Takt Time vs. Cycle Time vs. Total Cycle Time
V
VT-IE
#11
If ylou are looking at an ongoing process, the length of time a unit spends in processing is usually not an issue. Think of an automotive assembly line. Each vehicle may spend several hours moving down the line, but the line's "cycle time" is usually thought of as how frequently a finished vehicle comes off the end of the line. On the other hand, if one is considering a 6 position rotary table machining center, and you only run 6 pieces, the cycle time would include the time from when you loaded the first piece on, until the time you unloaded the sixth piece, which would be significantly different.
Geoff Withnell
What if you were investigating your lead time and you were examining the "time in system"? Correct me if I'm wrong, but when doing a value stream map you use the sum of the cycle time in each process to calculate a total cycle time, then later use that number to determine lead time(add total cycle time to time the WIP spends in the system between processes). It could have an impact there, but its probably not significant. Can you see my confusion?
Thanks,
Andy
G
Geoff Withnell
#12
Thanks,
Andy
Sure, cycle time and lead time are different requirements. Lead time = time to first piece (equal to time wip spends in system) + (n-1) x cycle time. Think of a line that takes 2 hours ofor a piece to traverse (wip time in process) with a cycle time of 1 minute, as I defined above. Then the lead time for 100 pieces would be 120 minutes (to get the first piece) + 99 minutes (to get the rest of the lot) or 3 hours 39 minutes.
Geoff Withnell
U
Umang Vidyarthi
#13
Geoff Withnell
The main point raised here is, whether the definition of cycle time given- "The time interval between start and finish of an operation"- is correct or not.
2.Time consumed on the assembly line is covered in 'Total cycle time'.
3.For making 6 pcs only, I will not prefer to load it on a 6 position rotary table machining center.
Umang,
Takt time is solely the rate of production required to meet customer demand. While your equation is technically correct, your definition of it, "minutes of work per unit produced" is incomplete. The ideal scenario would be for takt and cycle time to be equal, but this rarely the case. Cycle time is often slower or faster so adjustments would need to be made. A better definitition would perhaps be "target rate of production". Your definition as stated would basically be the same as that for cycle time.
I would also clarify the equation to support takt to be customer demand and not "total demand". If my customer only wants 100 pieces/day, but I choose to make 150, then theoretically my takt is based on 100/day. From a capacity and/or planning standpoint, I may be looking at increased demand in the near future and wish to employ some other method such as level loading in order to alleviate the need for overtime. But that doesn't change the fact that takt is customer focused.
Please don't think I'm nitpicking, I'm just trying to present the perspective based on the "purist" approach since that is what most people will have been taught or read versus what one company may or may not do. What it really comes down to is what may work for one company doesn't necessarily guarantee success for another.
Wayne
IMHO "Rate of production" relates to 'Number of units produced per minute', which in turn relates to cycle time and not to Takt time as you have suggested. There is a popular mis-concept about the Takt time, which in fact is taken as "Minutes per Unit" and not as "Units per Minute.
2.The concept of 'customer demand' is absolutely correct while catering for a single customer. In case of multiple customers, one has to consider 'Total demand' (of course of the customers). This terminology also covers the after market demand. Obviously, in the days of 'Lean manufacturing' & 'Zero inventory' ideology, no one wishes to produce without a demand! IMO, 'Total demand' is the controlling word, since the customer is automatically behind the demand! Therefore Takt is focused on 'Demand' - created by customer(s) and/or market.
:topic:
'TAKT' is a German word for the 'Baton' used by orchestra conductors to make the musicians play in unison.
Umang :D
W
wmarhel
#14
Umang :D
I think you took the paragraph out of context regarding my statement about "rate of production". My comment about rate of production was directed at your equation and then description of takt for the variable "T". At some point though, once takt has been determined, then essentially this does become the desired "rate of production" off a line, workcell, etc. From this perspective:
Takt = rate of customer demand = rate of production to satisfy customer demand
It all starts to fuse together at some point and turns into an exercise of semantics. Whether or not the cycle time can meet takt is a different story altogether. In those instances it is time to look at alternative methods to align with takt.
Wayne
chan0192
#15
I've got a question about cycle time. When takt time is calculated out and also the cycle time for each process, to plot it up to identify the bottleneck, how should I capture the cycle time for that plot? Is it from the ideal machine running rate or from the real operation output rate?
