Survey of Tier 1 & Tier 2 suppliers
optomist1
A Sea of Statistics
To All Coveers, a kind of naive survey question, do the Tier 1 & Tier 2 auto/aero suppliers routinely structure their various quality gates in conformance with AIAG APQP, do you conduct your own internal DV/PV Testing prior to conducting a Run At Rate or Production Demonstration Run...and in turn forward/submit parts from this event to PPAP Lab (DVP&R) and PPAP Dimensional....ultimately a PSW
I realize the question is a bit short on details, many many intemediate steps not addressed here....in addition the above internal quality gates may or will certainly vary depending on part pedigree; is it a customer designed part, an in-house design or merely a variation on a previously qualified part
Ninja
Looking for Reality
Howdy,
I've been Tier 2 for quite a number of products, for three companies. In all cases, it was for highly specialized products with little chance of second suppliers being validated due to cost.
In this scenario, the two companies for which I was in a decision making capacity...we followed pretty much none of the gates, Tier 1 design team kept tweaking things until literally the last minute and the PPAP was a perfunctory paperwork exercise after start of production...in all cases on n=1.
We wanted to approach it more responsibly, with some of the key parts of PPAP such as [email protected] and 5lot full build validation...but we were never allowed to do so. We insisted that all PO's stated APQP not required.
The third company did a TON more paperwork, and far more PV and DV internally...but the Tier 1 threw them all out and launched into production without PPAP. The PSW was signed when we refused to ship the next lot...and we completed the [email protected] a few months later...
So...I certainly hope that my experience is a very rare and specialized case...I'll be interested to see the experiences of others...
N
ncwalker
Tier 1 in automotive here.
Yes. We follow the AIAG APQP process. What is different is the number of gates and the terms, this is based on our OEM customer. If we are supply GM, we use the GM gates and lingo, etc. From my experience, all the OEMs follow the process too, the major reporting gates are the same. Everyone has a project start, off tool samples, PPAP run, DV testing, PV testing and Run at Rate. (Called different things). Then some OEMs add in a few more gates they like.
My Tier 1s (Tier 2 to the OEM) the experience I have is it is a mixed bag. Some Tier 2 companies are HUGE - for example a bearing supplier. They are typically well versed in AIAG and follow the process as well. Though we let them use the AIAG lingo. Because we know how confusing it is to use different words for the same things all the time. Most of them use the AIAG lingo. Some of them use thing lingo of their biggest customer, regardless. And some adjust the lingo based on customer like we do. (This usually happens if they tier 1 to the OEMs as well as be tier 2).
But the smaller shops - the single site, single owner specialty shops - that don't typically have a lot of overhead.... You have to ride them like a rented mule sometimes to follow the APQP process. They'll sort of do it in a loosey goosey way if left to their own. But if you need formal reporting, you have to keep after them. (If they're supplying a component on the critical path or with lots of KPCs, we ride them pretty hard. If it's a common part, we usually don't care too much, we have limited resources as well.)
optomist1
A Sea of Statistics
So for a typical OEM, your gates would closely mirror those of the OEM, re: PDR or run at rate a rough % of parts you would submit to a PPAP Lab and PPAP DIM? Many many times schedules become compressed, and a production itent PDR may be behind schedule, some new equipment added to the production line
Howdy,
Thanks Ninja...given the diverse terminology in the APQP arena, this may sound a bit redundant....so in the last scenario.."The third company..", prior to conducting a DVP&R, did your firm conduct full DV/PV testing before performing [email protected], and PPAP? Sometimes the terminolgy and requirments get blurred. Cheers - optomist1
Ninja
Looking for Reality
DV/PV was something that we (Tier2) wanted done to protect ourselves from what we considered the irresponsible approach of the Tier1...it was not a part of the PPAP process, more of an attempt at CYA. [email protected] was a single day of "how fast can we run?" and a bunch of XL work so the SQE could check the box on the form...all after launch. We insisted on the "APQP not required" note on PO's since we were prohibited from following it by the actions (or inactions) of the Tier1.
All three were very disappointing exercises from my side, and has helped to form many of my opinions about value of published standards that you can see elsewhere on the forum. I value QMS very much, but I've seen too much like the above to put weight on a cert.
There are car brands that I will not buy as a result of seeing this...just like there are restaurants I will not eat in after I saw their kitchens...
optomist1
A Sea of Statistics
Thanks Ninja...great input...so if I might address the ideal condition @Tier 1 or 2....what many term as DV/PV testing is performed internally (likely one of the Quality Gates), then if all good, on to a customer witnessed (usually) [email protected], then parts to formal PPAP Lab and Dim and ultimately clean launch and on-time....of course I have left out many other intermediate steps....
Along with your input re: customers selectively ignoring some steps....have you expereinced situations where the APQP/PPAP process is actually crusing along, very few issues until shortly after successful [email protected] the customer, usually the OEM, drops a last minute change and still expects Tier 1 parts to manufacturing location on or about what we called PS or Pre-series, the step just prior to Job 1? The sobering part of this scenario is that PS vehicles are actually saleable vehicles, so even more urgency to get it right for launch.
Ninja
Looking for Reality
Howdy,
I think I understand your question better now...and I don't think I can comment...
