Drawings), Testing, Sampling and Related Topics 1
alonFAI Component Failure (Relay) during ICT Testing after Surface Mount Assembly Manufacturing and Related Processes 5
W Profilometer Surface Roughness Tester Issue - Ball Bearings ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 7
H Stainless Steel Surface Quality for Ophthalmic Surgical Device Other Medical Device Related Standards 11
J Profile of Surface with Basics and Angle Inspection, Prints (Drawings), Testing, Sampling and Related Topics 10
E Help me with Surface Plate Calibration General Measurement Device and Calibration Topics 10
G Generally accepted Tolerance for Surface Reflectance Various Other Specifications, Standards, and related Requirements 3
M Please help to analyze Response Surface Methodology by using Minitab 16 Using Minitab Software 6
T Variation in values of the levels in Factorial/Response surface design Using Minitab Software 1
B Surface Finish Equipment MSA (Measurement System Analysis) Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 5
R When a Part Print specifies 10 Rmax on a Surface - Rmax Settings & Standards? General Measurement Device and Calibration Topics 2
kedarg6500 Surface Finish Measurement Methods Inspection, Prints (Drawings), Testing, Sampling and Related Topics 13
C Mitutoyo SJ210 Settings - Is there an Industry Standard Surface Measurement Setting? General Measurement Device and Calibration Topics 4
L Flat Surface Granite Table Calibration Requirements Calibration Frequency (Interval) 16
C Complex Surface Profile as a datum Inspection, Prints (Drawings), Testing, Sampling and Related Topics 8
K How to Calculate Sample Size at 95% Confidence Interval on Surface Roughness Inspection, Prints (Drawings), Testing, Sampling and Related Topics 1
C Measurement System to measure Hole Diameters, True Positions, Surface Profiles, etc General Measurement Device and Calibration Topics 4
J Looking for a Calibration Facility for a Surface Roughness Tester General Measurement Device and Calibration Topics 2