In the case of real operation output rate, should I uses an output per day devided by the available time per day which is included in all the downtime or should I use only the uptime of each operation?
Thank you =)
W
wmarhel
#16
Thank you =)
Always use real times. You could put an additional line showing where the theoretical rate is supposed to be, but it is always better to focus on reality versus what was stated in the sales pitch.
The actual output should in the same unit as takt time. Takt time is typically expressed in seconds, and so the cycle time (c/t) should be as well. Example for a linear assembly line of three stations:
--------------Takt---c/t
Station 1----10------8
Station 2----10-----12
Station 3----10------9
The problem station is #2. You could try to take two seconds from station #2 and shift it to station #1, or move one second of work to both stations #1 and #3. The preferred option would be to reduce station #2 to eight or nine seconds for better flow, but still produce at the 10 second takt.
Wayne
chuachomvn
#17
To sum it up in short:
Takt time : minutes of work per unit produced = T
Available time : Actual available minutes per day/shift =Ta
Total demand : Units required to be produced per day/shift = Td
The Takt time T = Ta / Td
Cycle time : The time interval between start and finish of an operation
Total cycle time : Total time interval between start and finish of all operations.
Umang :D
I am really confusing about lead time and total cycle time
0. Total cycle time = sum of all cycle time from every station?
1. As you define the toal time interval between start and finish of all operations. Does it mean that it includes material waiting time between stations.
2. What is different between the total cycle time and Lead time?
3. In the Little law, what kind of time do you use? cycle time or lead time?
4. How do you think about below formula:
Cycle time = (Value Added time + Non Value Added time) at one station
Lead time = Cycle time + material waiting time
W
wmarhel
#18
Lead time would encompass the entire value stream: material lead times, total manufacturing time, transportation times, etc.
Total cycle time would be restricted to the sum of just those elements in manufacturing.
For a more concrete variations, I would reference the APICS' (Association of Operations Management) dictionary.
Wayne
chuachomvn
#19
Wayne
Thank Wayne
I am clear now
For lead time calculation. I assume a case as follows:
Station1 (2h) Station 2 (10h) Station 4 (2h)
Station 3 (2h)
Parts from station 1 will go to Station 2 and 3 for processing. Station 2 & 3 are parallel to each other. after Station 2 & 3 it all come to gether to assemble in station 4. station cycle time is assumed as in bracket
Total cycle time = 2+10+2+2 = 16 hr
Lead time = 2+ 10 + 2 = 12 hr (the longest path)
is my understanding correct? please advise
Thank you in advance:agree1::agree:
Chomvn
W
wmarhel
#20
Thank Wayne
I am clear now
Station 3 (2h)
Chomvn
Actually, if processes are in parallel, I would say the cycle time is 14 hours (the time it takes for a unit from start to finish). The TOTAL # of labor hours to produce a unit would be 16 hours, but you would still be getting a unit off the line every 14 hours.
Your lead time to the customer could be 14 hours, but that's making the assumption that no additional time is required for packing and transportation to the customer.
The interesting thing about all this is that there are lot of different ways to look at it, and nuances that can be introduced. What is especially important is that you are consistent, and that the methodology is understood internally and by the customers.
