Survey about Attribute Gage and Sight Checking R&R
N
Nixverstehikus83
Hi :bigwave:,
I?m interested in making a suvery about your results for making MSA for attribute gauging and sight checking.
I think that when you introduce these MSA to your company it costs a lot of money. And if something costs a lot of money it must have a benefit.
So I?m interested in the experiences you have done in the companies.
My opinion is that a lot of people do this but at least there ist no change. For example I?ve done some R&R for sight checking. The results were like almost always the inspectors identified about 70-90% of the bad parts. But if it is the only way you can check this part (because there is no other way or because the other method is to expensive) it does not change anything.
Maybe it is possible to give a percentage number for bad attribute gauging R&R and bad sight checking MSA. And some word what does the bad results change.
Thanks... I think this survey will be interessting for other forum members too.
hmmm. I do use categorical MSAs a considerable amount of time and have realized substantial benefits. It's important to remeber that no assessment tool fixes anything. it can only quantify current state and reveal some clues about how to improve. people must do the hard work of improving systems that do not meet performance.
So you did an MSA that shows your visual inspectors only detect bad product 80-90% of the time. What actions did you take to improve their ability? That is the critical element to a successful MSA program.
N
Nixverstehikus83
That?s the point. I have seen some examples were they do a lot of things to improve the sight checking.
The result of the check is depending on perception and concentration of the worker. Just look on the google results for optical illusion. A human is not able to make sight checking with a zero error rate.
I don?t want to say that a human is not able to do the sight checking, in some cases there isn?t other possability. What I wan?t to say is that you might improve your sight checking up to a quote of 95%. But this ist only a snapshot. You can make 10 MSA with a very satisfaction results. One morning, the inspector comes, after an argument with his wife, to woork. And you only have bad results in your exam. Because he will not be able to concentrate. It's only human.
P
Piotr Stoklosa
That's true that attribute GRR can be beneficial. Some examples:
1) If you see that all operators have low kappa it can be a sign that your acceptance criteria are not precise.
2) If you see that operators have different kappas (for example A*B > 0.90 and B*C<0.50 and A*C<0.50) you can conlude that you have "calibration" problem with C operator.
3) If the operators have high Miss Rate your system tends to pass defective parts.
4) If the operators have high False Alarm Rate your system tends to reject good parts.
5) If you define Ref Value using expert decision then you can use the same sample set to verify training effectiveness of your new operators.
That's also true that sight control systems are very sensitive to human factor. From practice I can recomend one "soft" solution. You can allow your controlers to have a few "bad days" a year. If they have a somatic or mental problem they can report it to supervisor with no consequence: "Boss, I fill bad today. Give me less responsible work." The cost of shifting this worker to other job will be lower than the costs of wrong sight inspeciton.
I
iamtroll
I think that the point of any MSA is improvement and discovering best practices. No measuring system is perfect, look at how the MSA is designed, it is not about getting a perfect score but understanding where your weaknesses are then trying to correct them and plan for them. Even with measuring tools there is error allowed. If your visual inspector can have a bad day, so can your tool and gage inspector. The best that you can hope for is that you identify best practices and how to spread them to all of you workers while mitigating your own systems deficiencies. The knowledge that your system is not perfect should be a driving force for improvement not an excuse for failure.
The fact that no measurement system is perfect is also why it is the second thing we check for an out-of-control event.
Gages get dropped, inspectors drift and shift, temp & humidity alters gages, maintenance and calibration change instrument set points...etc.
