Taguchi method using Minitab - DOE (Design of Experiments) Help
P
Prototype
Hi
Please see the attachment foe the DOE problem. I've used Taguchi method using Minitab to analyze the matrix. Can someone tell me what the results mean? I've posted the question in the attachment.
Thanks a lot.
No. You are analyzing count data that cannot be less than zero. Minitab does not know this. It assumes the data is continuous with no lower boundary.
If I were analyzing this data, I would use the Freeman-Tukey transform for count data then analyze using classical techniques. The S/N approach complicates and muddies the analysis.
P
Prototype
I'm not aware of the Freeman-Tukey method. If I'm understanding you correctly, because counting the number of defects is an attribute and minitab doesn't know this you cannot predict the number of defectives at the optimum setting using Taguchi method. Am I right?
Thanks for the reply though
L
Lemor - 2011
minitab interpreted optimim setting as higher is better. your condition is smaller is better
Mustafainisb
Dear Moderator,
pl tell me how to raise my problem in this forum.
Dear listners,
I have four factors and three levels (L9) with three times repeat laser cutting process on the same input setting and measure kerf width(smaller the better) . One of the input data set produce unsuccessful cutting of sheet by laser. So if i take zero than signal to noise ratio is infinite. What is the practice of analyst to represent uncut value?
Best Regards
Mustafa Zaidi
I am not a proponent of S/N ratio. I prefer to analyze the mean and StDev separately using classical methods.
In your case, you have missing data, or what is sometimes called botched runs. Your best bet is to try to analyze the data that you do have using GLM or Regression analysis.
You could also try an RSM approach using a Face centered or Box-Benken design or even an Optimal design to avoid the setting that are not feasible.
Mustafainisb
Dear ,
Thanks for reply, the problem is write know that i have full factorial design data so it is difficult to perform it again free from Malaysia. So what i can do if i want to do analysis. i am thinking that these values of uncut should be deleted but the observation table will be unbalanced. So how i can handle it. for calculating interactions.
V Using Taguchi method in Minitab for Coil Winding Application Using Minitab Software 11
E ANOVA for Taguchi method - Four factors and three levels and nine runs (Minitab) Using Minitab Software 6
Y Experiential Design with Taguchi Method Using Minitab Software 2
M Apply Taguchi method for Web-based application development Quality Tools, Improvement and Analysis 4
B WEDM Taguchi and Anova Analysis - L16 array with 5 parameters at 4 levels Manufacturing and Related Processes 5
H Taguchi mixed model DoE [L16 (4^3 2^6): factors interaction and ANOVA calculation Using Minitab Software 3
A Taguchi Minitab - Continuous Data - What should I choose as response variable? Using Minitab Software 3
K Taguchi Experiments for Factorial Design Analysis - Reliability of Minitab Results Using Minitab Software 1
S Taguchi Design with ANOVA - 3 factors each with 3 levels Quality Assurance and Compliance Software Tools and Solutions 13
M Taguchi Loss Function Problem Misc. Quality Assurance and Business Systems Related Topics 2
M Taguchi Signal to Noise Ratios Misc. Quality Assurance and Business Systems Related Topics 3
J F and P-value in L9 Taguchi Design Using Minitab Software 22
M Taguchi Analysis of Discrete Factor Using Minitab Software 10
Y Taguchi Design with 6 levels and 3 factors in Minitab Using Minitab Software 11
P Taguchi Logit Transformation in Minitab Using Minitab Software 7
K Taguchi School Assignment using an L8 Orthogonal spreadsheet tool Statistical Analysis Tools, Techniques and SPC 1
P Taguchi Anova Error with Minitab Using Minitab Software 9
R Taguchi design for 3 level 4 factors Using Minitab Software 12
M Taguchi L4 Orthogonal Array Design of Experiments (DOE) in an Excel spreadsheet Excel .xls Spreadsheet Templates and Tools 3
M Taguchi versus fractional factorial: Can somebody check the results? Quality Tools, Improvement and Analysis 3
AnaMariaVR2 How to Make Things Well: Genichi Taguchi, 1924-2012 Philosophy, Gurus, Innovation and Evolution 1
J Taguchi Analysis using MiniTAB Using Minitab Software 1
B Taguchi DOE (Design of Experiments) example using Minitab Using Minitab Software 3
A Quality Giant Dies: Dr. Genichi Taguchi: RIP - June 2nd 2012 Philosophy, Gurus, Innovation and Evolution 0
T DOE Multi level Taguchi - I am doing a Capstone Project Using Minitab Software 10
T Taguchi DOE Analysis - What S/N ratio (Nominal is best or smaller is better) to use? Quality Tools, Improvement and Analysis 5
S Taguchi's "Robust Design" for Services Sector - Experience or Papers to Share? Six Sigma 3
A Taguchi Inner and Outer Array Design for Medical Device Testing Quality Tools, Improvement and Analysis 1
D Mathematical Model of Taguchi L18 Using Minitab Software 7
R Analysis of Welding Parameters - Can Taguchi methods provide equation? Using Minitab Software 11
R Define Data from Taguchi to Response Surface Methodology in Minitab Using Minitab Software 2
R Taguchi Design - Degree of freedom for l27 in 4 factors 3 level (Minitab) Using Minitab Software 15
P Taguchi's Analysis using Minitab 16 Using Minitab Software 25
Marc Taguchi Loss Function example Misc. Quality Assurance and Business Systems Related Topics 4
C Difference between softwares in choosing correct Taguchi designs Using Minitab Software 16
C DoE and ANOVA - 4 factor and 3 levels Taguchi design with 2 replicates Using Minitab Software 14
G Implementing Taguchi Loss Function in COQ - A Curious Case Misc. Quality Assurance and Business Systems Related Topics 1
V Quality Gurus Comparison - Deming, Juran, Crosby, Ishikawa and Taguchi Philosophy, Gurus, Innovation and Evolution 1
T Optimizing Multiple Response Variables Using Taguchi Signal-to-Noise ratios Statistical Analysis Tools, Techniques and SPC 3
C Is Cpm (Taguchi's Index) Superior to Cpk and Ppk? Capability, Accuracy and Stability - Processes, Machines, etc. 1
D Questions about Taguchi style Designed Experiments (DOE) Quality Tools, Improvement and Analysis 6
S Looking for a good Taguchi book-any suggestions? Book, Video, Blog and Web Site Reviews and Recommendations 3
A Shainin vs. Fisher vs. Taguchi DOE (Design of Experiments) Statistical Analysis Quality Tools, Improvement and Analysis 10
L DOE Integrated Methodology - Traditional DOE vs. Taguchi Methods vs. Shainin Techniqu Quality Tools, Improvement and Analysis 7
Geoff Cotton Taguchi quality loss function - How do I establish the 'Consumer Loss' element? Quality Tools, Improvement and Analysis 6
S Desensitizing to reduce variation - A Taguchi technique? Quality Tools, Improvement and Analysis 3
S How does one calculate Cpm (Taguchi process capability) Statistical Analysis Tools, Techniques and SPC 16
Marc Zero Defects & Taguchi Loss Function - ISO 9000 and the Zero Defects Philosophy Quality Tools, Improvement and Analysis 32
Q Process map Evaluation and Analysis Method Process Maps, Process Mapping and Turtle Diagrams 3
