Tape Measure Verification - Starrett 72" certified steel rule
SteelMaiden
#11
By the way, do you really have to calibrate your standard every two years, or would it suffice to simply verify the condition is still pristine?
Since that is the one that all else is verified against, it would be hard to justify not looking at it periodically. Our customers expect it, we are audited to some pretty heavy duty standards with legal and regulatory requirements. (nuclear) It is easier to do it with some of our other 2 year stuff is being done.
#12
There's nothing in evidence at this point to indicate that the "certified" master has been properly calibrated (e.g., to traceable standards), which is why I asked the OP earlier what "certified" means.
Helmut Jilling
Auditor / Consultant
#13
I understood the OP comment to indicate that the master 72" rule was a "certified" master issued by Starrett. Everything else would of course hinge on that.
andygr
#14
The only concern I could see is "stretching" causing the length to be off- especialy in a rough enviroment. I belive that you cover it with the visual inspection as to impact enough to affect you 3/16 should show something I would think.
:2cents:
Jessic2952
#15
The master 72" rule I use is certified by Starrett; I would type out everything on the certificate but basically it states it is traceable to NIST standards. I was only going to "calibrate" the 72" rule every 5 years -- and let Starrett do that.
As far as stretching goes, I don't see that happening beyond 1/16 of an inch since we're not tugging on the things and it doesn't get that hot... besides the material is full hard steel; it would be hard to stretch!
I'm glad to see that so many of you guys are in agreement with me!!! I knew I wasn't being noncompliant. The external auditor with SRI even said so.:thanx:
Hershal
Metrologist-Auditor
#16
I would like some advice from someone (anyone) who can let me know if my current practices for tape measure verification is sufficient for the TS 16949 standard....
Background info:
Tape measures are used to measure the widths of steel coils. This measurement goes on the customer's paperwork. Steel coils range in widths from 35" to 65". Tightest width tolerance (per ASTM requirements) is 3/16".
Current practice:
1. When new tapes arrive at our facility (Komelon brand), they are pulled out against a Starrett 72" certified steel rule. Each inch increment is verified for accuracy, then issued to operators on the shop floor.
2. The operators inspect the tapes at the beginning of each 12-hour shift for any damage such as kinks, wear and tear, etc, that would invalidate measurement results. During this inspection, they also test the accuracy of the tape's end piece with a certified Mitutoyo 1" gage block. If there is any kind of damage along the operating range of the tape or the end piece, they are instructed to discard the tapes and get a new one.
3. If the tapes last that long (mill environments can be rough!), then the tapes are brought back to the lab and pulled out against the 72" certified rule again after 2 years. If they pass, they are reissued; if not, they are disposed of and corrective action is taken place if it is suspected that material has been measured incorrectly.
Suggested practice by QMS dept:
The 1" block is not enough. Instead, operators should be using certified 72" steel rules at each shift (instead of the 2-year interval currently in place).
Arguments against suggested practice by QMS:
1. The certified steel rules are relatively expensive ($600-700 each), compared to the 1" blocks (about $15 each).
2. MSA studies (specifically stability) has indicated that the current process is stable enough to not require modification to the 2-year verification interval on the 72" rule.
3. Claims/complaint/internal hold data does not suggest any width issues arising from out-of-spec tape measures.
4. It's a tape measure, for goodness sakes. If it's good when you bought it and doesn't become damaged, then it remains good.
If anyone can point me to a clause in any standard or ISO guidance material where our current practices are noncompliant, then please do so. I am also a TS 16949:2002 certified lead auditor; I'm not sure why QMS department is unsatisfied with our verification process for tapes. I have also searched ISO 10012:2003 and have found nothing in there that suggests we are noncompliant. Am I overlooking something somewhere?
HELP!!
I can't speak to the TS-16949.....only to the metrological aspect.....
First question, for your Starrett master rule, is it at once anchored and calibrated by an external and ISO/IEC 17025 accredited calibration laboratory? If not, then you may have significant questions to answer to your auditor.....
Verification using gage blocks is also OK, except now you need to include wringing for each time you move the block (typically accepted as 0.00005") per wringing.....
Oh, and you should - even for verification - calculate your uncertainty, not to report, it is verification after all, but YOU need to know what the error is in a given measurement.....that is what uncertainty tells you.....
Now, let's get real.....you measure to 3/16" which is not far distant from the most believable limit of a tape measure.....a decent tape can be accpeted to - at best - 1/16" as then one gets into the width of the marking and so forth.....so 3/16" is basically pushing the limit a bit.....but you are still good.....so verify your tapes to 1/8".....
I would put the tapes on a MUCH tighter schedule for verification, a quarter at most.....not two years.....your statement regarding wearing is a good evidence of that.....
Hope this helps.....
Hershal
Helmut Jilling
#17
First question, for your Starrett master rule, is it at once anchored and calibrated by an external and ISO/IEC 17025 accredited calibration laboratory? If not, then you may have significant questions to answer to your auditor........Hope this helps.....
Hershal
Starrett has acquired and maintained ISO/IEC 17025 accreditation for the last few years...possibly as a result of the TS requirement.