P ISO 13485:2016 MDSAP Certification Fee Survey ISO 13485:2016 - Medical Device Quality Management Systems 6
S Need help with analysing a survey on minitab Using Minitab Software 1
M Informational From RAPS – 27% Will be Compliant? Survey Highlights Lack of Readiness for EU MDR Medical Device and FDA Regulations and Standards News 0
M Informational Team-NB published a press release regarding the survey run among its members to analyse the certificates being issued Medical Device and FDA Regulations and Standards News 0
optomist1 Survey of Tier 1 & Tier 2 suppliers APQP and PPAP 6
B [Help] Customer Engagement Survey for MBA Project - due Apr19 Manufacturing and Related Processes 0
B Help with Customer Engagement Survey for MBA Project - due Apr19 General Measurement Device and Calibration Topics 0
T Likert Analysis of Data from a Survey Statistical Analysis Tools, Techniques and SPC 6
A Efficacy of ISO 9001:2015 - Survey ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 10
T Assessment / Audit / Survey for Indirect Suppliers or Material ISO 13485:2016 - Medical Device Quality Management Systems 3
N Customer Survey Question Has Me Stumped - Compliance with Laws and Regulations Customer and Company Specific Requirements 4
K Temperature Uniformity Survey (TUS) - Vacuum Furnace General Measurement Device and Calibration Topics 1
D Alternatives to Customer Feedback Survey in ISO 9001 Quality Manager and Management Related Issues 4
N Interesting Discussion How to Deal with Suppliers Who Refuse to Complete our ISO Survey? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 51
N Survey to Customers Regarding Our Complaint Response Time Customer Complaints 7
L 5 minutes only for this Survey on the Value of PDCA and Your EMS Miscellaneous Environmental Standards and EMS Related Discussions 1
S Conduct Customer Satisfaction Survey for every submitted Bid? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 3
N Load Thermocouple requirement for TUS (Temperature Uniformity Survey) AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 8
J Looking for a Customer Satisfaction Survey Form Other Medical Device Related Standards 2
Sean Kelley How to upload GM's MMOG survey version 4 to GM Powersupply Customer and Company Specific Requirements 3
C Vendor Self-Survey to Qualify Vendors/Suppliers - AVL Question ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 2
Richard Regalado 2014 Information Security Breaches Survey by PWC IEC 27001 - Information Security Management Systems (ISMS) 1
Richard Regalado Weathering the storm - The 2013 Business Continuity Management Survey Business Continuity & Resiliency Planning (BCRP) 2
R Female auditors earn 18% less than male auditors - IRCA Salary Survey 2014 Career and Occupation Discussions 0
S What is the minimum samples required for Customer Survey? Quality Manager and Management Related Issues 3
John Broomfield Survey on Management Quality Manager and Management Related Issues 8
Z Customer Satisfaction Survey Analysis Quality Tools, Improvement and Analysis 2
M Temperature Uniformity Survey Sensors AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 7
C Customer Survey Assessment Feedback Customer Complaints 11
M Customer Satisfaction Survey - Poor Response ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 11
S Need to prepare Internal Customer Satisfaction Survey form for QA department Misc. Quality Assurance and Business Systems Related Topics 5
T A survey on problems during ISMS implementation - need help IEC 27001 - Information Security Management Systems (ISMS) 2
P Should I send survey questionnaire prior to Supplier EMS Audit? Miscellaneous Environmental Standards and EMS Related Discussions 14
D U.S. Department of Commerce, Bureau of Industry and Security survey Various Other Specifications, Standards, and related Requirements 1
W IR Camera - Heat Survey of parts during dynamic testing General Measurement Device and Calibration Topics 5
S Airborne Survey Legal Compliance - OHSAS 18001 Occupational Health & Safety Management Standards 2
N What Questions Are On Your Customer Survey? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 2
B What Customers Return Survey Results? Customer Complaints 1
B What is the Appropriate Sample Size for a Customer Survey? Customer Complaints 5
B Your thoughts on Communicating to Customers the Actions on Customer Survey Customer Complaints 4
T Brief Survey for OEM's about Outsourcing Supplier Quality Assurance and other Supplier Issues 5
R Supplier Satisfaction Survey about Working with us as a Customer Supplier Quality Assurance and other Supplier Issues 7
I Request to participate in ISO 14001 survey for Masters Thesis ISO 14001:2015 Specific Discussions 3
B Writing a Customer Survey......Any tips? Customer Complaints 13
T A little survey on ISMS Implementation - Need help IEC 27001 - Information Security Management Systems (ISMS) 12
I Survey - The impact of ISO 9001 Certification on Organisational Peformance ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 4
K Survey Meter Calibration - Accredited Laboratory required? General Measurement Device and Calibration Topics 5
Richard Regalado Symantec 2011 SMB Disaster Preparedness Survey Business Continuity & Resiliency Planning (BCRP) 6
T RoHS Supplier Survey Needed Supplier Quality Assurance and other Supplier Issues 5
M Airworthiness Review - Aircraft Physical Survey EASA and JAA Aviation Standards and Requirements 1
