Surface scratch measurement
I am looking for a tool/software that would measure the size and depth of surface scratches on paper stock and that would also maybe calculate surface area of a specified area with % covered by those scratches.
optomist1
A Sea of Statistics
PwayneZ, I would start with manufacturers/providers of AOI (Automated Optical Inspection) systems & software....
Hope this helps...
Optomist1
B Painted surface of a protective Class I equipment. CE Marking (Conformité Européene) / CB Scheme 1
Sam.F Question about granite surface plates out of spec AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 9
H Regarding external surface temperature limit requirement for lab incubators. CE Marking (Conformité Européene) / CB Scheme 2
DuncanGibbons Typical Surface Roughness Requirements for Aviation AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 2
I Good Surface Plate Suppliers? General Measurement Device and Calibration Topics 1
T Capability calculation of surface profile Capability, Accuracy and Stability - Processes, Machines, etc. 20
S Alcohol based cleaner for Food Contact Surface? Food Safety - ISO 22000, HACCP (21 CFR 120) 0
V EN ISO 10993-1, Category of surface device by nature of body contact Other Medical Device Related Standards 2
W Surface Profile All-Around AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 1
T Is there a direct relation between surface roughness and gloss? Inspection, Prints (Drawings), Testing, Sampling and Related Topics 7
D CED Coating in Cast iron surface Reliability Analysis - Predictions, Testing and Standards 0
S Surface roughness Rz Manufacturing and Related Processes 1
L GD&T Position for surface Inspection, Prints (Drawings), Testing, Sampling and Related Topics 9
K Surface finish (Evaluation Length) Inspection, Prints (Drawings), Testing, Sampling and Related Topics 3
Ron Rompen Surface Finish Correlation between Ra, Rz and Tp (bearing surface ratio) General Measurement Device and Calibration Topics 3
D Surface Roughness understanding Inspection, Prints (Drawings), Testing, Sampling and Related Topics 1
D Calibration of Digital thermometer with surface probe General Measurement Device and Calibration Topics 1
J Gear Surface Finish - Print with the word "calibrated" Manufacturing and Related Processes 2
R Design and Manufacture Guidelines for Surface Mount Technology Misc. Quality Assurance and Business Systems Related Topics 9
8 Surface Finish - Callout as 8 - 16 Rq Manufacturing and Related Processes 1
M Active Surface Disinfectant Claims - FDA vs EPA and Hands vs Objects Other Medical Device and Orthopedic Related Topics 0
GoKats78 Callout on Surface Finish General Measurement Device and Calibration Topics 12
P Gas Nitriding Surface Hardening of Stainless Steel 304 ISO 13485:2016 - Medical Device Quality Management Systems 4
S Difference between Surface Finish (Ra) and Flatness (GD&T) Inspection, Prints (Drawings), Testing, Sampling and Related Topics 6
N Creepage - Does a surface mount isolator body negate a PCB slot? IEC 60601 - Medical Electrical Equipment Safety Standards Series 6
CCaantley Where to get a good test indicator stand for a granite surface plate General Measurement Device and Calibration Topics 8
M Interesting Discussion Surface Cleanliness Real Time Test Tools General Measurement Device and Calibration Topics 2
P Romer Arm - Profile of a Surface Changing General Measurement Device and Calibration Topics 4
R Reporting Profile of a surface with U modifier Inspection, Prints (Drawings), Testing, Sampling and Related Topics 4
S Response Surface Method to create design matrix in Minitab Using Minitab Software 5
Proud Liberal Surface finish measurement (roughness) - Rz under the ISO standard vs ANSI standard Inspection, Prints (Drawings), Testing, Sampling and Related Topics 0
Proud Liberal Measuring axial and radial surface finish (16 Rz) on a broached internal radius Inspection, Prints (Drawings), Testing, Sampling and Related Topics 1
B Profile of a Surface Callout on this Drawing General Measurement Device and Calibration Topics 4
O Can a Profile of a Surface have a Diameter Symbol? Inspection, Prints (Drawings), Testing, Sampling and Related Topics 3
Q Surface Roughness - Conversion of RS on a Print to RZ General Measurement Device and Calibration Topics 3
S ARP 1820 Surface Contamination Testing Various Other Specifications, Standards, and related Requirements 1
N Projection welding of nuts on zinc coated surface Manufacturing and Related Processes 3
K Can a Surface of a profile be applied to a feature of size? GD&T questions Inspection, Prints (Drawings), Testing, Sampling and Related Topics 1
alonFAI Component Failure (Relay) during ICT Testing after Surface Mount Assembly Manufacturing and Related Processes 5
W Profilometer Surface Roughness Tester Issue - Ball Bearings ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 7
H Stainless Steel Surface Quality for Ophthalmic Surgical Device Other Medical Device Related Standards 11
J Profile of Surface with Basics and Angle Inspection, Prints (Drawings), Testing, Sampling and Related Topics 10
E Help me with Surface Plate Calibration General Measurement Device and Calibration Topics 10
G Generally accepted Tolerance for Surface Reflectance Various Other Specifications, Standards, and related Requirements 3
M Please help to analyze Response Surface Methodology by using Minitab 16 Using Minitab Software 6
T Variation in values of the levels in Factorial/Response surface design Using Minitab Software 1
B Surface Finish Equipment MSA (Measurement System Analysis) Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 5
R When a Part Print specifies 10 Rmax on a Surface - Rmax Settings & Standards? General Measurement Device and Calibration Topics 2
kedarg6500 Surface Finish Measurement Methods Inspection, Prints (Drawings), Testing, Sampling and Related Topics 13
C Mitutoyo SJ210 Settings - Is there an Industry Standard Surface Measurement Setting? General Measurement Device and Calibration Topics 4