T Tape Measure, the right device for 2 or 3 decimals accuracy on prints General Measurement Device and Calibration Topics 8
K Using a Tape Measure for +/- 1/16" Tolerance - Large Welded Assemblies (6 to 12') Inspection, Prints (Drawings), Testing, Sampling and Related Topics 12
Q Validating Tape Measures used to Measure Product Conformity to Requirements ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 7
C Get 2 soda cans and a tape measure Funny Stuff - Jokes and Humour 10
D Gage R&R on one tape measure to represent all identical tapes Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 1
H Five Foot Caliper vs. Tape Measure - Tolerance issues General Measurement Device and Calibration Topics 5
L Tape Measure Calibration - I asked if I had to do nominals, was told no! General Measurement Device and Calibration Topics 7
K Re-validation of EtO sterilization after change of tape Other Medical Device and Orthopedic Related Topics 1
R Tape Measures NOT used for Inspection or Testing Measurement Uncertainty (MU) 12
I Batch Numbering for medical tape EU Medical Device Regulations 1
AnaMariaVR2 DIY Fixes Don't Meet CGMP: FDA Slams Manufacturer for Fixes Involving Tape, Rubber Ba Pharmaceuticals (21 CFR Part 210, 21 CFR Part 211 and related Regulations) 0
Q Sampling Plan for Paper and Tape Industry Inspection, Prints (Drawings), Testing, Sampling and Related Topics 7
L Product numbers & sources for ASTM D3359 adhesive tape Inspection, Prints (Drawings), Testing, Sampling and Related Topics 1
A Japan - Medical Device Classification for Autoclave Tape Japan Medical Device Regulations 6
I Cleaning Validation for Durapore Tape Cutting Machine EU Medical Device Regulations 2
C Carton Boxes for Surface Mount Tape and Reel Manufacturing and Related Processes 7
D Gummed Water Activated Packaging Tape causing Mildew? Manufacturing and Related Processes 6
P PMMA IRK304 Resin and EVA (Ethylene Vinyl Acetate) Tape causes a Stain Mark Manufacturing and Related Processes 3
P Metal Tape Plating Process - CQI-11 Required? IATF 16949 - Automotive Quality Systems Standard 2
P Exempt from Calibrating our Tape Measures and Micrometers ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 32
Q PPAP for Materials - Rolls of adhesive tape, rolls of films and sponge material APQP and PPAP 5
D For Reference Only or Calibration/Verification - Tape Measures for cutting bar stock ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 26
P Tape Measures (again) Gage R&R Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 7
N Sufficient measurement of length - 4:1 TUR - Basic 25ft tape measures Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 4
Z Industrial Standard on Accelerated Ageing test for plastic carrier tape Reliability Analysis - Predictions, Testing and Standards 8
B Steel Measuring Tape - Can a Steel Measuring Tape be excluded from calibration? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 38
J Pressure Sensitive & Gummed Tape IMDS Reporting RoHS, REACH, ELV, IMDS and Restricted Substances 5
Scott Catron Tape-less digital video camera buying advice After Work and Weekend Discussion Topics 4
T Calibrating or Verifying Metal or Steel Tape Measures General Measurement Device and Calibration Topics 195
A Tight Control Limits - Tape & Reel Process, the process of packaging ICs Statistical Analysis Tools, Techniques and SPC 27
J Measuring Tape Repeatability and Accuracy - Types of tapes - ECIII, ECII and ECI Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 1
L Generic Accuracy of a 100 foot Tape Rule General Measurement Device and Calibration Topics 10
P Need Tape Spec for MSCH 62 Full Tape Wrap & MSDC 13-B Spot Tape Various Other Specifications, Standards, and related Requirements 3
J Verbage to cover tape measures General Measurement Device and Calibration Topics 6
Icy Mountain Reasonable calibration? 50 foot measuring tape and other basic M&TE General Measurement Device and Calibration Topics 25
D Gage R&R required on 6" rules, tape rules, verniers or micrometers? Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 4
R Gage R&R for measuring tape for some wire length inspection Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 2
L Tape Measures & Scales - Part Tolerance - Gage R&R Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 24
R Calibration of Tape Measures used for reference General Measurement Device and Calibration Topics 13
G Steel Tape Rules - Does the length of the leads have a significant impact? General Measurement Device and Calibration Topics 21
D Calibration of Tape Measures used on our production floor - What are 'Best Practices' General Measurement Device and Calibration Topics 42
C First Article Inspections - 'how to measure' General Measurement Device and Calibration Topics 11
lanley liao Question regarding the calibration of monitoring and measure equipment. Oil and Gas Industry Standards and Regulations 0
P How to measure DPPM in Chemical batch manufacturing Quality Tools, Improvement and Analysis 1
silentmonkey How to measure severity if my product is designed for emergency use and failure would result in death? ISO 14971 - Medical Device Risk Management 9
A Looking for a third party to calibrate our measure equipment - South Carolina General Measurement Device and Calibration Topics 6
J Validity / outcomes measure for custom made medical device ISO 13485:2016 - Medical Device Quality Management Systems 2
D Performance specification as a Risk Control Measure, EN 14971 ISO 14971 - Medical Device Risk Management 7
