Task analysis and ISO 14971
h689e2NR2ok4mceQ
Hi, I have a question about aligning risk analysis techniques such as task analysis with 14971. The cognitive task analysis for our purpose is to identify possible task failures and hazards so we can compare the differences between our generic drug/device combination product and the reference.
My procedure is to consider all potential hazards but the ones that are acceptable don't need to be entered into my risk table. I'd like to know if anyone has guidance on how to understand the relationship between user error and 14971. For example:
Hazard = in this case we're looking at use errors caused by perception, cognition or actions.
Hazardous situations = I think we should be looking at the identified task failures in our task analysis as the cause of the hazardous situation?
Harm = clinician is available to advise
Foreseeable sequence of events = to me this is pretty much inherent in the task analysis exercise since the idea is to identify the primary operating functions and work through all the user steps.
Maybe another way of asking the question is if the identified task failures or use errors are considered the cause / hazardous situation? Or simply if it seems I'm on the right track?
I appreciate any feedback, thanks!
Marcelo
Failures or use errors are part of the sequence or combination of events that lead to the hazardous situation, so no,k they are not the hazardous situation.
The hazardous situation is the patient/user/other exposure to the hazard.
h689e2NR2ok4mceQ
Thanks Marcelo, that's exactly the sort of guidance I was looking for!
Use errors are a bit difficult but I found some examples in 62366 annex B that I overlooked because they're mixed in under 'hazard-related use scenarios'.
h689e2NR2ok4mceQ
One more question, does that apply to FMEA as well? Are there any fast rules as to how the failure effects and causes line up?
Thanks!
sagai
Fast rule is to involve a loads of common sense and medical domain expertiese for all of these wanderings.
Regards
sagai
Sorry to here that my wording received condescending. It was not the purpose at all.
More was on that all these risk analysis activities are in a universe of immense uncertainties. Reassurance that the works we have done for all of these were appropriate and effective matures over the years.
h689e2NR2ok4mceQ
Thanks for following up, I took that I was asking too many and unrelated questions about risk analysis techniques and 14971. You are correct about the uncertainties involved and we're at the point of setting up a new risk management program for a new type of product, so it's doubled.
Good advice, thanks and cheers :beers:
Marcelo
Quick answer is you should not use FMEA as a basis for fulfilling ISO 14971. Causes and effects on an FMEA are, usually, part of the sequence of events in the ISO 14971 model. The effects (on the device) are not hazardous situations, because the hazardous situations are the exposure of the patient/user/etc. to the harm.
h689e2NR2ok4mceQ
Thank you, it's helpful to think about causes and effects that way. Yes, I understand FMEA is not a basis for fulfilling ISO 14971. I'm looking at FMEA in terms of identifying a hazardous situation from a sequence of events and managing the risk in 14971.
Thanks again
I Root Cause Analysis when someone simply stops performing a task? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 16
B MDSAP 8.2.6 CH6 task 17 ANVISA 16/2013 3.2.1 - Label History in Device history record Other Medical Device Regulations World-Wide 3
D FDA QSR task checklist based on inspection citations 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 5
J GHTF (Global Harmonization Task Force) SG2 Guidance Documents EU Medical Device Regulations 3
S IATF (International Automotive Task Force) Rules 4th edition changes IATF 16949 - Automotive Quality Systems Standard 1
K Task and Sub Tasks of Software Life Cycle Phase Quality Assurance and Compliance Software Tools and Solutions 1
B The task of Auditing Clause 7.3 Design & Development ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 10
T ISMS (Information Security Management System) Task Flow Chart in 'Detail' IEC 27001 - Information Security Management Systems (ISMS) 7
D Quantifying Cost Benefits associated with a Particular Task Lean in Manufacturing and Service Industries 3
M How to handle the task of Organizing a Regulatory File Room Document Control Systems, Procedures, Forms and Templates 2
