Surface Roughness Tester Acceptance Criteria
benzkumar
Dear All,
We have calibrated our Master of our surface roughness tester.
We use Mitutoyo SJ 201. & the master is Ra 2.94
Our calibrated readings are 2.930, 2.944
I Just want to know that what is the acceptance criteria for the master & the observed raedings are within the limit.
Also i calibrated this only for Ra, So can i use the roughness tester for Rz measurememnts.
Thanks,
Selva
Marc
Fully vaccinated are you?
Another quick "Bump". My Thanks in advance to anyone who can help with this one!
Marc
E
erinpristel
Can somebody help me out.
Thanks,
Selva
Selva,
Try this article (qualitymag.com-calibrate-correctly-for roughness) from Quality magazine. Very informative, the answer to your question is typically ?5% of your standard (according to Quality Magazine) and is found at the bottom of the article.
Sorry I can't be of more help. :)
W Profilometer Surface Roughness Tester Issue - Ball Bearings ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 7
J Looking for a Calibration Facility for a Surface Roughness Tester General Measurement Device and Calibration Topics 2
S Measuring Scratches with a Surface Roughness Tester General Measurement Device and Calibration Topics 5
P Portable Surface Roughness Tester Calibration Question (SPI model 14-514-4) General Measurement Device and Calibration Topics 3
P What is "Cut off Length" in Surface roughness tester Manufacturing and Related Processes 7
S Surface roughness Rz Manufacturing and Related Processes 1
D Surface Roughness understanding Inspection, Prints (Drawings), Testing, Sampling and Related Topics 1
Proud Liberal Surface finish measurement (roughness) - Rz under the ISO standard vs ANSI standard Inspection, Prints (Drawings), Testing, Sampling and Related Topics 0
Q Surface Roughness - Conversion of RS on a Print to RZ General Measurement Device and Calibration Topics 3
K How to Calculate Sample Size at 95% Confidence Interval on Surface Roughness Inspection, Prints (Drawings), Testing, Sampling and Related Topics 1
P I need to Borrow or Hire a Surface Roughness (Ra) Measuring Equipment Manufacturing and Related Processes 3
G Standard to use as a guide in measuring surface "roughness" of aluminum tubing General Measurement Device and Calibration Topics 1
M Accredited Surface Roughness Measurement - Requirement for 1Ra surfaces General Measurement Device and Calibration Topics 6
S Correct Length to Measure Surface Roughness Inspection, Prints (Drawings), Testing, Sampling and Related Topics 4
I The difference between Rz and Rz3 Surface Roughness Inspection, Prints (Drawings), Testing, Sampling and Related Topics 6
Jerry Eldred Calibrating Mitutoyo SJ-201P Surface Roughness Testers General Measurement Device and Calibration Topics 4
C Standard for surface roughness on hot rolled steel Manufacturing and Related Processes 2
Q Curve Surface Roughness Measurement & Converting Ra to Rz General Measurement Device and Calibration Topics 8
S Surface Roughness Testing - Comparison of models for measuring Ra, Rmax, Rt, Rz Inspection, Prints (Drawings), Testing, Sampling and Related Topics 4
R Surface Roughness - What is difference between Ra, Rmax & Rt Inspection, Prints (Drawings), Testing, Sampling and Related Topics 6
K Honda Surface Roughness Callout (ex. 12.5S) Customer and Company Specific Requirements 5
D CED Coating in Cast iron surface Reliability Analysis - Predictions, Testing and Standards 0
L GD&T Position for surface Inspection, Prints (Drawings), Testing, Sampling and Related Topics 9
K Surface finish (Evaluation Length) Inspection, Prints (Drawings), Testing, Sampling and Related Topics 3
Ron Rompen Surface Finish Correlation between Ra, Rz and Tp (bearing surface ratio) General Measurement Device and Calibration Topics 3
P Surface scratch measurement General Measurement Device and Calibration Topics 1
D Calibration of Digital thermometer with surface probe General Measurement Device and Calibration Topics 1
J Gear Surface Finish - Print with the word "calibrated" Manufacturing and Related Processes 2
R Design and Manufacture Guidelines for Surface Mount Technology Misc. Quality Assurance and Business Systems Related Topics 9
8 Surface Finish - Callout as 8 - 16 Rq Manufacturing and Related Processes 1
M Active Surface Disinfectant Claims - FDA vs EPA and Hands vs Objects Other Medical Device and Orthopedic Related Topics 0
GoKats78 Callout on Surface Finish General Measurement Device and Calibration Topics 11
P Gas Nitriding Surface Hardening of Stainless Steel 304 ISO 13485:2016 - Medical Device Quality Management Systems 4
S Difference between Surface Finish (Ra) and Flatness (GD&T) Inspection, Prints (Drawings), Testing, Sampling and Related Topics 6
N Creepage - Does a surface mount isolator body negate a PCB slot? IEC 60601 - Medical Electrical Equipment Safety Standards Series 6
CCaantley Where to get a good test indicator stand for a granite surface plate General Measurement Device and Calibration Topics 8
M Interesting Discussion Surface Cleanliness Real Time Test Tools General Measurement Device and Calibration Topics 2
P Romer Arm - Profile of a Surface Changing General Measurement Device and Calibration Topics 4
R Reporting Profile of a surface with U modifier Inspection, Prints (Drawings), Testing, Sampling and Related Topics 4
S Response Surface Method to create design matrix in Minitab Using Minitab Software 5
Proud Liberal Measuring axial and radial surface finish (16 Rz) on a broached internal radius Inspection, Prints (Drawings), Testing, Sampling and Related Topics 1
B Profile of a Surface Callout on this Drawing General Measurement Device and Calibration Topics 4
O Can a Profile of a Surface have a Diameter Symbol? Inspection, Prints (Drawings), Testing, Sampling and Related Topics 3
S ARP 1820 Surface Contamination Testing Various Other Specifications, Standards, and related Requirements 1
N Projection welding of nuts on zinc coated surface Manufacturing and Related Processes 3
K Can a Surface of a profile be applied to a feature of size? GD&T questions Inspection, Prints (Drawings), Testing, Sampling and Related Topics 1
alonFAI Component Failure (Relay) during ICT Testing after Surface Mount Assembly Manufacturing and Related Processes 5
H Stainless Steel Surface Quality for Ophthalmic Surgical Device Other Medical Device Related Standards 11
J Profile of Surface with Basics and Angle Inspection, Prints (Drawings), Testing, Sampling and Related Topics 10
E Help me with Surface Plate Calibration General Measurement Device and Calibration Topics 10
