If there is a limit to the amount of Value contained in a system, it might be reasonable to consider that each component would experience varying levels of value in relationship to the amount of value consumed by another component.
Okay I see where you're going with this and I agree with your observation.
I reviewed some of my old books last night and found this on Shannon entropy and information.
H(P)=sum P(s).log P(s) {P(s) = probability distribution that the system would be in state s}
"H" reaches its maximum value if all states are equiprobable, that is, if we have no indication whatsoever to assume that one state is more probable than another state. Thus it is natural that in this case entropy H reduces to variety V. Like variety, H expresses our uncertainty or ignorance about the syste's state. It is clear tha H =0 if and only if the probability of a certain state is 1 (and of all other states 0). In that case we have maximal certainty or complete information about what state the system is in.
A little confusing but after I read it a few time it started making a little sense. Anyway, when I couldn't see the relationship at first I thought you were referring to the Shannon model.
Now going along with what you have suggested Kevin:
If we say that Customer defined value = 1 then the sum of all our processes needs to add up to 1. Differing values would cause one step to add and one to subtract from the whole. I agree with this. And as S_T & NYH have brought up we need to evaluate the system and eliminate as much of the negatives as possible.
I have another example for you. I just went through some painting on the place and here is what I saw.
The value that the customer (me) is interested in is paint on the walls. So the only part of the painters operation that adds "customer" value is the paint brush on the wall - all else in non-customer value added. But all the support processes - taping, tarps, mixing, ladders, brush/roller cleaning - are absolutely necessary (to one extent or another) in order to satisfy the customer.
With what Kevin was saying: There is only so much I can do with spreading a tarp, taping off, etc. before it is a waste of time, costs to much, etc. and system collaspes.
What you are doing with a VSM then balancing time and cost so as to not disturb the "customer defined value".