V Medical Device Definitions outside GHTF (Global Harmonization Task Force) Other Medical Device Regulations World-Wide 2
P GHTF's (Global Harmonization Task Force) Latest ASQ, ANAB, UKAS, IAF, IRCA, Exemplar Global and Related Organizations 5
M Rules for achieving IATF (International Automotive Task Force) recognition IATF 16949 - Automotive Quality Systems Standard 1
S Work Outside the Location of the Task (Telecommuting) Career and Occupation Discussions 3
S End of GHTF (Global Harmonisation Task Force) Other Medical Device and Orthopedic Related Topics 8
M GHTF (Global Harmonization Task Force) "Archived" Document question EU Medical Device Regulations 3
J Definition Activity vs. Task - Definitions in Process Mapping and Projects Definitions, Acronyms, Abbreviations and Interpretations Listed Alphabetically 9
Ajit Basrur GHTF (Global Harmonization Task Force) release 2 final documents Other Medical Device Regulations World-Wide 2
S Nadcap announces new Task Group for Conventional Machining AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 4
Ajit Basrur Proposed documents from GHTF (Global Harmonization Task Force) 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 2
P New IATF (International Automotive Task Force) Communiqu ASQ, ANAB, UKAS, IAF, IRCA, Exemplar Global and Related Organizations 0
Howard Atkins New IATF (International Automotive Task Force) web site IATF 16949 - Automotive Quality Systems Standard 26
G Posting of Initials or Names on a Computer Document as Proof of Approval or Task Done Document Control Systems, Procedures, Forms and Templates 3
Ajit Basrur GHTF (Global Harmonisation Task Force) - Guidelines for Regulatory Auditing ISO 13485:2016 - Medical Device Quality Management Systems 0
W Auditing the Task (Process) Elements - Visual Map Attached General Auditing Discussions 74
Raffy Training Competency - Job List vs. Job Description vs. Task Inventory ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 2
D ISO 9001: 2000 Task List, Gantt Chart, or ???? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 4
M MS Outlook - How to edit the front page of the 'Task' form Document Control Systems, Procedures, Forms and Templates 5
S How to perform verification of the Statistical Analysis Software? Qualification and Validation (including 21 CFR Part 11) 2
J Starting a Weibull Analysis: Source on how to perform Weibull Reliability Analysis - Predictions, Testing and Standards 2
V ISO 10360-5: 2020 Gap analysis and Action plan Excel .xls Spreadsheet Templates and Tools 1
Q IATF audit - Root Cause Analysis results IATF 16949 - Automotive Quality Systems Standard 5
B Struggling with using the 5.6 version Ford Capacity Analysis Report APQP and PPAP 5
JoCam MDR Gap Analysis - Consultant fees EU Medical Device Regulations 10
silentmonkey Overall Benefit/Risk Analysis - Risk Management VS Clinical Evaluation ISO 14971 - Medical Device Risk Management 3
Awais Forklift Reliability Analysis Manufacturing and Related Processes 6
T Tactics for Root Cause Analysis Problem Solving, Root Cause Fault and Failure Analysis 4
lanley liao How to correctly understand the bullet list d) of 6.3 Analysis of Data for API Spec Q1 Oil and Gas Industry Standards and Regulations 7
R The term "Benefit Risk Ratio" in EU MDR, do I need to present benefit risk analysis as a RATIO Risk Management Principles and Generic Guidelines 4
B Two excellent examples of process capability analysis from Quality Magazine Capability, Accuracy and Stability - Processes, Machines, etc. 5
A Attribute Analysis for colour matching scale Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 5
M Recurrent event analysis software (python) General Auditing Discussions 2
E Normal Condition Hazards in Risk Analysis ISO 14971 - Medical Device Risk Management 3
M MDSAP and 13485:2016 gap analysis Quality Management System (QMS) Manuals 1
M Gap analysis on ISO 14971:2019 with previous revision ISO 14971 - Medical Device Risk Management 8
M Risk Analysis Flow - Confusion between ISO 14971 and IEC 62304 IEC 62304 - Medical Device Software Life Cycle Processes 8
R ECG Risk Analysis Standards ISO 14971 - Medical Device Risk Management 2
T Root Cause Failure Analysis - Not following Customer packaging Specification Problem Solving, Root Cause Fault and Failure Analysis 9
H ISO 13485:2016 Gap Analysis by NB ISO 13485:2016 - Medical Device Quality Management Systems 7