I haven't seen that part...and everything else is dependent on that...so I cannot comment on anything downstream...
Sidney Vianna ISO 14001 News ISO 14001 Continual Improvement Survey ISO 14001:2015 Specific Discussions 0
briteme4 ASL - AS9100 / Supplier Survey Supplier Quality Assurance and other Supplier Issues 3
C Supplier survey - 200 to 250 duppliers Supplier Quality Assurance and other Supplier Issues 3
P ISO 13485:2016 MDSAP Certification Fee Survey ISO 13485:2016 - Medical Device Quality Management Systems 6
S Need help with analysing a survey on minitab Using Minitab Software 1
M Informational From RAPS – 27% Will be Compliant? Survey Highlights Lack of Readiness for EU MDR Medical Device and FDA Regulations and Standards News 0
M Informational Team-NB published a press release regarding the survey run among its members to analyse the certificates being issued Medical Device and FDA Regulations and Standards News 0
B [Help] Customer Engagement Survey for MBA Project - due Apr19 Manufacturing and Related Processes 0
B Help with Customer Engagement Survey for MBA Project - due Apr19 General Measurement Device and Calibration Topics 0
T Likert Analysis of Data from a Survey Statistical Analysis Tools, Techniques and SPC 6
A Efficacy of ISO 9001:2015 - Survey ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 10
T Assessment / Audit / Survey for Indirect Suppliers or Material ISO 13485:2016 - Medical Device Quality Management Systems 3
N Customer Survey Question Has Me Stumped - Compliance with Laws and Regulations Customer and Company Specific Requirements 4
K Temperature Uniformity Survey (TUS) - Vacuum Furnace General Measurement Device and Calibration Topics 1
D Alternatives to Customer Feedback Survey in ISO 9001 Quality Manager and Management Related Issues 4
N Interesting Discussion How to Deal with Suppliers Who Refuse to Complete our ISO Survey? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 51
N Survey to Customers Regarding Our Complaint Response Time Customer Complaints 7
L 5 minutes only for this Survey on the Value of PDCA and Your EMS Miscellaneous Environmental Standards and EMS Related Discussions 1
S Conduct Customer Satisfaction Survey for every submitted Bid? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 3
N Load Thermocouple requirement for TUS (Temperature Uniformity Survey) AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 8
J Looking for a Customer Satisfaction Survey Form Other Medical Device Related Standards 2
S How to upload GM's MMOG survey version 4 to GM Powersupply Customer and Company Specific Requirements 3
C Vendor Self-Survey to Qualify Vendors/Suppliers - AVL Question ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 2
Richard Regalado 2014 Information Security Breaches Survey by PWC IEC 27001 - Information Security Management Systems (ISMS) 1
Richard Regalado Weathering the storm - The 2013 Business Continuity Management Survey Business Continuity & Resiliency Planning (BCRP) 2
R Female auditors earn 18% less than male auditors - IRCA Salary Survey 2014 Career and Occupation Discussions 0
S What is the minimum samples required for Customer Survey? Quality Manager and Management Related Issues 3
John Broomfield Survey on Management Quality Manager and Management Related Issues 8
Z Customer Satisfaction Survey Analysis Quality Tools, Improvement and Analysis 2
M Temperature Uniformity Survey Sensors AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 7
C Customer Survey Assessment Feedback Customer Complaints 11
M Customer Satisfaction Survey - Poor Response ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 11
N Survey about Attribute Gage and Sight Checking R&R Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 5
S Need to prepare Internal Customer Satisfaction Survey form for QA department Misc. Quality Assurance and Business Systems Related Topics 5
T A survey on problems during ISMS implementation - need help IEC 27001 - Information Security Management Systems (ISMS) 2
P Should I send survey questionnaire prior to Supplier EMS Audit? Miscellaneous Environmental Standards and EMS Related Discussions 14
D U.S. Department of Commerce, Bureau of Industry and Security survey Various Other Specifications, Standards, and related Requirements 1
W IR Camera - Heat Survey of parts during dynamic testing General Measurement Device and Calibration Topics 5
S Airborne Survey Legal Compliance - OHSAS 18001 Occupational Health & Safety Management Standards 2
N What Questions Are On Your Customer Survey? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 2
B What Customers Return Survey Results? Customer Complaints 1
B What is the Appropriate Sample Size for a Customer Survey? Customer Complaints 5
B Your thoughts on Communicating to Customers the Actions on Customer Survey Customer Complaints 4
T Brief Survey for OEM's about Outsourcing Supplier Quality Assurance and other Supplier Issues 5
R Supplier Satisfaction Survey about Working with us as a Customer Supplier Quality Assurance and other Supplier Issues 7
I Request to participate in ISO 14001 survey for Masters Thesis ISO 14001:2015 Specific Discussions 3
B Writing a Customer Survey......Any tips? Customer Complaints 13
T A little survey on ISMS Implementation - Need help IEC 27001 - Information Security Management Systems (ISMS) 12
I Survey - The impact of ISO 9001 Certification on Organisational Peformance ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 4
K Survey Meter Calibration - Accredited Laboratory required? General Measurement Device and Calibration Topics 5