Wayne
qualprod Calculate number of people in processes, considering cycle time/takt time = quantity of people Lean in Manufacturing and Service Industries 9
J Line Balance Study and maybe Takt Time and Cycle Time Lean in Manufacturing and Service Industries 3
P Takt Time & Cycle Time Calculations Lean in Manufacturing and Service Industries 6
L Takt time and crew-to-takt concerns Lean in Manufacturing and Service Industries 3
O Takt Time Calculation for Long Runner Product Lean in Manufacturing and Service Industries 5
H Determining Takt Time in Metal Stamping Lean in Manufacturing and Service Industries 9
M The logic around Takt Time Lean in Manufacturing and Service Industries 7
V Visual Control - Takt based Production Scheduling Lean in Manufacturing and Service Industries 8
Q TAKT Time Calculation - ASQ CSSBB Question Six Sigma 2
C A TAKT time calculator The Reading Room 11
Q Use TAKT time to optimize output of line - TAKT Time .xls Lean in Manufacturing and Service Industries 4
K PDCA cycle and ISO processes alternative model Quality Management System (QMS) Manuals 14
E Any sample of a full software life cycle IEC 62304 report ( any class )? IEC 62304 - Medical Device Software Life Cycle Processes 1
M Lean: Conducting Capacity Study, calculating Cycle times on laser cutting machines Lean in Manufacturing and Service Industries 2
J Should Loading and Unloading be Included in Cycle Times? Lean in Manufacturing and Service Industries 14
J Scope of ISO 9001 clause 10.2 in the product life cycle ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 2
K Product (Device) Life cycle - Product Life AFTER the Post Market Phase Medical Device and FDA Regulations and Standards News 3
Y Commanded life cycle management tool IEC 62304 - Medical Device Software Life Cycle Processes 1
M Setting deadlines (ex. 45 days) for Document Registration & Review Cycle Document Control Systems, Procedures, Forms and Templates 3
M Informational Draft ANSM’S GUIDELINE Cybersecurity of medical devices integrating software during their life cycle Medical Device and FDA Regulations and Standards News 0
Q ISO 14001:2015 accredited but import most product - CB Raised minor NC on Life Cycle Perspective ISO 14001:2015 Specific Discussions 2
qualprod Cycle times, value stream mapping, inventory, average values? Lean in Manufacturing and Service Industries 1
qualprod Criteria for print shop - How do you consider the cycle time in a print shop? Lean in Manufacturing and Service Industries 21
M PDCA cycle - Process mapping - Environmental ISO 14001 ISO 14001:2015 Specific Discussions 1
R ISO 13485:2016 Registration - NC on full cycle of internal audits ISO 13485:2016 - Medical Device Quality Management Systems 7
J Manufacturing Cycle Time Apps General Information Resources 2
R ISO 14001:2015 Life Cycle Perspective ISO 14001:2015 Specific Discussions 11
R Product life cycle and compliance obligation ISO 14001:2015 Specific Discussions 6
R Life Cycle Assessment of a Product Misc. Quality Assurance and Business Systems Related Topics 6
Z Understanding Cycle Time - Why the time of the other activities are left out Lean in Manufacturing and Service Industries 11
P ISO 14001:2015 and Life Cycle Assessment ISO 14001:2015 Specific Discussions 18
O Is a full Internal Audit cycle every year required? AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 6
A Quality system vs SDLC (Software Development Life Cycle) (or ALM)? Other US Medical Device Regulations 2
S Product Bio-burden Limits and Sublethal Cycle Requirements ISO 13485:2016 - Medical Device Quality Management Systems 4
A Stuck at 'Analyse' stage of DMAIC Improvement Cycle on Cosmetic Specification Manufacturing and Related Processes 10
B Number of Biological Indicators for Routine Monitoring of ETO Sterilization Cycle Other Medical Device Regulations World-Wide 8
M Revision of ISO 16142 - Clause on use of standards in the medical device life-cycle Other Medical Device Related Standards 3
S Fractional cycle fail in Eto sterilization validation ISO 13485:2016 - Medical Device Quality Management Systems 3
D QMS 1st Cycle - Indicators and Data ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 18
2 Complete Cycle for Complaint Process - Idea Searching Customer Complaints 7
K Task and Sub Tasks of Software Life Cycle Phase Quality Assurance and Compliance Software Tools and Solutions 1
A Understanding adoption of a product to an existing Sterilization Cycle Other US Medical Device Regulations 1
E Where to Buy IEC 62304 Software Life Cycle IEC 62304 - Medical Device Software Life Cycle Processes 7
V Examples of Risk Assessment (FMEA) through the Life Cycle of the Product Development ISO 14971 - Medical Device Risk Management 16
M Calibration Cycle for Standard Iron & Steel Plate Gage General Measurement Device and Calibration Topics 17
Y Definition Traffic Cycle and Chart Deck Story - Terms related to Quality Management Definitions, Acronyms, Abbreviations and Interpretations Listed Alphabetically 6
L EO Sterilization Cycle Revalidation Intervals ISO 13485:2016 - Medical Device Quality Management Systems 2
P 3 Year Audit Cycle (ISO 17021:2011) General Auditing Discussions 2
somashekar Sampling Technical Files Continually throughout the Certification Cycle EU Medical Device Regulations 6
